stevron Posted May 17, 2012 Posted May 17, 2012 Does my 24 registered plane need a 100 hour inspection or can it be an annual inspection?
Neil_S Posted May 17, 2012 Posted May 17, 2012 Quote Does my 24 registered plane need a 100 hour inspection or can it be an annual inspection? I believe it is whichever comes first. Neil
stevron Posted May 17, 2012 Author Posted May 17, 2012 Where is it written so I can read the info. does the same rule for SAAA rules for inspection cross over to RA
facthunter Posted May 17, 2012 Posted May 17, 2012 That's how it is with a VH registered plane. whichever come first. No extensions. Nev
Louis Moore Posted May 17, 2012 Posted May 17, 2012 I thought for GA it depends on the category of the M/R, private planes can do annual inspection regardless of the hours flown (they still need the required hourly AD's yarda yards completed though).
djpacro Posted May 17, 2012 Posted May 17, 2012 Nev - Louis is correct, the period of the MR is calendar based only. Apart from ADs there are oil changes intervals (an AD mandates manufacturer's recommendations) and ....
facthunter Posted May 17, 2012 Posted May 17, 2012 That's fine. I was thinking of Oil Changes and other itens that might have an hours based servicing schedule. ( Like magnetos). There is the potential to do a lot of flying hours in a year in some operations. Nev
Louis Moore Posted May 17, 2012 Posted May 17, 2012 Yes there is, but not many people in the private category go over 100 hours. Commercial and Air work cats require the 100 hour inspection. But this is for VH aircraft, my understanding is 24 aircraft still come under the which ever is first?
facthunter Posted May 18, 2012 Posted May 18, 2012 I don't know. I guess the current techman is busy. Perhaps he should get a helper temporarily at least? He would be the one to ask. Comercial ops require an engine strip even if it has done little time at 5? years.or 10? Nev
Louis Moore Posted May 18, 2012 Posted May 18, 2012 Quote Comercial ops require an engine strip even if it has done little time at 5? years.or 10? Nev If your talking VH The commercial ops life is 12 years since last bulk strip
facthunter Posted May 18, 2012 Posted May 18, 2012 Wasn't sure of the figure but recalled there was one. Tah..... Nev
djpacro Posted May 18, 2012 Posted May 18, 2012 Quote If your talking VH The commercial ops life is 12 years since last bulk strip The AD mandates the engine manufacturer's recommendations so the figure will vary. Lycoming is 12 years. Also, it is not related to a bulk strip but to an overhaul to manufacturer's requirements.
Louis Moore Posted May 18, 2012 Posted May 18, 2012 DJ, I am talking purely about Calendar life, not time, which can be reset at bulk strip as opposed to overhaul. 1
