Lyndon
Everything posted by Lyndon
  1. Same part
  2. Is this the back my book says sb 003-12 but ???
  3. Would an xl be wider than the VG ???
  4. Thanks
  5. Great thanks with that in mind I'm sure it make sense. I have found the floor. But can't seem to find the back wall of the compartment. I will keep looking. Lyndon
  6. Sorry Savannah VG
  7. This has done my head in. There is an option for an extended baggage compartment. Looks like my kit does not have it. So that's fine. But that implies that there is one. But from what I can work out with out this option it does not have a baggage compartment at all. Just a flat sheet of aluminium behind you. Not having seen a plane can someone please confirm this is correct. Lyndon
  8. Lyndon
    Stabilizer ???
    Any recommendations Lyndon
  9. Lyndon
    Stabilizer ???
    Off the subject is there an upgrade for the control stick rubber. Seems ordinary Lyndon
  10. No worries. I have actually sorted that next the trim tab all ordered from Reg Lyndon
  11. Lyndon
    Stabilizer ???
    The booked has not fitting the last end plate crossed out. So I fitted it. I take it there is no need to fit it when it's all hooked up to the elevator.
  12. Yes I think yours is on the side and mine in the middle. Thanks Lyndon
  13. Fitting the trim servo. Book is very ordinary. Picture of it mounted and the wiring would would tell a thousand words. Lyndon
  14. Thanks
  15. Spare black block
  16. Perfect. I have one block left. I take it that will be used later some where else
  17. I have two identical blocks left. One on either side of the nose skin or is one used somewhere else. The cable is installed so the adjuster will be up the front of the plane as this makes sense to me. Lyndon
  18. Block in
  19. It's says use the middle block. There is three of these. Mine has four. Pretty sure it's right
  20. Thanks Mark. Your going to be a busy man over the next 6 months.
  21. Before I button it up. Have I thread the correct end through it. It can go in either end Lyndon
  22. I will now replace these three rivets
  23. Mark great info. I too just found my counter sunk rivets for my fin. Three a4 ones. The four a3 rivets that fit the retainers in the same spot I take it are just normal a3 rivets. Lyndon
  24. I've had a look. Don't guess you know roughly what page. Lot of information on your build. Lyndon
  25. Ta will take a look Thanks Lyndon
