Blackhawk Posted March 20, 2017 Posted March 20, 2017 Has anyone from here tried to contact - www.aerotech-poland.com They make PSRU's and i'm trying to get information about their belt psru (below) that they manufacture but I can't get any reply from them?? Thought someone here may have had contact with them at some time. 1
spacesailor Posted March 24, 2017 Posted March 24, 2017 A different firm ? Sainty engineering :info@saintys.com : They use the same type of reduction belt system on their drag car. Just for your information as an alternative to "original equipment". spacesailor
bexrbetter Posted March 24, 2017 Posted March 24, 2017 deja vu. This is not the person you are seeking, but you might try him for your needs and see what they have (Russian). ivaokm@yandex.by
M61A1 Posted March 27, 2017 Posted March 27, 2017 What is the psru off? It looks a lot like the one fitted to the old style Verner engines made in Czechoslovakia. I have a couple in my shed.
Blackhawk Posted March 27, 2017 Author Posted March 27, 2017 Hi M61A1, The psru from Aerotech was made to adapt to any auto engine up to 200hp Technical Data: REDUCTION RATIO ...........1.60 : 1, 2.09 : 1, 2.23 : 1, 2.50 : 1, 2.80 :1, 3.00 : 1 OUTPUT ROTATION DIRECTION ...........................................Same as Engine Input BELT WIDTH .................................................50 mm (1.97 in.) - 100 mm (3.94 in.) BELT LENGTH .........................................800 mm (25.21 in.) - 1000 mm (39.37 in.) BELT TEETH PITCH ...................................................................8 mm (0.315 in.) APPROXIMATE INSTALLED WEIGHT ........................5 kg (11 lbs.) - 9 kg (19.8 lbs.) PROPELLER HUB .......................6-Hole (8 mm) on 75 mm Bolt Centre with 1 in. Pilot LIFE OF THE BELT...................... change every 2 years or 500 hours (recommended) Performance Data: MAXIMUM ENGINE HORSEPOWER ........................................................200.0 HP MAXIMUM ENGINE INPUT TORQUE.......................................................300 ft/lbs MAXIMUM ENGINE INPUT SPEED........................................................6,500 RPM I contacted a friend in the Czech Republic and he said Aerotech was bought out by another company and don't make PSRU's any more. What HP engines did the PSRU you have come off, I'm after a belt drive that will take 85HP, 2.2:1 to 2.5:1 ratio. If what you have are suitable for my engine, I would like to buy both of them off you if you want to sell them. Send me a PM and let me know.
bushcaddy105 Posted March 28, 2017 Posted March 28, 2017 Have you checked whether Foxcon are still making belt drives? I've been flying behind one on a Subaru EA81 for the last 11 years 2 1
bexrbetter Posted March 28, 2017 Posted March 28, 2017 .. and I just remembered there's an Australian guy making VW conversions in Brissy (I think?). V W Engine Centre BRIBIE ISLAND, QLD
