planedriver Posted November 30, 2023 Posted November 30, 2023 IF AWARE?, thats always helpfull. Sadly that seems to have been overlooked for whatever reason. 1
IBob Posted November 30, 2023 Posted November 30, 2023 On 30/11/2023 at 9:50 AM, Marty_d said: The point of the reserve is so you don't go down. Expand FYI Marty, 2 possible shortcomings of the receiver tank alarm system: 1. In the kits it comes with an incandescent bulb indicator. We swap that for a flashing red LED, which we also mount on the LH side of the panel (where the standard indicator is on the RH side). 2. Unless you have a way to valve off the main tanks, you have no easy way of testing the level switch, which is a simple magnetically operated reed switch and can fail. We put in a 4 valve system for the 4 tanks, following Mark Kyle's early example, and this does allow easy routine testing of the entire alarm circuit. 1
IBob Posted November 30, 2023 Posted November 30, 2023 (edited) On 30/11/2023 at 9:50 AM, Marty_d said: The point of the reserve is so you don't go down. Expand Edited November 30, 2023 by IBob
facthunter Posted November 30, 2023 Posted November 30, 2023 In an emergency you must prioritise your actions and concerns to the "essential". Reduce fire possibility by shutting off fuel if you think of it. Life first. Nev
