nig71 Posted August 22, 2018 Posted August 22, 2018 Is the best way to get UHF in an aircraft to install a dedicated unit in the dash? Is there a way to use a handheld walkytalky through headsets. All I want it line of site communications. Is there a harness available? Seperate key for activation? Or do you use the key on the walkytalky ?
Bluboyz Posted August 22, 2018 Posted August 22, 2018 G'day nig71, Can you indicate the type, make or model for the:- aircraft, aircraft VHF radio(s), (intercom if fitted), and your intended UHF h/h or panel mount. A panel mounted rotary switch is a common method used in recreation aircraft, Microair and other brands have info on their sites. eg Microair 760P and UHF adaptor ~ http://www.microair.com.au/admin/uploads/documents/MAW1002M760PUHFAdaptor01R2.pdf
nig71 Posted August 22, 2018 Author Posted August 22, 2018 Quote G'day nig71,Can you indicate the type, make or model for the:- aircraft, aircraft VHF radio(s), (intercom if fitted), and your intended UHF h/h or panel mount. A panel mounted rotary switch is a common method used in recreation aircraft, Microair and other brands have info on their sites. eg Microair 760P and UHF adaptor ~ http://www.microair.com.au/admin/uploads/documents/MAW1002M760PUHFAdaptor01R2.pdf Haven’t got one yet but looking at options on a vixxen . Uhf option costs $4250; not bad for $600 unit. I’ve seen one in a photo in a Kelpie and it’s just a GME unit I might use in my ute. It is of course missing the mic and is wired into the intercom.
Thruster88 Posted August 22, 2018 Posted August 22, 2018 A handheld with headset adapter would be the lightest and cheapest. I have an icom a15 VHF as backup works well with the adapter i just use the ptt on the unit. A high power handheld in an aircraft will transmit over 100km 1
rankamateur Posted August 23, 2018 Posted August 23, 2018 Xcom add a harness to a standard dash mount GME uhf set to interface with their airband set, I installed them myself, nothing challenging, just regular tools and farmer skillset. 1
Old Koreelah Posted August 23, 2018 Posted August 23, 2018 Quote A handheld with headset adapter would be the lightest and cheapest. I have an icom a15 VHF as backup works well with the adapter i just use the ptt on the unit. A high power handheld in an aircraft will transmit over 100km ...and they go even further if connected to a good external antenna. 1
rankamateur Posted August 24, 2018 Posted August 24, 2018 Quote ...and they go even further if connected to a good external antenna. Commant 121 in the kit I got, I installed it on top, but put the unity gain UHF antenna under the fuselage, it still has plenty of ground clearance.
Hargraves Posted August 26, 2018 Posted August 26, 2018 HAT hight above terain for uhf transmitions formula is twice the height in feet squared expressed in miles ie 5000' x 2 = 10,000' squared = 100 miles
nig71 Posted March 7, 2019 Author Posted March 7, 2019 Quote Xcom add a harness to a standard dash mount GME uhf set to interface with their airband set, I installed them myself, nothing challenging, just regular tools and farmer skillset. Got any links to this harness?
skippydiesel Posted March 7, 2019 Posted March 7, 2019 My Rotax 912 motivated aircraft is quiet enough to be able to use a hand held UHF, with one cup of headset pushed away from ear, - works for me and way cheaper than integrating with VHF aircraft comms and means I can take the handheld and use it for other ground based applications. Go with the KISS principal ! 1
rankamateur Posted April 10, 2019 Posted April 10, 2019 Quote Got any links to this harness? Just had a look around the internet, looks like Xcom has gone the way of the DODO which is a shame if true.
