Low aspect ratio planforms are not pitch sensitive they are generally stall proof and spin resistant, because of their inherent stability, they usually have no dihederal or anhederal to make them more sensitive in the roll plane.
I suggest that turboplanner does some research before making those generalisations.
The Arups, Milt Hatfield's Little Birds, Vought FXU5 and V173, David Rowe's UFO, Wainfan's Facetmobile - all exhibited positive stability - all were stall resistant, and all were reported as pleasurable to fly.
The Helios and other electric powered aircraft have used the tractor configuration which provides the least turbulent air into the propellers.
Unless the thrust can be vectored down, prop slipstream over the wing from the front is the best way to use the wing shape to increase lift, low aspect aircraft have wide chords and therefore large reynolds numbers, the same circulation over a wide chord gives a proportionall greater increase in lift.
