Bruce Tuncks Posted April 28, 2020 Share Posted April 28, 2020 I'd like to make up a spares pack of nuts, bolts, washers, split pins and whatever else might be useful. There is no point in carrying things which will never be used, so standard assortment packs are not much good. I'll get things started by listing: AN 3 nyloc nuts - 20 only AN4 nyloc nuts - 20 only AN3 thin washers -10 only AN3 thick washers - 10 only AN4 thin washers -10 only AN4 thick washers 10 only AN5 thick washers 5 only Bolts: AN3 AN4 AN5 Split pins: Bushes: ( the ones used on the flaps , they are AN3 bore and just cut from a tube. I reckon better brass ones if they can be found ) ??? Other suggestions welcome, comments too. Link to post Share on other sites
Yenn Posted April 29, 2020 Share Posted April 29, 2020 Why do you need washers as spares, surely the old ones would still be perfectly good. Link to post Share on other sites
facthunter Posted April 29, 2020 Share Posted April 29, 2020 Brass is not a good bush material. (Copper -zinc) and it doesn't wear well and isn't reliable structurally.. Bit of a knock and it's likely to split. Nev Link to post Share on other sites
Downunder Posted April 29, 2020 Share Posted April 29, 2020 Bushes: ( the ones used on the flaps , they are AN3 bore and just cut from a tube. I reckon better brass ones if they can be found ) Are you sure they're not aluminium bronze? Link to post Share on other sites
skippydiesel Posted April 29, 2020 Share Posted April 29, 2020 What ?? reminds me of my British cars and bikes (back in the day) - always carried a load of spares and the tools to do the job(s) Link to post Share on other sites
Bruce Tuncks Posted April 29, 2020 Author Share Posted April 29, 2020 You are right Yenn, but I just like having lots of washers around. I didn't know you could get thick and thin ones as AN washers. If a bolt is not quite right, you can fix it with washers up to 3 per bolt. As for the bushing material, I stand corrected . The bushes in question are on the flap-horns, and they fit the AN3 bolts on the wing brackets. A tiny bit of wear and you can feel it as play on the flap trailing edge. What I do is to replace the bolt and this helps, but I would like better and closer-fitting bushes as well. How about some rod-ends in the pack too? Link to post Share on other sites
watto Posted May 3, 2020 Share Posted May 3, 2020 I'd like to make up a spares pack of nuts, bolts, washers, split pins and whatever else might be useful. There is no point in carrying things which will never be used, so standard assortment packs are not much good. I'll get things started by listing: AN 3 nyloc nuts - 20 only AN4 nyloc nuts - 20 only AN3 thin washers -10 only AN3 thick washers - 10 only AN4 thin washers -10 only AN4 thick washers 10 only AN5 thick washers 5 only Bolts: AN3 AN4 AN5 Split pins: Bushes: ( the ones used on the flaps , they are AN3 bore and just cut from a tube. I reckon better brass ones if they can be found ) ??? Other suggestions welcome, comments too. An3 an4 and an5 penny washers are also useful to have on hand will get you out of trouble, As well as AN (a)bolts and nuts ,Cotter pins. The washers can be uses up to a maximum of 3 per bolt if you have to but preferably buy the appropriate lengths e.g AN3-4 and so on keeping in mind between 1 and max 3 threads should be protruding from the nut. 1 Link to post Share on other sites
