skippydiesel Posted February 20, 2021 Share Posted February 20, 2021 I am checking out LSA level aircraft for sale. I am particularly interested in those with good cross country performance. In this process I have come across the Rospeller propeller system, that I have not heard of befor. All the aircraft, so fitted have in flight adjustable's. The Rospeller web site offer 2 & 3 blade system and would appear to focus on Rotax 9 series engines. It would appear that these props have been around for about 30 years or so, which would suggest a degree of reliability/good reputation. Mr Google, dated erly 2000's, has some reference to failures, but nothing since. I would be grateful for any feed back on the Rospeller propeller systems Link to comment Share on other sites More sharing options...
Thruster88 Posted February 20, 2021 Share Posted February 20, 2021 What did they do about the blade retention issue, design appears unchanged? Link to comment Share on other sites More sharing options...
skippydiesel Posted February 21, 2021 Author Share Posted February 21, 2021 4 hours ago, Thruster88 said: What did they do about the blade retention issue, design appears unchanged? As I said erly 2000's - anything of note since then ?? If the design is unchanged, may be they had a material/build issue - now hopefully resolved with no further problems ??? Link to comment Share on other sites More sharing options...
Thruster88 Posted February 21, 2021 Share Posted February 21, 2021 59 minutes ago, skippydiesel said: As I said erly 2000's - anything of note since then ?? If the design is unchanged, may be they had a material/build issue - now hopefully resolved with no further problems ??? Like you I have never heard of rospeller before today. Engine failure is one thing, propeller failure is next level scary shite. I guess the market spoke. Happy to be proven wrong. 2 Link to comment Share on other sites More sharing options...
skippydiesel Posted February 21, 2021 Author Share Posted February 21, 2021 43 minutes ago, Thruster88 said: Like you I have never heard of rospeller before today. Engine failure is one thing, propeller failure is next level scary shite. I guess the market spoke. Happy to be proven wrong. I am actually quite intrigued - the are fitted to quite a few European aircraft - so far I have come across 3 for sale & one where the associated LAIM told me his aircraft is fitted with a 3 blade Rospeller variant, on a Rotax914 (he thinks they are great). They appear to have quite a robust KISS type pitch variation system utilising the Rotax 9 hollow prop shaft. They are still in production - have recently come out with a new blade shape. My guess is that most, if not all propeller manufacturers, have had "issues" at some stage in their history. What matter most is that they have learnt & applied and their products are now reliable. 1 Link to comment Share on other sites More sharing options...
skippydiesel Posted February 22, 2021 Author Share Posted February 22, 2021 Come on! there must be quite a few pilots out there flying behind Rospeller systems. Link to comment Share on other sites More sharing options...
Yenn Posted February 23, 2021 Share Posted February 23, 2021 Absolutely no experience with that brand and I assume they are working OK nowadays. Propeller failure scares me more than engine failure. Lose an engine and you know you are flying a glider, but losing part of a prop could really stuff up your day. I am not suggesting that is likely with this brand of prop. Just commenting. Link to comment Share on other sites More sharing options...
SSCBD Posted February 23, 2021 Share Posted February 23, 2021 Skip - never heard of them or any of anyone has used them in 35 years of flying. Sorry. Link to comment Share on other sites More sharing options...
skippydiesel Posted February 23, 2021 Author Share Posted February 23, 2021 Hmmmmm _ I wonder if any of our UK/European members know of this manufacturer and would care to comment ?? Link to comment Share on other sites More sharing options...
boggy Posted May 26, 2021 Share Posted May 26, 2021 Hi, I was looking at buying an aircraft with a Rospeller 2 blade inflight adjustable (damaged).The aircraft was a certified ultralight ie: non LSA and enquiries made with Rospeller concluded that these props are no longer manufactured. If you have one on your aircraft it can still be overhauled/serviced but you would have to freight it and at considerable expense. I hope this helps. Link to comment Share on other sites More sharing options...
skippydiesel Posted May 26, 2021 Author Share Posted May 26, 2021 (edited) From my reserch (there is a web site) Rospeller do not make the propeller blades - they make the hub/IFA/CS system. A similar arrangement to Airmaster Propellers (NZ). Also, it appears, from the same web site, they are still selling new units. Edited May 26, 2021 by skippydiesel Link to comment Share on other sites More sharing options...
