Chocolate Posted September 19, 2014 Share Posted September 19, 2014 Has the new credit card bowser been installed yet? Thank youThank you Link to comment Share on other sites More sharing options...
Chocolate Posted September 20, 2014 Author Share Posted September 20, 2014 Bump. Anyone Link to comment Share on other sites More sharing options...
viewfromright Posted September 21, 2014 Share Posted September 21, 2014 The slab is done - slight hold up with council. Link to comment Share on other sites More sharing options...
dlegg Posted November 12, 2014 Share Posted November 12, 2014 Install is now complete and just waiting for it to be filled with avgas.....hopefully by end of this week:wave: Link to comment Share on other sites More sharing options...
viewfromright Posted November 12, 2014 Share Posted November 12, 2014 A very professional job - well done to the QRAA team in Warwick. 1 Link to comment Share on other sites More sharing options...
horsefeathers Posted November 12, 2014 Share Posted November 12, 2014 Can Avgas be used in a Rotax 582? Maybe even just a tankful every now and then??? Link to comment Share on other sites More sharing options...
Tex Posted November 12, 2014 Share Posted November 12, 2014 Yes it can. The lead will cause more deposits to build up and I have found that the spark plugs get pretty dirty too... none the less it can be used but better to have a mix of standard and AVGAS. Link to comment Share on other sites More sharing options...
Russ Posted November 12, 2014 Share Posted November 12, 2014 582 being a 2 stroke, avgas premixed to correct ratio, ( 50 / 1 or whatever ) should actually reduce lead problems quite significantly. .??? Folks are just slightly dosing avgas in 4 stroke engines to control lead build ups, ring seizures etc. I for one do, and my plugs look clean as. Now done around 60 hrs. Link to comment Share on other sites More sharing options...
