kfowler Posted May 17, 2010 Posted May 17, 2010 hi my lsa has a problem i went for a fly today as most take off it runs rough at about 300 feet agl the only way to get it to run smooth is to pull the carby heat on back the throttle back till the engine tacho just starts to drop the engine has 400hrs the plugs replaced and tappetts adjusted 10 hours ago the spark plug leads where also replaced it has a economy kit with a 2.85 mm jet fitted 340 hrs ago the problem only started when i moved up to the N.T. the temp today was 31.5 degress with they humity above 50% any ideas thank keith
Ultralights Posted May 17, 2010 Posted May 17, 2010 could be Mixture related, or carby ice, jabirus Love carby ice. but if bringing the throttle position back till RPM just begins to drop, it sounds more a Mixture issue. closing the throttle valve is reducing the air in the air/fuel mix, and bringing it back to a more normal/correct mixture.
Modest Pilot Posted May 17, 2010 Posted May 17, 2010 Maybe an obstruction in the fuel system. If you have a fuel flow meter should be around 31lt/hr at your OAT. You could also check by disconnecting the fuel line at the carb and measuring a minute of flow on the boost pump.(be careful fire risk!) If flow is low check the fuel filter and for kinks in the fuel lines. One other thing, check the fuel bowl somehow a white compound had built up after 50 hours in my aircraft. Looked like fuel slosh, how it got through the filter beats me, it was extremely difficult to remove.
Tomo Posted May 17, 2010 Posted May 17, 2010 Is it Hydraulic or solid lifters? Have you checked the propeller by any chance also?
Guest Nelson Smith Posted May 18, 2010 Posted May 18, 2010 Running Rough Hi Keith If it isn't an ice problem,then the fact that pulling carby heat on and reducing revs improves the running, it would suggest that the carbureter is not geting enough air via the naca duct.Pulling heat on gives the carby an alternate source of air. Lets know what you find Nelson
Yenn Posted May 18, 2010 Posted May 18, 2010 Sounds like a too rich mixture. There have been a few cases of sticking slides in the US. A bit of corrosion on the slide causes it to stick in the full throttle position, meaning that the needle valve is giving a too rich mixture.
facthunter Posted May 18, 2010 Posted May 18, 2010 Slide stuck OPEN. Slide stuck open does not give a too rich mixture. The mixture will go lean of the slide jams open. That conclusion is incorrect. You can't always believe what you read. Usually applying carb heat will enrichen the mixture . The carb may have a build-up Of white powdery material in it. Clean it out and if you have the lean needle replace it with the later one. Nev.
cherk Posted May 18, 2010 Posted May 18, 2010 G'day Keith, could check the hose from the carby fuel bowl to the air box(from memory), something to do with pressure equalisation... pulling carb heat tends to iron it out smoother!
Kiwi Posted May 18, 2010 Posted May 18, 2010 As "cherk" just stated, We had a jab with the same symptoms as yours and all that was wrong was the equalizer tube between the carb and the air box had been knocked off. Kiwi
Tomo Posted May 22, 2010 Posted May 22, 2010 Quote hi solid lifter Ok, thanks. I know of a 3300 that had very similar problems. They thought it was everything else, but once they changed the hyd lifters to high flow the problem stopped. Hope you get it sorted asap.
kfowler Posted May 23, 2010 Author Posted May 23, 2010 hi all thank you for your input the balance tube is not blocked this week end i went to emkaytee. on take of this time i did not use W.O.T. and the engine ran fine, on take the same coming back.it looks like to rich with W.O.T. at cruise 2800 rpm the fuel burn is 13.63 lts / hour thanks keith
jetjr Posted May 31, 2010 Posted May 31, 2010 If carb heat helps your running too lean When putting in new needles did you adjust float levels as required as this will do this and can lead to lean running right through rpm range, Can have serious consequenses Often ONLY seen as EGT problem or "running out of fuel" feeling after 20 sec or so of WOT
kfowler Posted May 31, 2010 Author Posted May 31, 2010 thanks jetr i am going to bundaberg this week and i will pick up a new set of needles and jets thanks keith
