68
Everything posted by red750
A horrific landing on the Greek island of Rhodes. He managed to save it, and other aircraft went elsewhere. I bet a few needed new underwear.
1.5M views · 6.5K reactions | Smashing ride #pilot #planes... WWW.FACEBOOK.COM Smashing ride #pilot #planes #aircraft #aviation #Planes #pilotlife #aviationlovers #pilotlifestyle #wings #pilotlifestyle.
This was copied from Facebook. This (unducted fan) concept has been explored before. I am not exactly thrilled about not having a cowling to protect the fuselage from flying projectiles when blades let go. Anyway progress is now largely dictated by climate change and economics. When an aircraft engine's bypass ratio is 15 or 16, the benefits of a large fan are wiped out by the additional drag created by a very big duct. The current bypass ratio on jet engines is at 11 to 12, so the end of large increases in bypass ratio is close. Turboprops have bypass ratios of 50-100 although the propulsion airflow is less clearly defined for propellers than for fans and propeller airflow is slower than the airflow from turbofan nozzles. An open fan design can easily take the bypass ratio up to 60. This would likley mean significant fuel burn advantages A bypass ratio is a key measure of the efficiency and performance of jet engines, referring to the ratio of air bypassing the engine core versus air passing through it. Airbus has said test flights of a demonstrator of the “open fan” engine would take place on a modified A380 towards the end of this decade. Tests will determine what powers the next generation of single-aisle aircraft that will succeed the A320 aircraft when they come on the market towards the end of the 2030s. Airbus hopes that the new engine configuration will contribute to an expected 20 to 30 per cent fuel efficiency improvement compared with existing models. Current types use “ducted fan” engines, where the fans are enclosed within a casing.
- 1 reply
- 1
These posts are spam and have nothing to do with recreational flying. Your login has been blocked and posts deleted. Mods.
The McDonnell 120 Flying Crane, also V-1 Jeep, was a lightweight utility flying crane helicopter designed and built by the McDonnell Aircraft Corporation during the 1950s. The open frame fuselage supported the three gas-producers and main rotor mast, with a small single-seat cockpit in the nose, which was originally open, but later enclosed. McDonnell had been interested in the flying-crane concept from just after the war, investigating rotors driven directly by ramjets and compressed air tip jets on the McDonnell XH-20 Little Henry, the cancelled McDonnell 79 Big Henry and the McDonnell XV-1 high-speed compound helicopter. The expected advantages included: inherent angle of attack stability increased inherent pitch and roll damping greatly improved dynamic helicopter stability ability to start and stop in high winds; no need for tracking and no dampers required no possibility of mechanical instability or ground resonance; very low vibration low maintenance due to absence of highly loaded bearings, reduction gears, shafting, and anti-torque rotor automatic rotor speed control. McDonnell started development of a private-venture flying crane helicopter in December 1956, progressing rapidly with a mock-up in January 1957 and the first of two prototypes flying on 13 November 1957, piloted by John R. Noll. The airframe of the Model 120 was very simple, comprising a welded steel-tube open structure, with the three-bladed main-rotor mast and gas-producers attached without covering. Rotor drive was by compressed air rotor-tip jets, fed by three 200 hp (149 kW) gas power AiResearch GTC 85-135 gas-producers. The Model 120 was only ever intended to carry loads under-slung or attached directly to cargo hooks on the underside of the top fuselage beam, including specialised pods. Although aimed at the US Army the Model 120 was also evaluated by the US Navy at the Naval Air Test Center (NATC), NAS Patuxent River, in September 1959. The Model 120 experienced powerplant problems initially, but demonstrated an excellent load to weight ratio of 1.5:1, but despite the proven performance no orders were forthcoming and cancellation of the project in February 1960 signalled the end of McDonnell's helicopter aspirations. Only two examples were built.
Aircraft incident point lonsdale
red750 replied to BrendAn's topic in Aircraft Incidents and Accidents
Is it just because there is so many of them that they dominate the crash reports? This one was in Texas. -
Maybe planedriver can reload the original image. I can't remember it but from my previous post it must have had a a humourous twist. As for Facebook, I find it provides a lot of information. Yes, there's also a lot of crap, but you can scroll past that. Most of the aircraft in the Oddball thread (290 0f them) are brought to my attention by FB, then I look them up of Wikipedia. Most of the reports about Trump come from FB. Nearly all my silly pictures and silly signs come from FB. Reports of deceased celebrities are from FB, and lots of quickie jokes come from FB. And they have lots of general knowledge quizzes and mathematics questions to keep my brain active. And that doesn't take into consideration keeping in touch with family and friends. Don't use Twitter (X), Truth Social, Instagram, Tik Tok or any other soshul meja.
The Falconar SAL Mustang, also called the 2/3 Mustang and the SAL P-51D Mustang is a Canadian amateur-built aircraft, originally produced by Falconar Avia and introduced in 1969. The aircraft is a 2⁄3 scale replica of the North American P-51 Mustang and is supplied as a kit or as plans for amateur construction. Since the winding up of business by Falconar Avia in 2019, the plans are now sold by Manna Aviation. In 1963 Falconar partnered with designer Marcel Jurca to produce the Jurca Gnatsum. By 1967, Falconar recommended a large number of changes to the design, which resulted in Jurca leaving the project. The modified aircraft was developed as the SAL Mustang and first flown in 1971 after significant cost overruns. Falconar Aircraft Ltd was sold to George F. Chivers and other investors, and operated as Sturgeon Air Ltd (SAL) with Falconar as an employee until 1973.[4] The SAL Mustang features a cantilever low-wing, a single-seat, or optionally a two-seats-in-tandem, enclosed cockpit under a bubble canopy, retractable conventional landing gear, including a manually retractable tailwheel and a single engine in tractor configuration. The aircraft is made from wood covered with fibreglass cloth and doped aircraft fabric. Some parts, like the belly air scoop are made from fibreglass. Its 24.8 ft (7.6 m) span wing has an area of 110 sq ft (10 m2) and mounts flaps that may be electrically or manually operated. The cockpit is 24 in (61 cm) wide and the bubble canopy is jettisonable. The aircraft's recommended engine power range is 200 to 350 hp (149 to 261 kW). Engines that have been used include the 200 hp (149 kW) Lycoming IO-360 horizontally opposed engine, the 200 hp (149 kW) Ranger L-440 inverted inline, the 180 to 235 hp (134 to 175 kW) Avia M 337 inverted inline, 230 hp (172 kW) Continental O-470 horizontally opposed, the 200 hp (149 kW) Ford 230 cu in (3.77 L) V6 automotive conversion, as well as other automotive V-6 or V-8 powerplants. Construction time from the supplied kit is estimated as 2500 hours. The paper plans supplied total an area of 450 sq ft (42 m2), weigh 13 lb (5.9 kg) and include a construction manual. An alternative set of plans allows constructing a tandem two-seat version. The plans are very detailed and complete and one builder rated them as "the best I have seen on any homebuilt airplane". The prototype was introduced at the 1971 EAA airshow painted in the same gold and red colors as the Canadian Golden Hawks airshow team. In July 2012 the manufacturer indicated that 18 examples had been completed and flown in the 43 years that the plans and kits had been available.
The Epic Victory was the second experimental jet designed by Epic Aircraft, a company that was based in Bend, Oregon. Epic Aircraft declared bankruptcy in 2009. Its assets were acquired by Aviation Industry Corporation of China and LT Builders Group; which as of July 2010 were in the process of restarting production of the Victory. The Victory is a single-engine very light jet that was intended to be powered by a single Pratt & Whitney Canada PW600. Epic used the Williams FJ33 engine for testing but planned to switch to the PW600 for final production. The aircraft seats 4 to 5, including the pilots, in a 2+2 or a 2+1+2 configuration. The aircraft took Epic six and a half months to design from concept to a flying prototype, with the first flight on 6 July 2007 from Roberts Field in Redmond, Oregon. The company had intended that the jet would be available for less than US$1 million. The aircraft was displayed at the Experimental Aircraft Association's AirVenture fly-in in 2007 at Oshkosh, Wisconsin, where the company began accepting down payments. The prototype's Federal Aviation Administration registration expired on 31 May 2017. It has not been renewed and the aircraft has been deregistered.
The Mooney M-18 "Mite" is a low-wing, single-seat monoplane with retractable, tricycle landing gear. The Mite was designed by Al Mooney and was intended as a personal airplane marketed to fighter pilots returning from World War II. The M-18 design goal was extremely low operating costs. The Mite is constructed mainly of fabric-covered wood, with a single spruce and plywood "D" wing spar. The wing aft of the spar is fabric-covered. The airfoil selected for the design was the NACA 64A215. The M-18 represented the first time a NACA 6-series airfoil had been used on a civil aircraft after World War II. The aircraft featured a unique "safe-trim" system. This mechanical device links the wing flaps to the tail trim system and automatically adjusts the horizontal stabilizer angle when the flaps are deflected, reducing or eliminating pitch changes when the flaps are lowered. The Mooney Aircraft Corporation built a total of 283 Mites in Wichita, Kansas, and Kerrville, Texas, between 1947 and 1954. The first seven were powered by belt driven, modified 25 hp (19 kW) Crosley automobile engines, but these proved to be troublesome. Production shifted to the M-18L powered by the four-cylinder, 65 hp (48 kW) Lycoming O-145 powerplant. The original Crosley-powered Mites were recalled and retrofitted with the Lycoming engines at no charge. The later M-18C used the Continental A65 65 hp (48 kW) aircraft engine. The market for the single-seat M-18 was limited, so Mooney later developed the four-seat M-20 to appeal to aircraft owners with families. In the early 1970s, Mooney offered plans for four different home-built versions of the M-18. Factory production of the Mite ended in 1954. Leading up to this, the company was losing $1000 on each plane, which accelerated the development of the M20. Another factor was that Continental had ceased production of the engine used in the Mite due to a lack of demand. A total of 283 Mites were constructed.
The Bensen B-8 is a small, single-seat autogyro developed in the United States in the 1950s. Although the original manufacturer stopped production in 1987, plans for homebuilders are still available as of 2019. Its design was a refinement of the Bensen B-7, and like that aircraft, the B-8 was initially built as an unpowered rotor-kite. It first flew in this form in 1955, and on 6 December a powered version, designated B-8M (M for motorised) first flew. The design proved to be extremely popular and long-lasting, with thousands of sets of plans sold over the next thirty years. The B-8's design is extremely minimalist, with not much more to the aircraft than a pilot's seat, a single tailfin, a rotor, and (in powered versions) the powerplant. In May 1968 a B-8 and B-8M were studied by the USAF under the Discretionary Descent Vehicle (DDV) program as the X-25B and X-25A respectively. In this scheme, it was proposed to integrate combat aircraft ejection seats with a small autogyro or rotor kite to allow downed pilots more control over their post-ejection landing spot. The X-25A and X-25B were used to evaluate the piloting and training requirements of the autogyros. No full-scale operational tests were ever performed. The U.S. Air Force stopped funding the DDV program with the end of the Vietnam War. One B-8M, named Spirit of Kitty Hawk (registration N2588B) was used to make a special commemorative flight exactly duplicating the first flight of the Wright brothers' original Flyer on the sixtieth anniversary of the occasion. This same aircraft was flown by Igor Bensen himself between May 1967 and June 1968 to set twelve world and US speed, distance, and altitude records for autogyros, the largest number of such records to be held by any non-military rotorcraft. Variants B-8 Gyro-Glider - unpowered rotor-kite intended to be towed behind a car B-8B Hydro-Boat - B-8 with a full boat hull intended to be towed behind another boat B-8M Gyro-Copter - standard motorised version, main production type. Usually powered by a McCulloch 4318 engine B-8MH Hover-Gyro - twin, coaxial rotor design with powered lower rotor and autorotating upper rotor, giving it the capability of hovering. Upper rotor and drive propeller powered by separate engines B-8MJ Gyro-Copter - B-8M modified for "jump" take off by a small second engine providing power to rotor head with anti-torque provided by rudder correction under power. B-8MW Hydro Copter - float-equipped B-8M X-25A - B-8M evaluated by USAF. Single example (serial 68-10770) first flown 5 June 1968 and preserved at the National Museum of the United States Air Force at Wright-Patterson Air Force Base B-8 Super Bug - similar to B-8M but with extra engine to spin up rotor before take-off B-8HD Super Gyro-Copter - development of Super Bug first flown in 1979 with hydraulic drive to pre-rotate rotor rather than separate engine B-8V - B-8 powered by a Volkswagen air-cooled engine B-8W Hydro-Glider - float-equipped B-8 intended to be towed behind a boat X-25B - B-8 evaluated by USAF. Single example (serial 68-10771) first flown 23 January 1968 and preserved at the AFFTC Museum at Edwards Air Force Base. Rotorcraft Minicopter Mk 1 - South African variant with pre-rotator and cockpit fairing. Aeroflyte DGH-1 - 70 hp (52 kW) license-built model from Aeroflyte.
The Changhe Z-10 (Chinese: 直-10; pinyin: Zhí-Shí; lit. 'helicopter-10') is a Chinese medium-weight, twin-turboshaft attack helicopter built by the Changhe Aircraft Industries Corporation for the People's Liberation Army Ground Force. Designed by 602nd Aircraft Design Institute of Aviation Industry Corporation of China (AVIC) and Kamov Design Bureau, the aircraft is intended primarily for anti-tank warfare missions with secondary air-to-air combat capability. The plan to develop a medium-weight helicopter program was initiated in 1994 with the attack helicopter program formally beginning in 1998. The preliminary design of the aircraft was provided by Kamov, while prototyping was conducted by the 602nd Aircraft Design Institute of Aviation Industry Corporation of China (AVIC). The Z-10 first flew on 29 April 2003 and entered Chinese Army Aviation service in 2009. Nicknames of characters in the Chinese classic novel Water Margin have been used to name Z-10 and its light-weight counterpart, the Harbin Z-19 by Chinese Army Aviation Corps; Z-10 is called Fierce Thunderbolt (Pi Li Huo, 霹雳火), the nickname of Qin Ming, while Z-19 is called Black Whirlwind (Hei Xuan Feng, 黑旋风), the nickname of Li Kui. For details of development an history, design, operational history and 8 variants, click here.
The Martin XB-51 was an American trijet ground-attack aircraft. It was designed in 1945 and made its maiden flight in 1949. It was originally designed as a bomber for the United States Army Air Forces under specification V-8237-1 and was designated XA-45. The "A" ground-attack classification was eliminated the next year, and the XB-51 designation was assigned instead. The requirement was for low-level bombing and close support. The XB-51 lost out in evaluation to the English Electric Canberra which — built by Martin — entered service as the Martin B-57 Canberra. This unorthodox design, first flying on 28 October 1949, was fitted with three General Electric J47 engines - an unusual number for a combat aircraft - two underneath the forward fuselage in pods, and one at the extreme tail with the intake at the base of the tailfin. The innovative, variable incidence wings, swept at 35° and with 6° anhedral, were equipped with leading edge slats and full-width flaps. Spoilers gave most of the roll control and undersized ailerons provided feel for the pilot. The combination of variable incidence and slotted flaps gave a shorter takeoff run. Four 954 lb (4.24 kN) thrust Rocket-Assisted Take Off (RATO) bottles with a 14-second burn duration could be fitted to the rear fuselage to improve takeoff performance. Spectacular launches were a feature of later test flights. The main landing gear consisted of dual wheel sets in tandem in the fuselage, similar to the Boeing B-47 Stratojet, with outrigger wheels at the wingtips (originally proved on a modified Martin B-26 Marauder named "Middle River Stump Jumper"). The XB-51 was a large but aerodynamically "clean" design which incorporated nearly all major systems internally. The aircraft was fitted with a rotating bomb bay, a Martin trademark; bombs could also be carried externally up to a maximum load of 10,400 lb (4,700 kg), although the specified basic mission required only a 4,000 lb (1,814 kg) bombload. Eight 20 mm cannon mounted in the nose would have been installed in production aircraft. Crew was a pilot under a "fighter"-type bubble canopy and a Short-range navigation and bombing system (SHORAN) operator/navigator in a compartment located lower than and to the rear of the cockpit (only a small observation window was provided). Both crew members were provided with a pressurized, air conditioned environment, equipped with upward-firing ejection seats. The XB-51 was the first Martin aircraft equipped with ejection seats, these being of their own design.Number built - 2.
The Cunningham-Hall GA-21 was an American two-seat monoplane design to compete for the Guggenheim Safe Aircraft Competition in 1934. Its distinguishing feature was full span flaps which could be manually or automatically adjusted. The GA-36 was a military version of it with tandem, rather than side-by-side seating. The GA-21M was all metal aircraft apart from the fabric covering of parts of the wing, otherwise metal-covered, and the control surfaces. The low-set wings were rectangular in plan out to rounded tips and had a high lift section. Both flaps and ailerons filled the whole straight part of the trailing edge, so the latter only opened upwards. Apart from its unusual flaps and lateral control the GA-21M was conventional. Powered by a 145 hp (108 kW), seven cylinder Warner Super Scarab radial engine, it had a round-sectioned, metal-skinned, monocoque fuselage. An open cockpit over the forward wing seated two side-by-side. The tailplane was mounted just above the fuselage on the fin and could be trimmed; essentially triangular in plan, it carried rounded elevators. A rounded rudder reached down to the keel. The GA-21Ms had conventional, tailwheel landing gear with the landing wheels ahead of the leading edge within aircraft fairings that also enclosed the legs. The GA-36 was a 1936 military trainer rebuild of the Ga-21M. This included a revised, tandem cockpit and more trouser-like landing gear fairings, making it 15% heavier. The automated flaps worked well but were more complicated than, for example, Fowler flaps and more expensive to construct. Simpler systems were preferred and the sole GA-21M/36 was sold in 1941, stripped of major components and dumped until the 1980s when it was recovered, fully restored and put on display at the Niagara Aerospace Museum. GA-21M GA-36
The Cunningham-Hall Model PT-6 was an American six-seat cabin biplane aircraft of the late 1920s and was the first design of the Cunningham-Hall Aircraft Corporation of Rochester, New York. The Cunningham-Hall Aircraft Corporation was formed in 1928 and the first design was the PT-6 (Personal Transport 6-place), which first flew on April 3, 1929.[3] It was flown to the Detroit Aircraft Show two days later, with minor alterations being made later including a switch from a tailskid to a tailwheel. The PT-6 was a cabin biplane with an all-metal structure that was stressed to meet military strength specifications rather than the much more lenient commercial requirements, however aside from the cabin, which was covered with corrugated aluminum, most of the airframe was fabric covered. It had a fixed landing gear with a tail wheel. The cockpit held a pilot and either a copilot or passenger, with a separate cabin for four passengers. The aircraft was powered by a 300 hp (220 kW) Wright J-6-9 Whirlwind radial engine. The company's final aircraft was a freighter conversion the PT-6F. Built during 1937 and flown in 1938, the passenger cabin was modified as a cargo compartment with 156 cu ft (4.4 m3) of stowage space, an NACA cowling was fitted, along with a variable-pitch propeller. A freight door was fitted to the fuselage and a loading hatch fitted in the roof. It was powered by a Wright R-975E-1 radial engine of slightly greater power. Only two PT-6s (s/n 2961 X461E and s/n 2962 NC692W) and one PT-6F (s/n 381 NC16967/NPC44/NC444) were registered, however as many as six of each type may have been built. The discrepancy from many publications with higher numbers may indicate that from two to nine additional airframes were built, but scrapped without being registered or sold, due to the collapse of the aviation market with the deepening of the Great Depression. A production line had been set up, and materials bought to produce 25 examples. Plans for a slightly smaller 4-seat derivative to be named the PT-4, and an armed military variant were also cancelled. One example was used for charter flying by the Rochester - Buffalo Flying Service, often fitted with skis or floats. One customer was the Fairchild Aviation Corporation. George Eastman of Kodak had his first flight in PT-6 The PT-6F was supposed to have been one of three built from parts still available from the original cancelled production run, for an expected Philippine customer, and even carried the Philippine registration of NPC-44, however a lack of funds caused that sale to be cancelled. The aircraft was eventually sold for around $7,000, and made its way to Alaska for a career as a bush plane with Byers Airways.
The Kamov Ka-26 (NATO reporting name Hoodlum) is a Soviet light utility helicopter with co-axial rotors. It looks like it has twin turbine engines in nacelles on each side of the body, but they are radial engines with turbofans for cooling. The Ka-26 entered production in 1969 and 816 were built. A variant with a single turboshaft engine is the Ka-126. A twin-turboshaft–powered version is the Ka-226. (All the Ka-26/126/128/226 variants are code-named by NATO as "Hoodlum"). The fuselage of the Ka-26 consists of a fixed, bubble-shaped cockpit containing the pilot and co-pilot, plus a removable, variable box available in medevac, passenger-carrying and crop duster versions. The helicopter can fly with or without the box attached for flexibility. It is powered by two 325 hp (239 kW) Vedeneyev M-14V-26 radial engines mounted in outboard nacelles. The Ka-26 is small enough to land on a large truck bed. The reciprocating engines are more responsive than turboshaft engines, but require more maintenance. It runs mostly at 95% power in crop dusting with usually excess payload, leaving little reserve power for emergencies. Due to frequent overloads, the interconnect shaft joining the two engines is prone to breakage and requires frequent inspection. The standard instrumentation of the Ka-26, like larger naval Kamovs, may be overkill for civilian or crop dusting use. The 18-dials cockpit panel masks a part of the right-downwards view, needed to avoid telephone and power lines at low altitudes. The instrument panel may be simplified to retain the six main dials. As there is a low rotor clearance at the aircraft front, it is approached from the rear when the rotors are turning. Due to the limitations of the Ka-26, USSR and Romania agreed under the Comecon trade to build a single-turboshaft engine version, the Kamov Ka-126, with better aerodynamics and range. The Ka-26 is eminently useful for civil agricultural use, especially crop dusting. The coaxial main rotor configuration, which makes the Ka-26 small and agile, also results in a delicate airflow pattern under the helicopter, providing a thorough, yet mild distribution of chemicals onto plants. The Ka-26 is often used to spray grape farms in Hungary, where conventional "main rotor and tail rotor" layout helicopters would damage or up-root the vine-stocks with their powerful airflow. Hungarian Kamov operators claim that coaxial rotors of the Ka-26 creates an airflow which allows well-atomized pesticides to linger longer in the air, causing more of the residue to settle underneath, rather than on top of, the leaves. This results in a more efficient distribution of pesticides, as most pests and parasites do not live on the top side of foliage. Additionally, the coaxial vortex system is symmetrical, allowing the distribution of the pesticide to be more uniform, without the side currents induced by the tail rotor, making it easier to avoid contaminating adjacent non-crop areas. In some Warsaw Pact armies, the Ka-26 was used only in the light paratroop or airborne role, but not the civilian agricultural role[citation needed]. In the military role, its slow (150 km/h) cruise speed compared with the Mi-2 (220 km/h) limits effective general-purpose military use, although its shorter length (7.75 m) compared with the Mil Mi-2 (11.9 m) and smaller rotor diameter (13 m vs. 14.6 m) are advantageous for military operations in an urban area. Its operational range is also greater than the Mil-2. On 30 June 2020, Moldovan police and prosecutors closed down an illegal factory producing unlicensed copies of the Ka-26. The factory had a production line with ten air frames in various stages of completion that were intended for sale to clients in former Soviet countries. Variants Ka-26 Hoodlum-A One- or two-crew utility light helicopter, powered by two 325-hp (239-kW) VMK (Vedeneyev) M-14V-26 radial engines. 850 built. Ka-26SS NOTAR technology testbed for the Ka-118 fitted with tail jet beams. Ka-126 Hoodlum-B One- or two-crew utility light helicopter, powered by one 720-shp (537-kW) OMKB "Mars" (Glushenkov) TVD-100 turboshaft engine. First flown in 1986, built and developed by Industria Aeronautică Română in Romania. 2 prototypes and 15 series helicopter built. V-60 A prototype light armed escort helicopter based on the Ka-126. Ka-128 One prototype, powered by a 722-shp (538-kW) Turbomeca Arriel 1D1 turboshaft engine. Kamov Ka-226 Six- or seven-seat utility helicopter, powered by two 450-shp (335-kW) Rolls-Royce (Allison) 250-C20R/2 turboshaft engines.
The pilot of the Black Hawk helicopter that collided with the American Airlines passenger airplane did not comply with directions to change course seconds before the fatal incident, a bombshell new report has revealed. On the night of January 29, Army Black Hawk pilot Capt. Rebecca Lobach was conducting an annual flight evaluation with her co-pilot Chief Warrant Officer 2 Andrew Loyd Eaves, who was serving as her flight instructor. Three months on, new details published by The New York Times revealed that the pilot made more than one mistake leading to one of the worst catastrophes in aviation history. Not only was Lobach flying her Black Hawk too high, but in the final moments before the impact, she failed to take advice and instruction from her co-pilot to switch course. Lobach's piloting skills were being tested during the evaluation on the fateful night, before the crew were informed that an aircraft was nearby, according to the report. Just 15 seconds before colliding with the commercial airplane, air traffic control told Lobach and Eaves to turn left, but she did not do so. Seconds before impact, co-pilot Eaves then turned to Lobach in the cockpit and told her that air traffic control wanted her to turn left. She still did not do so. Investigators may never know why Lobach did not change course that day. Both Lobach and Eaves had first acknowledged the message that an aircraft was nearby, and spotted the plane themselves before requesting to fly by 'visual separation.' This is a practice that allows aircraft to avoid collisions based on their own observations instead of following the air traffic controller's instructions. 'The request to fly under those rules is granted routinely in airspace overseen by controllers. Most of the time, visual separation is executed without note. 'But when mishandled, it can also create a deadly risk — one that aviation experts have warned about for years,' aviation experts told the outlet. The report stated: 'The Black Hawk was 15 seconds away from crossing paths with the jet. Warrant Officer Eaves then turned his attention to Captain Lobach. He told her he believed that air traffic control wanted them to turn left, toward the east river bank.' If she had turned left, it 'would have opened up more space between the helicopter and Flight 5342,' it added. Instead, 67 people - everyone aboard the plane and helicopter - perished. Lobach, from Durham, North Carolina, was an aviation officer in the Army and had racked up around 500 hours of flying time. She also served as a White House military social aide during the Biden administration. A critical rule in the industry is that if two aircraft are on a collision course pilots have to be advised if they are likely to merge, according to Federal Aviation Administration (FAA) regulations. Experts found that did not happen that night and that 'immediate intervention was needed' to prevent the horrible tragedy that left 67 dead. 'Direct, immediate intervention was needed that night. Instead of seeing and avoiding Flight 5342, Captain Lobach continued flying straight at it,' the report read. Though it remains unclear why Lobach defied orders, Aviation experts predict she may have been 'blindsided' that the American Airlines flight was 'circling' Runway 33 that night. Investigators now believe the Black Hawk crew did not hear the word 'circling' because they might have been pressing the microphone key to talk at the same time the crucial term came through, according to the report. 'If the key is depressed, the pilot can speak but not hear incoming communications,' it detailed. There is also no indication that Lobach suffered a medical emergency at the time of the crash, and didn't have pre existing health issues, her loved ones and people close to the investigation told the outlet.
Thanks Red, well spotted. Image replaced.
Found another website in Italian which when translated, gives this engine detail - 2 x 250 AG (184 kW) power 6-cylinder oposic internal combustion engines L-O-540
