Russ Posted January 4, 2016 Share Posted January 4, 2016 jab160.........wooden prop, anyone have a balancer that REALLY works. Would like to pay for the use. russ 1 Link to comment Share on other sites More sharing options...
Kyle Communications Posted January 4, 2016 Share Posted January 4, 2016 I have a Dynavibe ...and it really works I gather you have been reading the latest Sport Pilot mag Link to comment Share on other sites More sharing options...
M61A1 Posted January 10, 2016 Share Posted January 10, 2016 Mark's dynavibe works well. Well enough for me to consider buying my own. While researching, I found a device called a Balance Master, I was sceptical, but after looking it's operation, saw that it works on the same principle as the bifilar weights on a Blackhawk rotor head. I purchased one from the US and was pleasantly surprised at just how well it works. Link to comment Share on other sites More sharing options...
maulonir Posted January 11, 2016 Share Posted January 11, 2016 Russ, Lloyd with the RV6 at Mundoo has a Dynavibe type balancer. I can pass on his Ph number if you don't already have it. Cheers Rob 1 Link to comment Share on other sites More sharing options...
Yenn Posted January 11, 2016 Share Posted January 11, 2016 Are these balancers something you put on the plane to balance out vibrations or are they a means of static or dynamic balancing of the actual prop? Link to comment Share on other sites More sharing options...
M61A1 Posted January 11, 2016 Share Posted January 11, 2016 https://www.balancemasters.com/ultralights/index.html This is a link to the manufacturer, I got mine fro aircraft spruce. they are bolted between the prop and flange (also available for engine flywheel) I was sceptical, but found that it works better than I ever thought it would. I have used the Dynavibe with good result. There is also an Australian dynamic balancer supplier, Vibrotech, the Model 1015 is about the cheapest you will find. The electronic Dynamic Balancers are fitted to the engine, and have an accelerometer and a sensor (usually optical) to determine position of the balance. they are fitted temporarily for balancing and removed when good balance is achieved. Link to comment Share on other sites More sharing options...
Russ Posted January 11, 2016 Author Share Posted January 11, 2016 Russ,Lloyd with the RV6 at Mundoo has a Dynavibe type balancer. I can pass on his Ph number if you don't already have it. Cheers Rob appreciate that........thanks Link to comment Share on other sites More sharing options...
Russ Posted January 11, 2016 Author Share Posted January 11, 2016 I have a Dynavibe ...and it really works I gather you have been reading the latest Sport Pilot mag actually.....no. I like to give it a "refresh" every yr. ( sand / relaquer) and have flooked a "balanced" prop each time. Spray same speed, same coatings both blades. Other jab owners have commented how smooth my jab runs..........but "luck" can't keep happining for me. 1 Link to comment Share on other sites More sharing options...
