deadstick Posted July 6, 2014 Posted July 6, 2014 Motz, any chance you could reuqest a few pics of the thru bolt and nut config as well as the barrel base flanges pleae? The latest config barrels have a thicker flange and the thru bolts are larger to stop this, so if its latest spec I am now worried about my planes all over again or should I say more.
Dafydd Llewellyn Posted July 6, 2014 Posted July 6, 2014 Quote Motz,any chance you could reuqest a few pics of the thru bolt and nut config as well as the barrel base flanges pleae? The latest config barrels have a thicker flange and the thru bolts are larger to stop this, so if its latest spec I am now worried about my planes all over again or should I say more. Are you confusing the new CAMIT barrels with Jabiru barrels? The CAMIT barrels certainly do have larger through bolts, a thicker flange and a thicker barrel wall in the vicinity of the flange. Dunno about the "latest" Jabiru barrels - that engine cannot have had the new CAMIT barrels.
motzartmerv Posted July 6, 2014 Posted July 6, 2014 Are cammit parts aloud to be fitted to be fitted to type certified Jabs?
Dafydd Llewellyn Posted July 7, 2014 Posted July 7, 2014 Not yet; I understand that considerable effort is happening to get the approval to do so.
motzartmerv Posted July 7, 2014 Posted July 7, 2014 Well, that answers the question. The aeroplane was a 24 regod training aeroplane. It could only be Jab parts.
Teckair Posted July 7, 2014 Posted July 7, 2014 Quote Well, that answers the question. The aeroplane was a 24 regod training aeroplane. It could only be Jab parts. Maybe?
deadstick Posted July 7, 2014 Posted July 7, 2014 Quote Are you confusing the new CAMIT barrels with Jabiru barrels? The CAMIT barrels certainly do have larger through bolts, a thicker flange and a thicker barrel wall in the vicinity of the flange. Dunno about the "latest" Jabiru barrels - that engine cannot have had the new CAMIT barrels. Hey Dafydd, the roller cam engine in my 230 looks to have the larger flanges? may be a visual illusion but I will measure them and see.
deadstick Posted July 7, 2014 Posted July 7, 2014 Hmmm, this is a grey area it seem's as there is confusion in the industry at the moment surrounding the fitment of Cammit parts sourced through them not jabiru, on CASA type certified aircraft. Advice that I received from CASA listed, design engineers was that yes the same part number components can be fitted to C model 24 registered Jabiru's. Info from 2 independent sources however only verbal and not written. 1
Dafydd Llewellyn Posted July 7, 2014 Posted July 7, 2014 I'm not the authoritative source of information on this; but my understanding is that if it has the Jabiru part number, it's not the revised CAMIT design. CAMIT makes Jabiru parts, to Jabiru's design, under Jabiru's Production certificate, which means - as I understand it - that only Jabiru can issue release notes for them. CAMIT has its own Production Certificate, but it's under CASR 21.133(2B), which means the parts made under that PC have to be ordered on a "one off" basis - that was how it was done for the Blanik life-extension parts kits. There is a lot to do to extend this to parts for general supply.
storchy neil Posted July 7, 2014 Posted July 7, 2014 first hand knowledge you can source parts from any where for 24 reg aircraft neil 1
Teckair Posted July 7, 2014 Posted July 7, 2014 Quote first hand knowledge you can source parts from any where for 24 reg aircraft neil Yeah you can but it won't be legal. 2
storchy neil Posted July 7, 2014 Posted July 7, 2014 yeh deadstick get them to put it in writing neil 1
