Ouch! Foxbat Crash
Just found this a second ago while looking for something on google, looks like an expensive accident:
http://www.pixstel.com/6648.html
"Approaching Popham Airfield, Aeroprakt A22 Foxbat G-CWTD seemed to loose power. A wing dipped touching the ground, resulting in wing and undercarriage collapsing. Occupants emerged unhurt."
I don't know how this even could have happened unless it was a pretty strong gust of wind. Other than that there isn't much excuse for a control input like that....
Found this description too: Taken just a few seconds after the Foxbat had come to a halt. The aircraft appeared to approach the runway very slowly before yawing to the right, leading to the wing dropping. The left wing struck the ground & this subsequently caused two of the wheels to break-off on impact. No fire occured, & both the pilot & passenger escaped without injury.
From this site: http://www.flickr.com/photos/ojfphotography/4570618202/
Another photo by the same user on Flickr said the aircraft yawed and this caused the left wing to drop...
Also: http://www.aaib.gov.uk/publications/bulletins/august_2010/aeroprakt_a22_foxbat__g_cwtd.cfm
I don't know how this even could have happened unless it was a pretty strong gust of wind. Other than that there isn't much excuse for a control input like that....Found this description too: Taken just a few seconds after the Foxbat had come to a halt. The aircraft appeared to approach the runway very slowly before yawing to the right, leading to the wing dropping. The left wing struck the ground & this subsequently caused two of the wheels to break-off on impact. No fire occured, & both the pilot & passenger escaped without injury.
Okay, flaunting my ignorance here; Why would a yaw to the RIGHT cause the LEFT wing to drop? If the left wing stalled the nose would yaw left. I suspect a wind gust caught the pilot by surprise. There have been a few times I have found myself belting down the runway with my wing tip just off the ground, mainly why I won't fly in hot, gusty conditions (beer drinking conditions).insane.gif.b56be3c4390e84bce5e5e6bf4f69a458.gif
One description says that and the other just says yaw caused the left wing to drop, must be a mistake somewhere...
Pity,
They are a delight to fly. They have excellent controllability at low speed, but they are as flimsy as hell in construction. Difficult to tell the severity of the impact from sequential photographs. He must have still had some power, the prop was spinning. First picture shows a fair bit of right aileron down ... that wouldn't help the roll at all.
Looks more like it was heading left and the pilot tried to pick the LH wing up with aileron - which at low speed wouldn't have been so effective. Wonder why he didn't use hard right rudder to yaw it straight and in doing - lift the left wing?
happy days,
But Iggy, I know where Pots is coming from as a tailwheel pilot.
Picture this, you are in a tail wheel aircraft at late final in a stiff cross wind, you have the into wind wing real low and a fair bit of top rudder in to track straight. You are flaring to do a two pointer (the into wind wheel and tail wheel to land first) ... you are right on the stall and a strong gust picks up the into wind wing and you are in real danger of a tip over. At this point the rudder is your best friend, you aggressively kick opposite rudder to what you are holding to keep her straight and this has the effect of accelerating the down going wing to lift it and stall the up coming wing to keep it down. These are almost counter intuitive moves. At this point you are on the stall and it might not look pretty and the aircraft will lope onto the ground and your speed is so slow even the resulting minor ground loop will cause you no trouble. You have just saved yourself from a very ugly outcome.
Do you understand what he is saying now Iggy.
You got to love reading these reports sometimes.When the backside covering starts, normally with the story telling.In this eg- Pilot stated that his attention was withdrawn away from monitoring the aircrafts speed, and towards the gyrocopter further down the runway "blah blah
Just come out with the truth- Three words will allways cover it.They are " I F^&k#d Up". Simple:joystick:051_crying.gif.fe5d15edcc60afab3cc76b2638e7acf3.gif
Guest aussie carl
far out !! Done some pretty ugly 13knot crosswind landings last week and didn't break nothing so that must have been a big hit to bust the UC.
HI Carl, sorry mate.I didnt read anywhere about a gust of wind, the 12 mph wind should not have been a problem.The wing dropped.That wing had stopped flying.He was flying to slow on final and round out from what I can gather looking at the photos and reading the reports.He says he was distracted looking at a Gyro up a head.If the Gryo was coming into play, on lets at a guess say turning final.He should have gone around.This is pure speculation as I wasnt there or anything. 002_wave.gif.62d5c7a07e46b2ae47f4cd2e61a0c301.gif
Is it just me or is that right wing flaperon being down, whilst the other one doesn't appear so? Or it could be left aileron I suppose, but why do that when you're tipping left! I'm confused, or was there a flaperon failure.
Agree with the use of rudders for low speed operation!
Anyway, either way at the end of the day it wasn't a good one for the aircraft!
Is it just me or is that right wing flaperon being down, whilst the other one doesn't appear so? Or it could be left aileron I suppose, but why do that when you're tipping left! I'm confused, or was there a flaperon failure.Agree with the use of rudders for low speed operation!
That is a good point Tomo.Its a bit hard to pick up much in the pictures, but see exactly what you are saying..Im am going on the pilots report.Where the pilot said he was distracted and not monitoring the aircraft speed .To me between the lines means "got too slow".
Guest aussie carl
What ever happend the ocupants walked away and that's all that realy matters I say. Worth every ucraian $.
lessones will be learnt by pilot and if we get the full story we may learn something to.
Look at the first two shots-the control sufaces tell the story. But its real easy to be judgemental in front of a computer. I have had a wing lifted just before touchdown in my bat from a sudden gust during a x wind landing. Could have ended like this- just lucky I caught it in time. The best part of that sequence of shots is the two occupants getting out unhurt.
When things are getting slow, forget the ailerons ( almost) and use the rudder (and the elevators). When an aeroplane is slow it is VERY susceptible to gusts. STOL planes are fun, except when the winds are unpredictable and gusting. They just have too much lift..Sudddenly. Nev
Guest rocketdriver
Just a comment ... can't really see, but it looks like the prop just stopped at first strike on the ground. The one blade you can see in the second last picture appears to be undamaged? ...... When I dug mine in 6 months ago in VERY boggy ground, with the engine at idle, both blades shattered, one near the tip (the first one in) and the other closer to the root. The broken part of this one was left 6 inches underground and almost invisible, so soft was the soil. With that in mind and with the ground looking to be firm, maybe the engine had stopped producing power and the prop was just windmilling ...... If so, that wouldnt have helped!
Would the same thing happen if the throttle remained at idle for the whole incident?
Guest rocketdriver
If the engine is idling, it is producing some power and it is likely to be rotating a bit faster than a failed engine that is producing no thrust and is slowing down .... In my case the power produced and the intertia of the idling engine was sufficient to smash both blades even though the ground was soft enough for my a/c to sink below its axles ...(the reason for the overturn) ....
