Lyndon
Everything posted by Lyndon
  1. I will do all that. But the battery. What is the advantage of fitting in the rear. I'm thinking lithium ion in where the kit suggests. ???
  2. Probably not as much as I'm asking. Lyndon
  3. One question. Button up the fuse. Nothing I need to do. Eg cables wiring. ??? All can be done easily afterwards. ??? Lyndon
  4. Happy with it. Time to relax now. One question. Seems to make sense to leave one side off and rivet up three sides. For acces etc. But I'm guessing the answer is get all four clecoed then rivet.
  5. From what I know and have leant. Taking in mind I have just started mine. Take your time. Read the manual and ask lots of questions. Reason being every time you make a mistake and have to un pick rivets you compromise the hole. Be careful. Very careful. Does not matter how good you are they don't like being drilled out. Believe me I'm an expert I've drilled out lots. Lyndon
  6. I'm no expert but all the time is in preparation. Eg getting it ready for primer. It's a lot of work. It makes a nice job if go this way. Remember don't prime painted surfaces as prime to top coat has as 36 hour window. So you will be priming on primer. Weight is not good. Depends on what you use but wet on wet will eliminate sanding the primer. Lyndon
  7. Did you rub it flat dry or wet. Two pack rub it dry with a much corser paper than say acrylic. Should rub easy as. Two pack can be painted with much corser prep work Lyndon
  8. My. Two cents. You can't paint without keying it. I used Brown 3m about 300 quite corse. Easy fast leaves a great key. Six hrs before painting wipe with metho. Use a two pack. finish is superb. I use a 1 mm nozzle hvlp touch up gun. Perfect for 90 percent and a little slow on the big stuff. Fine finish and you can keep the primer to minimum. Going to all that trouble worth another 5 mins work with two pack Just be careful not to loose your part numbers. Lyndon
  9. Makes sense. Thanks Lyndon
  10. Outer. Angles ??? Meaning the four corner longerons ???
  11. Gunna have a go at mocking up the fuselage skins today on the ribs. Looks awkward. Any tips. Thanks Lyndon
  12. Yep I have already fitted a5 rivets . Found that out pretty much on the first one Thanks Lyndon
  13. Sorted. Thanks two points in front of the three ribs. Lyndon
  14. Thanks. Looks like number four block goes in between the ribs and the control longeron. Will have another look. Lyndon
  15. Then I seem to have one block left over. I have five of them. ??
  16. Ribs ??? A question. Manual is a little vague. On the cables. One nylon block on the rear of each rib. 4 5 and 6. The a block on both sides of the longeron ??? Thanks Lyndon
  17. Fantastic. Lazy using the net but for me to get that answer from manual would take a week. Thanks Lyndon
  18. Outer Aldrin ???. I take it this is drilled when fitting on the wings. My manual shows a hole in it to bolt to the inner aleron ??? Thanks Lyndon
  19. This way I think ??
  20. Thanks. Save me trying to figure it out.
  21. No worries. Cup of tea and I will have another look. If not A 4 will be fine ??? I read and if I'm correct. The alerons are staggered 16 mm. Eg not in line when fitted to the wings ??? Lyndon
  22. I'm doing the alerons. The tip looks like it's done with a3 rivets. Can't seem to find them anywhere. Am I missing something or is it just a matter of getting some rivets. If so are these the only parts that require them so I know what quantity to get. Lyndon
  23. Reg has advised it happens. Counter sunk rivets is the fix. I have also gently with a block of wood taken another 1mm of the leading edge in the middle. All good now. Thanks Lyndon
  24. A better pic. You can see the leading edge to. Sharp as there in no rib. This makes it protrude Lyndon
  25. Leading edge of the elevator is not straight. No ribs in in the center so on the edge it's wide and in the center it's not as wide thus its about a 4 mm woof. A fix anyone ??? Lyndon
