Adrian Lewer Posted April 1, 2010 Share Posted April 1, 2010 Hi all I am excited to announce I have my own plane... Nothing flash, But a Zenith CH 601 HD. Aircraft has been damaged in a landing mishap where the nose-wheel collapsed but the aircraft is very repairable. Has 303 hours TTIS same as for the 80 HP Rotax Certified engine, some instruments are new and some old but as for the general outlook, all will be well with alot of TLC. Pictures to come. Link to comment Share on other sites More sharing options...
ahlocks Posted April 1, 2010 Share Posted April 1, 2010 I have my own plane...Nothing flash, But a Zenith CH 601 HD. Sounds perfectly flash to me. :thumb_up: And the best bit is that it's all yours!:big_grin: Link to comment Share on other sites More sharing options...
shags_j Posted April 1, 2010 Share Posted April 1, 2010 congrats. I am jealous. Link to comment Share on other sites More sharing options...
Adrian Lewer Posted April 1, 2010 Author Share Posted April 1, 2010 Thanks Guy's, It still has not sunk in... ( I have my own plane ) Here Is me sitting in it. Will have to get Busy with the build when I get back from holidays. By adrianlewer, shot with KODAK C340 ZOOM DIGITAL CAMERA at 2010-04-01 Link to comment Share on other sites More sharing options...
Adrian Lewer Posted April 1, 2010 Author Share Posted April 1, 2010 Well I am wet around the pants and would like to hear your advice on a few things. My intentions are for a full strip of the fuzz and replace most of the bits as the aircraft was un officially involved in another incident (kink behind the port wing in the longeron) not a part of this incident and the engine mount was also repaired (badly) so I will have to drill out all rivets and inspect, clean, paint strip and re prime (maybe even replace most parts) I will do the same for a the wings and most other components. Will also remove all instruments and fuel components and re assemble with new parts where needed (all fuel lines will be replaced) When it is finished re paint White. Why you ask, well you need to see for your selves. the A/C is in a fairly poor state and was not really looked after (built) well.. so for my own piece of mind this is what I want to do. it wont cost anything to do (except my time) and a few sheets of aluminum and some stock. So now I need to learn how to do all of this properly and safely, so who is out there who is willing to give me a helping hand to diss assemble (or come over and give me pointers) assemble, and do the general help the man with no idea thing ;) Also I am hoping to gain my level 2 accreditation from this ? can this be done ? With the engine I will need someone who can inspect it and sign off that it is airworthy again after a prop strike (to keep certification) but would also like to do it myself to get my level 2 accreditation so I can do it in the future. So as you can see I need lots of advice on where to get A/C grade aluminum, What paint stripper to use and how to do it, and special requirements in doing so, how to cut aluminum without getting microscopic cracks yada yada yada... sorry for rambling, am trying to type fast as I am about to leave for my first holiday in 12 years in about 30 minutes. Thank god for the iphone now I will be able to post on the move ;) Link to comment Share on other sites More sharing options...
Spin Posted April 1, 2010 Share Posted April 1, 2010 Congratulations Adrian, I can understand why you're so excited. Plenty of work ahead I suspect, but it will be a good learning exercise and you'll have a good honest little plane at the end of it, set up exactly the way you want it. Can't help you with the questions re L2 etc, suggest you have a good look at the RA Aus tech manuals and then ring RA Aus (Steve Bell?) for the finer details. Link to comment Share on other sites More sharing options...
Guest drizzt1978 Posted April 1, 2010 Share Posted April 1, 2010 I think you have the correct mindset. My advice and I have NO Experience on building planes. But do one thing at a time. If it is anything like a car, you can get so many things happening you loose focus. I suggest if you strip it, and a great idea, everything is labeled like crazy, what every is necessary so there is zero confusion as to what you took off and what goes where. Then i would attack it one obstacle at a time, Engine Mount, done. Engine done, Nose assembly done, firewall checked, done, And work over it in a logical order. And don't do any other projects except the plane! Will expect to see you at Tooradin when it is done. Link to comment Share on other sites More sharing options...
icebob Posted April 1, 2010 Share Posted April 1, 2010 Congrats, there is nothing better than working on your own aircraft, lots and lots of satisfaction. Bob. Link to comment Share on other sites More sharing options...
Adrian Lewer Posted April 7, 2010 Author Share Posted April 7, 2010 Thanks Guy's. Am now back from my holiday and will be making a few trips to the field to have a play with her. Link to comment Share on other sites More sharing options...
Guest Cloudsuck Posted April 9, 2010 Share Posted April 9, 2010 Nice work Adrian, congratulations! Please please please be very careful regarding the canopy on these aircraft and other structures. They have been killing people all over the world including here. I think there are some mods that need to be done. I know that they were all grounded by the FAA in the states at one time. See http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgSAIB.nsf/(LookupSAIBs)/CE-10-08?OpenDocument Link to comment Share on other sites More sharing options...
Adrian Lewer Posted April 12, 2010 Author Share Posted April 12, 2010 Hi CloudSuck. Yep checked my Aircraft AD book and they have been done. it has the new canopy latches. Will be starting a blog online discussing my build. Link to comment Share on other sites More sharing options...
Guest Cloudsuck Posted April 12, 2010 Share Posted April 12, 2010 Sounds like you have done your homework Adrian, good luck with your project. Link to comment Share on other sites More sharing options...
