danny_galaga Posted March 25 Share Posted March 25 I noticed this too late for my build. My radio has a voltage display. That could have saved me some wiring. Mind you, my voltmeter is a USB port with built in voltmeter and USB seems useful nowadays. So I don't regret putting it in. Â But especially if you are building something really small and light, worth seeing if your radio, or other instrument has this function before you get a voltmeter. Â Â Â 1 Link to comment Share on other sites More sharing options...
Area-51 Posted March 25 Share Posted March 25 Be aware the usb volt meter may not read accurate; the one i installed reads a whole volt higher than actuals; confirmed with external test meter. 1 1 Link to comment Share on other sites More sharing options...
danny_galaga Posted March 25 Author Share Posted March 25 (edited) 14 minutes ago, Area-51 said: Be aware the usb volt meter may not read accurate; the one i installed reads a whole volt higher than actuals; confirmed with external test meter. Already tested before I installed. Within 0.1V of my voltmeter. The radio of course is even more accurate 🙂 Edited March 25 by danny_galaga 1 Link to comment Share on other sites More sharing options...
RFguy Posted March 25 Share Posted March 25 I was working on a plane recently , without a working voltmeter, and a USB car voltmeter plugged into the "cigarette lighter" is what we used ..... It's showing master bus voltage of course, not battery. Could be maybe half a volt different from battery voltage depending how it is wired However it does work to tell you if you are charging, or in discharge . > 13V probably charging. <13V. probably discharging. . ==13V ? wait another minute . 1 Link to comment Share on other sites More sharing options...
danny_galaga Posted March 25 Author Share Posted March 25 Totally agree, although if all the wiring is good the difference is negligible - no need to have wires going separately all the way to the battery.  Like you say, you want to know if it's charging or not. Even area 51s faulty one would be fine as long as it's consistent. Doesn't even have to read as volts.  825 bananas- battery at rest.  990 bananas- battery charging (a few minutes after start).  Over 990. Overcharging.  Somewhere between 825 990- something's going on (alternator not working fully, an unknown extra load has occurred etc). Monitor situation.  825 bananas or less in flight. No charge, battery going flat. Link to comment Share on other sites More sharing options...
kgwilson Posted March 26 Share Posted March 26 The Dynon D6 I installed in 2014 has a voltmeter built in. I only wanted a turn co-ordinator & balance ball but got a VSI, ASI, ALT, AoA, Compass, AH, & rate indicators for everything as well. Duplicates all my steam gauges. 1 Link to comment Share on other sites More sharing options...
facthunter Posted March 26 Share Posted March 26 Don't go Banana's. Just use an ammeter, Same gauge with a low impedance wire (or two) in Parallel. Reads Plus AND Minus. Nev 1 1 1 Link to comment Share on other sites More sharing options...
IBob Posted March 26 Share Posted March 26 Danny, you may want to check the current output of that USB port: I have seen an aircraft equipped with them initially, but subsequently replaced with good quality conventional USB charging ports. I can only assume either that the output was inadequate for whatever they were driving (tablet?), or that they were electrically noisy. 1 1 Link to comment Share on other sites More sharing options...
danny_galaga Posted March 27 Author Share Posted March 27 15 hours ago, IBob said: Danny, you may want to check the current output of that USB port: I have seen an aircraft equipped with them initially, but subsequently replaced with good quality conventional USB charging ports. I can only assume either that the output was inadequate for whatever they were driving (tablet?), or that they were electrically noisy. Totally agree. I was building a linear power supply for that purpose but realised mucking around with little side projects wasn't getting my plane in the air. My USB is really just for the voltmeter 😄  You know what's really dumb of me? I recently installed a battery isolator switch in the instrument panel. I put the isolator where the USB was. I had already seen I had a voltmeter in the radio some before, but completely forgot and REINSTALLED the USB next to the isolator, instead of just leaving it out 🤣  DOH! Link to comment Share on other sites More sharing options...
facthunter Posted March 27 Share Posted March 27 Those who never made a mistake never made anything. BUT" everybody makes mistakes" doesn't cut it with flying. Thats why we CHECK everything. (Boring as it might appear).  Nev 1 Link to comment Share on other sites More sharing options...
