Stoj Posted March 5, 2017 Posted March 5, 2017 So first I should apologise for such a late build thread. I've been building a Savannah XL for a little while now. I figured there were a few build threads going, so I was a bit slack with posting. But I guess the build took a change in direction with the decision to go with the 912iS injected engine. This was due to a bunch of different reasons, cost, safety and cool gadgety stuff. And you've gotta love the fuel burn they can achieve and the extended range (I plan on doing lots of cross country trips) The engine is also coupled with the Dynon system and autopilot. I come from and electrical and instrumentation background, so all that stuff appeals to me. Noticed there wasn't much info from people that had installed the injected engine, but also a bit of misinformation and scepticism. So I thought I'd do a thread if anyone is interested with installing the injected 912iS engine and possibly answer queries about it that might help. Cheers, Lee 3
rick morawski Posted March 5, 2017 Posted March 5, 2017 Quote So first I should apologise for such a late build thread. I've been building a Savannah XL for a little while now.I figured there were a few build threads going, so I was a bit slack with posting. But I guess the build took a change in direction with the decision to go with the 912iS injected engine. This was due to a bunch of different reasons, cost, safety and cool gadgety stuff. And you've gotta love the fuel burn they can achieve and the extended range (I plan on doing lots of cross country trips) The engine is also coupled with the Dynon system and autopilot. I come from and electrical and instrumentation background, so all that stuff appeals to me. Noticed there wasn't much info from people that had installed the injected engine, but also a bit of misinformation and scepticism. So I thought I'd do a thread if anyone is interested with installing the injected 912iS engine and possibly answer queries about it that might help. Cheers, Lee Bring it on, I'm drooling for more photos.
eightyknots Posted March 6, 2017 Posted March 6, 2017 Quote Here you go Nice Stoj. I wonder if you're the only Savannah owner Down Under who has a fuel injected engine? I would love a fuel injected Rotax too but they are really pricy so I won't even consider it .
Stoj Posted March 6, 2017 Author Posted March 6, 2017 Quote Nice Stoj. I wonder if you're the only Savannah owner Down Under who has a fuel injected engine?I would love a fuel injected Rotax too but they are really pricy so I won't even consider it . I believe there is one other out there, that I know of. Totally understand the price can put people off. I changed my mind back and forth a dozen times, but couldn't be happier I went with the iS. However there are a couple modifications to make, and I wondered whether I had bitten off more than I could handle. Nothing too difficult in hindsight, and figuring things out for the first time was all part of the fun. 1
rankamateur Posted March 6, 2017 Posted March 6, 2017 Did it fit in the supplied ring mount or did you have to come up with a different mount? How much will you need to butcher the cowling? 1
Stoj Posted March 6, 2017 Author Posted March 6, 2017 Quote Did it fit in the supplied ring mount or did you have to come up with a different mount? How much will you need to butcher the cowling? The iS came on its own ring mount already fitted, which was identical to the supplied one in the kit, except it had 11mm holes that the mounting bolts went through. I had an engineering shop make some sleeves to suit, which cost a carton of beer. As for the cowlings, a fair bit. Mostly due to the exhaust. Top cowling is straight forward, remove air intake scoop and fibreglass. Bottom cowling required shifting the bottom cutout forward to accomodate the muffler. Also a bit of cutting/widening around the scoop for the radiator, as it sits differently due to the exhaust. Also made up some stainless radiator hoses, because I was concerned about how close the exhaust pipes would be to rubber hoses
Downunder Posted March 6, 2017 Posted March 6, 2017 Nice looking engine and setup. Noticed the radiator pipes straight away. Being metal, I'm wondering if they will draw heat into the coolant from the exhaust? Awsome looking oil cooler there too!!! I spotted the MOCAL sticker. They have some nice stuff on their site.....Do they (the injected rotax) come with an oil thermostat as standard?
Stoj Posted March 6, 2017 Author Posted March 6, 2017 Quote Nice looking engine and setup.Noticed the radiator pipes straight away. Being metal, I'm wondering if they will draw heat into the coolant from the exhaust? Awsome looking oil cooler there too!!! I spotted the MOCAL sticker. They have some nice stuff on their site.....Do they (the injected rotax) come with an oil thermostat as standard? I couldn't imagine much heat being drawn in. The exhaust pipes sit a little wider than the uls engine. So the pipes sit close just where the coolent inlet/outlet is to the radiator. Plenty of air flow around the rest. The oil cooler is standard, but doesn't come with a oil thermostat. Although I did consider one as per attached pic. Thought these were a great design, simple and less hoses
IBob Posted March 7, 2017 Posted March 7, 2017 Any particular reason you decided against an oil thermostat?
Downunder Posted March 7, 2017 Posted March 7, 2017 Interesting that it is a standard rotax oil cooler. Looks so much bigger than the 912 uls one. I really thought a thermostat would have been standard on the iS.....
Kyle Communications Posted March 7, 2017 Posted March 7, 2017 Graham up in Ayr has a 912IS flying I think GuyS has one as well but not sure about that Where is your Sav Stoj?
Stoj Posted March 7, 2017 Author Posted March 7, 2017 Quote Any particular reason you decided against an oil thermostat? I'm not against an oil thermostat, I think I might even end up putting one on there eventually. Keeping the oil at optimum temp can only mean good things for engine life and performance. I'll see how I go with the silver tape first. Would be good to know people's experiences with oil thermostats. And yes, you would think for all those dollars they would include it with the engine :)
rick morawski Posted March 7, 2017 Posted March 7, 2017 I did a lot of research into oil thermostats on 912 and most people who put one on found little or no benefit. So I decided not to bother putting one in myself. Then had a guy ask me to install one for him. I told him about my research but he insisted so I installed one for him and yes indeed made little or no difference to warm up time. Just my $.02 worth 2 1 2
Stoj Posted March 7, 2017 Author Posted March 7, 2017 Quote Graham up in Ayr has a 912IS flyingI think GuyS has one as well but not sure about that Where is your Sav Stoj? Ah yes, thats the one. Bill told me about Grahams. Sav will be based out of Caboolture. Should be flying in 2 weeks
rankamateur Posted March 7, 2017 Posted March 7, 2017 There is one in a foxbat out at Alpha, haven't heard anything bad about it. If you are having an electronic dash the extra cost is less of a problem. The rotax instruments were $3500 when I looked into it and that would nearly have made a 914 cheaper at that time.
Stoj Posted March 7, 2017 Author Posted March 7, 2017 Quote I did a lot of research into oil thermostats on 912 and most people who put one on found little or no benefit. So I decided not to bother putting one in myself. Then had a guy ask me to install one for him. I told him about my research but he insisted so I installed one for him and yes indeed made little or no difference to warm up time.Just my $.02 worth Yep, I had read the same thing. I'm not so concerned with warm up times, but more with maintaining good temperatures on descent, or higher altitudes in winter for example.
Stoj Posted March 7, 2017 Author Posted March 7, 2017 Quote There is one in a foxbat out at Alpha, haven't heard anything bad about it. If you are having an electronic dash the extra cost is less of a problem. The rotax instruments were $3500 when I looked into it and that would nearly have made a 914 cheaper at that time. Yeah I think if your going with the iS, you would go with the electronic dash. Its pretty much just 2 wires from the ECU to the EMS module, so you get things like voice alerts as soon as you exceed parameters, throttle position indication for easier starts, rich/lean mode, and adaptive gauges for the tachometer with regards to oil temp, fuel computer etc. Pretty handy that the iS comes with all these engine sensors built in too.
Kyle Communications Posted March 7, 2017 Posted March 7, 2017 Quote Sav will be based out of Caboolture. Should be flying in 2 weeks Excellent another Sav at Ycab... I am in Hangar 91 drop in and say hi. I take it you will be in one of the new hangars behind me
Kyle Communications Posted March 7, 2017 Posted March 7, 2017 I have a water thermostat I fitted..its pretty good. I am up to temp by the time I finish my taxi to 12
Kyle Communications Posted March 7, 2017 Posted March 7, 2017 Was speaking to Graham earlier this week. He did say he had a few teething problems and yes it does speak to you. He has a nagging fuel pressure alarm that keeps coming up and annoying him. Graham also has a Dynon with his. Could be worth having a chat to him
Stoj Posted March 7, 2017 Author Posted March 7, 2017 Quote Was speaking to Graham earlier this week. He did say he had a few teething problems and yes it does speak to you. He has a nagging fuel pressure alarm that keeps coming up and annoying him. Graham also has a Dynon with his. Could be worth having a chat to him Great I'll keep an eye out and swing by. Yeah I'll be in one of the new ones, 204. I'll have to look into the water thermostat. I believe Rotax have done a few updates and improvements along the way to the ECU, airbox, fuel filter and a couple other things. They also recommend a 'limited flow bypass' on the fuel system. So far so good, engine runs perfectly.
Kyle Communications Posted March 8, 2017 Posted March 8, 2017 Have you been building it at Bill's place?
Stoj Posted March 8, 2017 Author Posted March 8, 2017 Quote Have you been building it at Bill's place? Yeah been there finishing it off, he's been a tremendous help, especially with working his magic on the cowling
Kyle Communications Posted March 8, 2017 Posted March 8, 2017 Are you going to fly it out of there for the first flight?....or should I say will Bill fly it out of there? Got to be a good pilot to get in and out of Bills
