Downunder Posted February 9, 2015 Share Posted February 9, 2015 Link to comment Share on other sites More sharing options...
Deskpilot Posted February 9, 2015 Share Posted February 9, 2015 NASTY Link to comment Share on other sites More sharing options...
facthunter Posted February 10, 2015 Share Posted February 10, 2015 If it doesn't scare you it should. Nev 3 Link to comment Share on other sites More sharing options...
Guernsey Posted February 10, 2015 Share Posted February 10, 2015 It certainly had my heart fluttering. Link to comment Share on other sites More sharing options...
Geoff13 Posted February 10, 2015 Share Posted February 10, 2015 OK I keep hearing about this. What causes it and what is the solution? Link to comment Share on other sites More sharing options...
ayavner Posted February 10, 2015 Share Posted February 10, 2015 looks like it could fly apart at any time! How does it feel, and what would you do about it! The aircraft in question seemed like it was fully under control, what would the pilot have been sensing there? Link to comment Share on other sites More sharing options...
SDQDI Posted February 10, 2015 Share Posted February 10, 2015 1 1 Link to comment Share on other sites More sharing options...
SDQDI Posted February 10, 2015 Share Posted February 10, 2015 That video will explain it a little. Also a good reason to not exceed VNE Link to comment Share on other sites More sharing options...
facthunter Posted February 14, 2015 Share Posted February 14, 2015 I couldn't open the second vid. The faster your plane flys the more you have to try to prevent flutter by designing it properly It's because the structure flexes and there are things like harmonics. The Lockheed Electra airliners lost about 3 aircraft before some one saw one go down because the wing detached due to twisting. Eventually they found the Allison engines were dropping because the engine mounts allowed movement when they deteriorated in service. It was taking less than a second to do this when it starts. The critical speed was not the highest speed it was allowed to fly at. Mass balancing of critical control surfaces is the usual way of dealing with it in our area of aviation, but it can be a bit like a flag flapping. I wouldn't like to see some trim tabs lose their linkages either. Slackness in controls is to be avoided too. Nev 3 Link to comment Share on other sites More sharing options...
rgmwa Posted February 14, 2015 Share Posted February 14, 2015 Here's a link to an article written by former Vans Aircraft aeronautical engineer, Ken Krueger, that includes a discussion on flutter, among other things. It's written in the context of RV's, but the principles apply to all aircraft. https://www.vansaircraft.com/pdf/hp_limts.pdf If you can find a copy of the Sept 2014 Kiplanes magazine, there's an excellent article by Barnaby Wainfan, another aeronautical engineer, on Critical Flutter Airspeed. http://www.kitplanes.com/issues/27_3/designers_notebook/Structural_origins_of_flutter_9130-1.html Theodore Von Karmen, who was a famous aerodynamics theoretician once said, "Some fear flutter because they do not understand it, and others fear it because they do." rgmwa 1 Link to comment Share on other sites More sharing options...
