What are people using for rotax 912 instruments?
danny_galaga
I was thinking of using VDO as they are reasonably priced and for me having used to be an auto electrician they are a known quality. However I like the idea of having ‘green’ bands on the gauges and I see there is this alternative 2” gauge brand
UL FLIGHT LINE 2 INCH OIL TEMPERATURE GAUGE from Aircraft Spruce
Anyone used these? Or in 2.25” is aviasport which is getting a bit pricier...
I have mainly Speco brand engine gauges - very happy with performance & price.
Regarding coloured operating bands - with care & ingenuity it is possible to open/close the gauges and stick your own bands in place.
When I built the Nynja, I used the Avia Sport instruments. I'm not sure if they're still in business though.
Agree with Scott plus you can wire in warning lights. I saw scott had done this and did the same, very easy. Off when in the green band, blink when in yellow band & constant light for red band. Good for getting attention. Cheers
I used all VDO when I built the Alpi - good quality and reliable ( and cheap)! Easy enough to mark the gauges with coloured strips
I guess I should have mentioned - my Speco's are all 18 years of age & Hobb 850 hrs plus, with the exception of the oil pressure, which I replaced (both gauge & sender) two months ago. So reliability speaks for itself and they are much cheaper than VDO.
My 912 engine & related gauges are:
Speco: Oil temp. Oil Pressure. Head temp (x 2 switch). Volts. Fuel Pressure. Fuel level.
VDO: Manifold vacuum (for fun)
Other: EGT (unknown brand)
Fuel flow/usage: MiZer (not very consistent)
Talking of lighting is there any point wiring up the back lighting on the gauges if the air craft is going to be VFR only? Might as well save a little weight and time if I can!
Not just weight - Complexity - Why add more potential for failure??
