Aero28
Everything posted by Aero28
  1. Hi Paul, Just looking at this thread, what type of carby did you end up using? I am currently wrestling with a Stromberg 175 off a Range rover, no adjustment any where. I have got a needle pretty close to make it run nice . Cheers Paul B
  2. I'm so glad I learned in 2002/2003 at 75 dollars for a 40 to 45 min dual flight in a two stroke Light Wing and Thruster. Couldn't pay the prices they want now. So ultralighting came about in the 70's -80's so not so well to do people could take to the sky's in minimum aircraft because ga was to expensive,( to regulated). Seems like its nearly done the full circle and is again out of reach to average wage earners. Maybe in 10 or so years there will be a minimum aircraft movement start again to get these people , young and old into affordable ultralighting?
  3. I'm so glad I learned in 2002/2003 at 75 dollars for a 40 to 45 min dual flight in a two stroke Light Wing and Thruster. Couldn't pay the prices they want now. So ultralighting came about in the 70's -80's so not so well to do people could take to the sky's in minimum aircraft because ga was to expensive,( to regulated). Seems like its nearly done the full circle and is again out of reach to average wage earners. Maybe in 10 or so years there will be a minimum aircraft movement start again to get these people , young and old into affordable ultralighting?
  4. Hiya Russ, I came across an old post concerning ea 81 's and rotax C gearboxes that you were in. I am doing away with my toothed belt drvie on a soob and going for a gearbox. tossing up between an Autoflight from NZ or a Rotax C from Bert flood. Have you heard of any issues with the rotax? (450 dollars cheaper than the Autoflight). Hope you can help Cheers, Paul.
    Read more
    1. Russ
      Russ
      EA81....rotax box.....great combo
  5. Hi Rotax, I'm interested in that gearbox, is it still for sale? Cheers Paul.
    Read more
  6. Hi Rotax, I'm interested in that gearbox, is it still for sale? Cheers Paul.
    Read more
  7. Thanks Russ, I thought the only robust option for the EA81 was A hirth..... no failures with the rotax?
  8. Hiya Cherk, did you ever sell that Hirth Gearbox?
  9. Hi All, Took this plane to Temora at Easter and had a favourable reaction to it. I have made a 62" x 38 prop for it and tried it and got 80 lbs of thrust....was a bit impatiant as it was not sanded real smooth, and no clear coat. The old 54" prop gave 110lbs of trust. Next step is finish the prop and a line of white paint on the belts (thanks Andys) and see what I get then. And a tacho
  10. Well...... had another go on Sunday and still not getting in the air. I had a couple of airman watching the taxi tests and they said there seemed to be heaps of revs but no thrust from the prop, (54") And it does look a bit small for what it has to do. So I am thinking a bigger Diam and pitch. But.... I have been offered a Cyunna 440 with a gearbox on it and prop which has previously been in a Neiport Bi Plane and it flew well, so another option.
  11. Ha Ha , very funny Riley, the dogs hypo , I reckon she'd be worth a dog and a half at least.. I will have to get a tacho that works, I have a 2"Falcon one in it at the moment but dosen't want to work. I am taking this plane to Temora at Easter to display, come and say gday if you are there.
  12. Hi Maj/Flyerme, The drive has 5 small vee belts on it and two were a little loose so I have put 5 on it that look about the same tension, this is without any adjustment done on the top pulley to tighten them up. I will have to sneek up on the tensioning, I dont' want to over tighten and chew out the crank bearing. Prop is 54" diam and don't know what pitch, Don't know rev's as the tacho isn't working yet. Engine has done moderate hours but seems to run nice. I have thought about putting a toothed belt on it , 2 pulleys and belt cost 250 dollars from Pies and an bit of machining. Anyway will try again this weekend and see if things have changed. Cheers Thanks for your help.
  13. Hiya Fellas, Gotta join in this thread about the lighter side of flying. I have just finished the 95.10 in the pic , it has a Kawasaki 440 with a 5 belt drive on it but not enough power to lift off. It weighs 156 kg's empty. Do you think the Kwaka has enough pull to do the job. How heavy is your thruster? Cheers.
  14. The foam comes in sheet form and is actually building insulation for walls, I think 25 and 30 mm thick. Dow Corning product. Each one of those ribs weighs 230 gramms with the cap strips. You don't really need to worry about lateral/sideways strength with ribs as the covering top and bottom takes care of that so would think that sandwich panel would be overkill. Cheers
  15. Hello All, I would like to add my bit to this discusion , The pic has 30mm wide foam ribs with .6 ally cap strips top and bottom. Sikaflex bonds the cap strips to the foam and pop rivits on the front and rear spars. The plane in my avatar has foam ribs.
  16. Thanks FlyTornado, That Suzi, don't know if it was a 1 litre or 1.3 was getting 320 lbs.
  17. Hello All, I have question about thrust. I am putting a EA81 in a High wing two place I designed. The Soob has 2:1 Belt drive CD 175 Stromberg off a Range Rover going into the standard inlet manifold, reground cam and inch and a quater exhaust with muffler. Propellor is a two blade Warp Drive, 70 ". Hooked it up to the fence and got 220 lbs of thrust. How much should I be getting? I am in the middle of making a larger inlet manifold and inch and a half exhaust so should breath a lot better. I have seen a 912 with three blade prop gets around 340 lbs of thrust. Cheers
  18. Thanks Chird, I have made contact.
  19. Thanks Scoyyt I will give them a try.
  20. Hiya Pete, I would think Tas Oak (Gum Tree) would be too heavy, I have often thought Celery top pine would be agood alternative to spruce and then i would think Hoop pine would be in the same strength /weight of Celery, If you find a supplier of Hoop could you let me know, need to make a prop. Cheers Paul.
  21. Well Monty...... Single cause I built a yacht and too many aeroplanes, and have two excellent kids. Some more pics in my album.
  22. Hello all, Just landed here from Tassie, Looks like a great site to talk all things aviation. I am mainly a builder , not so much a flier as the single seater I have has limited range so Haven't ventured far. Should change though as I have nearly finished a high wing two seater that will have more legs. Cheers
