Guest sunfish Posted March 23, 2010 Share Posted March 23, 2010 I've been trying without success to get authoritative answers to Two questions before I can decide whether to build an LSA aircraft from a kit. 1. I understand that CASA does not permit flight over built up areas in kit built LSA aircraft without authorisation. Exactly how is this authorisation given? Is it hard to get? Is it automatic? Is it related in some way to the aircraft and engine type? Does it cost money? Does it require special equipment/paperwork or whatever? 2. Are kit built LSA aircraft allowed in controlled airspace? C? D? or just G? I have a PPL and the endorsement, but can you do it with an RAA licence? WHat about the conversion of GAAP to class D airspace? I live in Melbourne so the answers to these questions have the potential to kill my project before I even start. Link to comment Share on other sites More sharing options...
slartibartfast Posted March 24, 2010 Share Posted March 24, 2010 Hi Sunfish. I believe the answer to question 1 was in this months RAAus mag. I don't have it handy, but look there if you have one - I think it was in Mick's column. I'll look tonight. Pretty sure the answer was that you just ring the office 48 hours prior with the details and they'll give the approval to you gratis. Question 2 - if you have a PPL and the aircraft has a transponder and an approved engine, and question 1 has been satisfied if it's a built-up area, then you're good to go. Someone else will set us straight if any of that's wrong. To get the definitive answers, ring the RAAus office. Link to comment Share on other sites More sharing options...
Guest sunfish Posted March 25, 2010 Share Posted March 25, 2010 Thanks for the reply Slarti. I don't have access to the RAA magazine. If the answer to question One means I have to ring and ask permission from the RAA every time I wish to fly over built up areas, then that kills my plan to build an RAA registered LSA aircraft from a kit stone dead because I loose all freedom and flexibility. I want to use the aircraft to travel, not just paddock hop. I will try and find out about VH registered experimental category aircraft. There are one or two of those trundling in and out of YMMB. Link to comment Share on other sites More sharing options...
Admin Posted March 25, 2010 Share Posted March 25, 2010 Just a note that this morning I added the RAAus contacts to the Contacts list of the site so you can send an email to any of them right from here. On the menu go to Home -> Contacts and you can send an email to them - hope this helps Link to comment Share on other sites More sharing options...
Guest sunfish Posted March 25, 2010 Share Posted March 25, 2010 Black rod: and cannot be operated over built-up areas unless authorised by CASA or an authorised person. I have tried ops at RAA with zero response apart from "If you want authorisation I'll get it for you.' My question remains; Do I have to do this every time I wish to fly over a built up area or only one time? Link to comment Share on other sites More sharing options...
Alpi Posted March 25, 2010 Share Posted March 25, 2010 Black rod: I have tried ops at RAA with zero response apart from "If you want authorisation I'll get it for you.' My question remains; Do I have to do this every time I wish to fly over a built up area or only one time? Sunfish Only once and it will probably be emailed to you if you supply an email address. Mine has 3 conditions attached namely 1 The approval will expire when cancelled 2 The aircraft must be equipped with a servicable engine 3 All flights must be conducted at an ailtitude consistant with RA-Aus operational requirements as per ops manual That simple !! Regards Greg Link to comment Share on other sites More sharing options...
Sloper Posted March 25, 2010 Share Posted March 25, 2010 When l was doing the research l was told it was easy to get once you have completed your testing period. regards Bruce Link to comment Share on other sites More sharing options...
runt Posted March 25, 2010 Share Posted March 25, 2010 hi , have a look a t the sports aircraft asosiation aus web site SAAA - We are the Builders of AUSTRALIAN EXPERIMENTAL AIRCRAFT it's got info about building , I beleive you can build anything , and use any engine you want under the experimental badge , if registered under "casa experimental " but it also means you need a ppl . I 'm thinking about an rv9 or a mustang2 or a bd4 or a zenith 640 , you get the idea , something in ally , somthing faily quick , but may be over the raa limit so I would be forced to register under casa experimental , because of the weight limit ,oh and there is no is no spped limit in aus for raa planes ( the us has a 120 knot limit). hope this helps . ps I hope this link is ok, Iian if it's not just pull it ) Link to comment Share on other sites More sharing options...
Guest sunfish Posted March 25, 2010 Share Posted March 25, 2010 Thank you for your replies. The next stage of due diligence now starts. I'm looking at the Zenith CH750. Link to comment Share on other sites More sharing options...
