IBob
Everything posted by IBob
  1. I'm confident in what I write about fitting running and maintaining the 912 (though always more to learn there too). I know nothing about the 0-200 other than what I can dredge up online. I don't know enough to be running comparisons.
  2. Yes. I'm not thinking straight there............(
  3. I saw the 0-200 quoted at 22L/hr at 75% but perhaps that figure was wrong?
  4. Thanks RFGuy, yes that post is 9 years old, what you say seems to sum it up as we stand now. To which I would add the estimated NZ$27,000 fuels saving that is 5L per hr over 2000hrs. Mark is certainly making a nice job of the alternative throttle linkage. And quite possibly others face challenges that I don't, and so will benefit from that.
  5. And........that was met by a deafening silence.......) Here is someone operates both an 0-200 and 912: https://www.rotax-owner.com/en/912-914-technical-questions/4678-o-200-vs-rotax-912-costs Second post down: "As for balancing the carbs, most of the the problems I've run into are not with the carbs but with improperly installed or poorly maintained throttle cable systems. I check my carb balance at every annual but haven't had to adjust them in two years." As for the 0-200 vs 912 question, he loves them both, but wonders if the 912 may require overhaul sooner.
  6. continued................ The rest has been very straightforward: Pretty much the only synchronisation tool you have is adjusting the relative length of those cables. So I did this: 1. First checked idle stop and idle jet settings as per the LM manual. This is quick and easy, and as noted the idle jet settings were only approximate, so worth doing. 2. With everything in place, I cut and fitted a stop block at the firewall: when the throttles are fully closed, the spare central lever on the throttle bar bottoms on this block. This prevents the carb throttle arms, which are light in construction, from being flexed or bent, upsetting adjustment, if the throttles are closed firmly (as you do when stopping the engine). 3. I reasoned that since the engine spends much of it's time at 75% power or above, this was where I wanted best synchronisation. So I push the throttle knob to fully open, this puts some slack in the cables. I then gradually close the throttle, watching the two throttle arms to see them both start to move off their stops simultaneously. This required several small cable adjustments in the first 40hrs, but in the 200hrs since, while I run this simple check regularly, I have not had to touch it. Surprisingly also, given the different cable lengths, the fully closed appears to be pretty much perfectly synchronised too. And that's it. I inspect all this carefully at service intervals, and lubricate the cables with light oil (I'm not sure about that, but it seems to be working okay in this environment.)
  7. Hi Yenn, a certain amount of it was in understanding what was in the kit, and working with that for best results, so bear with me if I go there first: The Savannah has a throttle bar across the width of the firewall, with arms connected to L and R throttle knobs, and with a pair of arms or quadrants side by side at the LH end that operate a pair of bowden cables. The short LH cable goes to the LH carb, the longer RH cable to the RH carb. I would guess this is a fairly common setup. Note that this is very positive when closing the throttle and the cables are being pulled, but when opening the throttle the cables are not pushed: they rely on the carb throttle arm springs to draw the cables. So for this to work well there can be no binding in the cables. Accordingly, I went to some trouble to ensure that all parts of this setup were well aligned and free moving. Also in the case of the RH cable, I was very careful to install it with sweeping curves so as to minimise cable friction. And for the LH cable I ensured there was a small but sufficient amount of curve in the outer to allow the engine to move on the mounts. I was greatly helped in all this by a series of pics supplied by the then Australia agent, Reg Brost, which proved to be gold when it came to making a tidy engine instal. Here is a pic of the cables coming off the throttle bar, they are the lower cables: And a pic of the engine bay showing the routing of the cables to the carbs: Note I have since seen a factory build where they do an even nicer job of curving that RH carb cable: they fit a little cable fastening near the top LH side of the airbox front, which makes for an even softer curve. continued below..............
  8. Hardly, Nev: I responded to each of the items you raised, including acknowledging the matter of carb floats. You want more detail????
  9. Let's see: 1. Balancing the carbs: adjusted the cables as they bedded in to synchronise movement at full throttle. No further adjustment required for last 150+hrs. 2. Bowl breather tube: piped to airbox downstream of air filter, job done. 3. Carb floats. Yep they definitely had issues there, I have replaced one set as directed and supplied FOC. 4. Carb to manifold rubbers. Swap 'em out when the time comes, or maybe you don't believe in periodic maintenance? 5. Gearbox service and sprag clutch. I expect no issues at all as I use unleaded fuel as recommended, and the more recent ignition units give excellent starting. 6. Throttle linkage? Mine works fine. 7. Not sure what your problem is with the alternator. Is there a problem with the alternator? 8. Oil return system: it works fine. Surely that is a the measure of a good machine: not all the theory, but how well does it work??? 9. Starting and stopping technique: simple. Okay Nev, you don't LIKE the 912, it offends your sensibilities, I guess. You're entitled to that. FWIW I'm ambivalent about the 0-200.
  10. I'm not following you there, Facthunter. The 912 as I know it doesn't require any fiddling at all. I just open the throttle, the prop is pitched about right and I put the carb heat on as required. Otherwise, it takes care of itself in all modes of flight and requires no fiddling at all, in flight or on the ground. I do blank off a bit of radiator in winter, to get the oil temp up. And I take an interest in how it all works.
  11. Facthunter, I don't disagree with your theory, in any respect. But I do read much of what is written here, and what I don't see is any undue pattern of weakness or failure for the 912. It is what it is: not the 'perfect' engine, not ideal for everything and everyone. But for the slot it does fill it seems to me to function remarkably well, and especially so since the designers grasped the nettle of liquid cooled heads and high engine speed, securing many benefits, but also complicating the design.
  12. I'm sure you're right Nev. But I'm left with the thought that, for an engine with so many design shortcomings.....it works remarkably well....)
  13. Earlier in this thread, I made a reference to troubleshooting Rotax problems by finding what had changed since the factory, then putting things back as per the factory build. I need to qualify that: It has been pointed out to me that variations in third party exhaust systems etc on the Rotax engine may affect carburettor performance, and that adjustments to the jetting, properly carried out, may offer a workable solution to that.
  14. Glen, I've just come to accept that my plugs look awful after a home taxi (and to that I should add most of the finals of the landing, since the Sav uses very little power if you're wanting it to land). But must be working fine at other power settings, since it runs so smoothly and never misses a beat (well, okay, one cough once, travelling just under cloud base without carb heat on). Add to that I ran the first set of plugs for almost 200hrs (as per the LM Manual, though some change them every 100). If it works, don't fix it??? With the Jab, I can see where LCHs could result in a number of changes...as you point out. Is there history from other users you can draw on? My 912 has no EGTs. It has the standard coolant temperatures on 2 and 3 (LHfront and RHrear), Rotax used to do CHT but moved to the coolant. I would think temperatures are very location specific, so would expect comparisons between different engine types to be worthless.
  15. Glen, I know nothing about Jabiru engines, and just a bit about the Rotax 912 since I own and maintain one, so have a particular interest there. I do understand the importance of the float bowl vent, as providing appropriate float bowl pressure (in the Sav the vent/s are plumbed into the airbox downstream of the filter, which makes sense). I am fortunate that my enrichment (aka choke) has a free action, and shuts positively as soon as released. I hadn't thought about carb heat, but try not to make that a set and forget thing: I can set various degrees of that, so tend to return and adjust it when in use. Having said all that, it is perhaps 800m of taxiing from touchdown to my hangar and any time I have pulled the plugs they look very rich. However, my fuel consumption is certainly not excessive and the thing has run like a dream from new, so I have just assumed that the Bing setup runs rich near idle. You say the Jabiru was about right, now rich after LCH? I'm not quite sure what you mean there???
  16. All the best with that Kgwilson. And I wasn't referring to any post you may have made.
  17. Before moving onto Holden........I would like to say how much I like the Rainbow Aviation approach to troubleshooting Rotax engines, as set out in their excellent carburettor functional descriptions in the links posted above. They take a 2 step approach: 1. Find out what has changed since the engine came from the factory. 2. Put it back to how it was when it left the factory. Which might sound glib or simplistic, but not so long ago we had someone in another thread here experiencing erratic or rough running problems. And when last reported, they were off to alter the carb needle settings...........(
  18. That article referencing the Australian dark sky takeoff accidents study makes for sobering reading: "Interestingly enough, investigators found that in every case the doomed aircraft struck the ground within 3 nm of the airport, and within one minute of becoming airborne. In 87 percent of the crashes, the aircraft impacted to one side of the extended centerline with wings showing little or no bank at the time of impact. In every crash, the wreckage indicated that the aircraft was under control at the time of impact. Specifically, the investigators noted that the aircraft damage was consistent with the pilot being unaware of any unusual attitude."
  19. RFGuy them's the numbers........however with that fat wing and various other gear hanging out in the breeze, the reality is you'd need to be doing something well past radical to reach 124kts. As most owners will agree, the Sav is happy at about 85kts. Anything much above that and there is very much the sense that you are pushing it..........)
  20. Skippy, I think part of the problem is that we label this particular control as a choke, because that's the sort of function it performs, and that's how we are used to thinking of it. And I am no different: mine is labelled 'choke'. But as others have stated here: 1. It is actually a starting carburettor. 2. The throttle also needs to be fully closed for it to function (because it is this full closing of the throttle that provides the necessary 'choking'.) Here is mine.....labelled choke:
  21. Skippy, here are two excellent detailed writeups, with illustrations, on the Bing64. The first covers the operation of the main carburettor. The second covers the operation of the starting carburettor. https://electricmotorglider.com/2017/02/01/bing-64-cv-carburetor-part-1/ https://electricmotorglider.com/2017/03/01/bing-64-cv-carburetor-starting-carb-part-2/
  22. Go for it, Gary......and don't forget to post pics of air under the wheels.......)
  23. The story does just seems to get worse. As for nobody speaking out: I have wondered if it might in part be a reluctance to be the first to speak out. I was thinking of the famous B52 crash, where the pilot had been variously bending and breaking the rules for years, but nobody (apart from one man who died with him) was prepared to do anything about it. Ridiculous as it seems, maybe it's a sort of male gungho chicken thing, where speaking up is chickening out.......(
  24. It certainly works very well for me, RFguy: in 230+hrs the only time I have not had near instantaneous and smooth starts, was due to stale fuel after lengthy Covid lockdown. So much so that if I ever start to get less clean starts, I will be looking for the problem. Further to all this: a while back, someone posted a link to a very good video on this carburettor. I did watch it, but cannot now recall where it was. Anyone???
  25. I suppose we are all talking about the same carburettor here: the Bing 32???
