AVOCET Posted May 25, 2014 Posted May 25, 2014 hi every one , been a while since I posted , the day before I was off to austfly I got the dreaded flu that lasted for 6 weeks and then at Xmas igot another does , on top of a long hot summer in the flinders, and then I decided to make another v/stab , and now I'm ready again to hit the sky's , we are building an office in the hanger to house our new 3d printer , (15cubic ins.)we'll be able to make moulds and plastic parts for the avocet I need to go and do some flying with an instructor , not quite current . any way, I've been following the forum , some informative stuff . cheers Mike Sharples 6
facthunter Posted May 25, 2014 Posted May 25, 2014 Welcome back. Always remember to keep current in an electric aircraft. Nev 1 1 3
bexrbetter Posted May 25, 2014 Posted May 25, 2014 I was wondering what was up Mike with the extended silence, glad to hear you're ok.
Jabiru Phil Posted May 25, 2014 Posted May 25, 2014 Good to hear from you Mike May catch up at Pirie in August, if not before. Regards to all Phil.
AVOCET Posted May 25, 2014 Author Posted May 25, 2014 I was looking to donate to the forum , but couldn't find the right button ??? help . I had fun building the the new v/stab onto the existing fin post , but all came good . used the moulds to jig everything in place . cheers.. 3
dlegg Posted May 25, 2014 Posted May 25, 2014 Hi there Avocet, I'm keen to hear how the injected, liquid cooled head jab 3300 is performing. I think you could be on a winner there. What sort of prop and pitch etc?
AVOCET Posted May 25, 2014 Author Posted May 25, 2014 Quote Hi there Avocet, I'm keen to hear how the injected, liquid cooled head jab 3300 is performing. I think you could be on a winner there. What sort of prop and pitch etc? the LCH& the multipoint work exceptionally good combined with 62"x54" pitch prop. it's a much smoother running & idl.,a good temp. spread and a oil temp thermostat keeps the oil at 80 deg heads /water temp 95/100deg. works we'll on the pusher set up . cheers mike 1
dlegg Posted May 26, 2014 Posted May 26, 2014 Looks great, very inspiring, I might start with the SDS injection and go from there:chuffed:
AVOCET Posted May 26, 2014 Author Posted May 26, 2014 Quote Looks great, very inspiring, I might start with the SDS injection and go from there:chuffed: if you add the LCH to the SDS the extra current load with the water pump ect , ,7ampdraw, required a 30amp alt (on vac pump drive) .weight starts to creep up . cheers mike 1
Phil Perry Posted May 28, 2014 Posted May 28, 2014 Quote Welcome back. Always remember to keep current in an electric aircraft. Nev Awwwww. . . .come on Nev. . . .that was reVOLTing. . . . . . 1
facthunter Posted May 29, 2014 Posted May 29, 2014 That jab modified might do the job but it's starting to look like a Plumber's nightmare. Nev
AVOCET Posted May 29, 2014 Author Posted May 29, 2014 Quote That jab modified might do the job but it's starting to look like a Plumber's nightmare. Nev The plumbers nightmare (my nightmare by the way ) is being redesigned as we speak , T he Crome Molly mount will go all the way down to the roof ,and the turret cowls will screw off , making better access . another big mod !! you know , rod stiff told me , it never ends. !!! Mike Mike
facthunter Posted May 29, 2014 Posted May 29, 2014 With the water you should be able to arrange a nice cabin heater. You had to go LCH with a pusher. Nev 1
ron dunn Posted June 16, 2014 Posted June 16, 2014 Hi there Mike. Good to hear from you. I am still flying my Jabiru powered VP1 at Port Augusta. Going OK but having a bit of trouble getting spares for the 1600 Jab engine. Would like to fit a 2.2 if I could get a a cheap run out unit suitable for a general rebuild. Would be a lot easier to maintain and perform better. must try and catch up with you one day. Cheers Ron Dunn Port Pirie. 1
ayavner Posted July 8, 2014 Posted July 8, 2014 Quote Awwwww. . . .come on Nev. . . .that was reVOLTing. . . . . . Resistance is futile (think that about takes care of Ohm's law) 1
facthunter Posted July 8, 2014 Posted July 8, 2014 I know everything there is to know about electricity. Electricity is SMOKE. When the smoke stops there is no electricity. Joseph LUCAS taught me this. "King of the Road" but later AKA The Prince of Darkness Nev
Bandit12 Posted July 8, 2014 Posted July 8, 2014 Good old Lucas - very wise fellow when it comes to electrickery.....
AVOCET Posted July 8, 2014 Author Posted July 8, 2014 W Quote With the water you should be able to arrange a nice cabin heater. You had to go LCH with a pusher. Nev what !! More plumbing ??
AVOCET Posted July 8, 2014 Author Posted July 8, 2014 Quote I know everything there is to know about electricity. Electricity is SMOKE. When the smoke stops there is no electricity. Joseph LUCAS taught me this. "King of the Road" but later AKA The Prince of Darkness Nev That's why I paid a professional avionics guy a Lot of money to do it right the first time !! All jokes aside , it doesn't have lipol Mike
AVOCET Posted July 8, 2014 Author Posted July 8, 2014 Quote Hi there Mike. Good to hear from you. I am still flying my Jabiru powered VP1 at Port Augusta.Going OK but having a bit of trouble getting spares for the 1600 Jab engine. Would like to fit a 2.2 if I could get a a cheap run out unit suitable for a general rebuild. Would be a lot easier to maintain and perform better. must try and catch up with you one day. Cheers Ron Dunn Port Pirie. Hi Ron , how are you going . Might pay to ring jabiru , that's how I got my 3300 . It had 770 hours for $ 7000 ran it for 50 hrs then 0 hour ed it I was surprised , as well as jabiru at how good it was inside . X flying school Cost $1200 to rebuild at the factory . Plus the LCH Mike
ron dunn Posted July 8, 2014 Posted July 8, 2014 Finances don't run to a 2.2 in any condition so have to plug away with the 1600. But I did ring Jabiru and spoke to rod Stiff. A bit of luck here as he has very kindly GIVEN me a complete 1600 that they exchanged for a 2.2 some years ago and sealed it up in a box so with any luck I will be able to make up another engine. At the very least I should have a source of parts for some time. and all for the cost of 148 dollars for freight. Cheers Ron 4 3
ron dunn Posted July 9, 2014 Posted July 9, 2014 We had a lot of dealings with Jabaru when we ran several LSA aircraft in our school here at Port Pirie several years ago. Always got on well with Rod,Phil and Don plus their staff. That,s not to say we did not have a lot of trouble but keeping it on a friendly footing seems to have paid off a bit. Cheers Ron 1
cherk Posted July 9, 2014 Posted July 9, 2014 Quote I know everything there is to know about electricity. Electricity is SMOKE. Joseph LUCAS taught me this. "King of the Road" but later AKA The Prince of Darkness Nev I was learned the way it is..........."if ya let the smoke OUT It's stuffed!"
