Richard Budge Posted December 28, 2017 Share Posted December 28, 2017 Does anyone needs a custom made panel. I have the tools, the knowledge and the experience to custom make your panel. This particular dash doesn't have the lower section that most do making it a tiny bit smaller. This panel featured an iPad Mini with the Guardian rear mount (the best on the market) iPad slides right in and locks. I can wire up all your gauges and dash lights, switches and fuses. You can supply or I can supply. Same with the avionics. Just let me know if there is any interest. I only have the template for the Jabiru dash panel or if you're upgrading, I can trace around your old panel. 2 Link to comment Share on other sites More sharing options...
Kyle Communications Posted December 28, 2017 Share Posted December 28, 2017 Richard I gather you have a flatbed router and a vacuum table?..or are you using clamps.....could be a laser too i suppose...but they are really expensive Link to comment Share on other sites More sharing options...
bexrbetter Posted December 28, 2017 Share Posted December 28, 2017 ...could be a laser too i suppose... Dat ane no laser. 1 Link to comment Share on other sites More sharing options...
Richard Budge Posted December 28, 2017 Author Share Posted December 28, 2017 RichardI gather you have a flatbed router and a vacuum table?..or are you using clamps.....could be a laser too i suppose...but they are really expensive i there, no, nothing so fancy. I do have a punch & die set that is a special aviation tool. It's cut through the exact size for either 3 1/8" or 2 1/4" inch perfectly formed holes. I also have a steel template, again exactly sized for the gauge mounting holes. I am an auto-electrnctian so the wiring in no particular problem. Richard. 2 Link to comment Share on other sites More sharing options...
fly_tornado Posted December 28, 2017 Share Posted December 28, 2017 probably need some detail shots so that people can see your craft Link to comment Share on other sites More sharing options...
Keith Page Posted December 29, 2017 Share Posted December 29, 2017 Does anyone needs a custom made panel. I have the tools, the knowledge and the experience to custom make your panel. This particular dash doesn't have the lower section that most do making it a tiny bit smaller. This panel featured an iPad Mini with the Guardian rear mount (the best on the market) iPad slides right in and locks. I can wire up all your gauges and dash lights, switches and fuses. You can supply or I can supply. Same with the avionics. Just let me know if there is any interest. I only have the template for the Jabiru dash panel or if you're upgrading, I can trace around your old panel. Have you looked at the Mini Levil AHRS? They will connect to the IPad by blue tooth and they work a treat. Transponders are wired to the AHRS and the blue tooth from there. All instruments -that is - flight and engine even the upmarket extra instruments e.g. DG & AH. 1 Link to comment Share on other sites More sharing options...
jetjr Posted December 30, 2017 Share Posted December 30, 2017 I know an owner of the ipad/Levil setup who isn’t very happy Not sure of details Link to comment Share on other sites More sharing options...
Kyle Communications Posted December 30, 2017 Share Posted December 30, 2017 Interesting Jet......can you find out what the issues are? whether its the Ilevel or the Ipad? In April when the BOM is ready I am pretty sure I am going to get one Link to comment Share on other sites More sharing options...
harrison Posted January 1, 2018 Share Posted January 1, 2018 Does anyone needs a custom made panel. I have the tools, the knowledge and the experience to custom make your panel. This particular dash doesn't have the lower section that most do making it a tiny bit smaller. This panel featured an iPad Mini with the Guardian rear mount (the best on the market) iPad slides right in and locks. I can wire up all your gauges and dash lights, switches and fuses. You can supply or I can supply. Same with the avionics. Just let me know if there is any interest. I only have the template for the Jabiru dash panel or if you're upgrading, I can trace around your old panel. [ Just noticed your post I have a Jab SP 6 with a pretty crappy instrument panel. Let me know if what you make will fit this Jab.Its 19 registered. You can get me on 0412763784 anytime Thanks. Rob Link to comment Share on other sites More sharing options...
