503 Posted April 3, 2016 Share Posted April 3, 2016 Hirth 3503 injected oil and fuel ,luv it Link to comment Share on other sites More sharing options...
Doug Evans Posted April 4, 2016 Share Posted April 4, 2016 I have had both the new system are fault less once set up much better for your engine cause engine get the oil when need and drop back the flow when not required where mixing only give oil at one rate. Too much oil is as bad as no oil in my books the pump will meter the flow from minimal too. 70/1 ratio motorcycle and out board have been running these for years even in the snow mobiles where weather can be extremely hard it works my two bob worth. I love the autolube systems Link to comment Share on other sites More sharing options...
spacesailor Posted April 9, 2016 Share Posted April 9, 2016 Come-on surely some-one's running premix in a 582,! Are you running the oil-pump with-out any lubrication ? spacesailor Link to comment Share on other sites More sharing options...
facthunter Posted April 9, 2016 Share Posted April 9, 2016 From memory the oil lubes the drive to the pump as well. Nev 2 Link to comment Share on other sites More sharing options...
corvairkr Posted April 9, 2016 Share Posted April 9, 2016 Come-onsurely some-one's running premix in a 582,! Are you running the oil-pump with-out any lubrication ? spacesailor Spacesailor,I converted my 582 from oil injection back to premix. I wouldn't run the pump dry you can buy a cover plate and O ring from Floods for about $20 Jason Link to comment Share on other sites More sharing options...
