gareth lacey Posted May 6, 2023 Posted May 6, 2023 So i have 2 ATR 500 radios all wired up can transmit and get recieve BUT cannot hear them any guru in rdaios can help Cheers Gareth
440032 Posted May 6, 2023 Posted May 6, 2023 One might think the simplest explanation would be the most likely. Maybe headphone sockets wired up incorrectly? Did you have it done, or do that yourself? There are three solder tabs, and you generally use just two.
gareth lacey Posted May 7, 2023 Author Posted May 7, 2023 (edited) NO,i did it myself and it all bells out for continuity, sidetone is ok, send ok(radio checks from local frequency) but still no receive sound ,the receive icon comes up on radio , i will just have too go through wiring diagrams again , also have a flightcom intercom fitted so will isolate that and see the response Cheers gareth Edited May 7, 2023 by gareth lacey
sfGnome Posted May 7, 2023 Posted May 7, 2023 Are the two radios both wired in at the same time, or are you swapping them in and out and getting the same result for both of them? If it’s the latter, then there a problem with the wiring because both radios won’t have both failed in the same way. If it the former, then perhaps one is loading down (shorting) the other? What happen if only one is plugged into the harness?
gareth lacey Posted May 7, 2023 Author Posted May 7, 2023 (edited) I have tested them separately and have a swtch to change from radio 1 to radio 2 same result transmit icon ok, sidetone ok and icon for receive shows but no sound have tried both radios on i at a time same result methinks it could only be in my mic sockets , will try that Edited May 7, 2023 by gareth lacey
RFguy Posted May 7, 2023 Posted May 7, 2023 mmmm Is this an external intercom to the radios, or two radios wired up with a switch, or paralleled outputs or inputs ???? Please provide a mud map ! thanks glen.
sfGnome Posted May 7, 2023 Posted May 7, 2023 Is the switch switching both lines of the speaker, or only one? The speaker outputs will typically be differential, so you can’t have a switch in just one line.
gareth lacey Posted May 7, 2023 Author Posted May 7, 2023 the switch cuts out receive to headphones only so i can have 4 frequencies, flightcom 403 intercom
sfGnome Posted May 7, 2023 Posted May 7, 2023 Ok. As RFguy said, time for a mud map (the less muddy, the better 🙂).
gareth lacey Posted May 7, 2023 Author Posted May 7, 2023 I will put radio schematic and my swich in tomorrow cheers gareth
Blueadventures Posted May 8, 2023 Posted May 8, 2023 On 06/05/2023 at 2:01 AM, gareth lacey said: So i have 2 ATR 500 radios all wired up can transmit and get recieve BUT cannot hear them any guru in rdaios can help Cheers Gareth Expand Ground connected?
gareth lacey Posted May 8, 2023 Author Posted May 8, 2023 Yes all grounds are separate and to a bus bar
sfGnome Posted May 8, 2023 Posted May 8, 2023 Ok, definitely not differential drive, so it’s not that. I’ll apologise in advance for asking, but the squelch isn’t turned up, is it? Failing that, the next steps I’d take (and it all gets a bit painful from here) is to buzz not just that the right things are connected, but also that nothing wrong is connected (ie no shorts to other signals). That takes a while because a) there a lot of possible combinations, and b) because you aren’t expecting to get a buzz, you have to be really careful that you’re actually making connection with your tester to the signals that you’re buzzing. take the switch out of the circuit again - ie take it back to exactly as per the schematic with only one radio and see what happens then. If none of that shows up anything, then we’re into poltergeist territory… 😳 1
facthunter Posted May 8, 2023 Posted May 8, 2023 Yes we have been able to fly to the moon but getting aircraft radios to work seems one step too far. Nev 1 1 1
RFguy Posted May 8, 2023 Posted May 8, 2023 (edited) right.... SO confirm 1) when valid signal present, either radio green 'receive active' LED is lit (indicating receiving a signal), and signal from a local portable or something , but NO audio? 2) open radio squelch (like pull icom vol knob) , do you hear noise + green activity LED lit ? (if fn available) 3) transmit voice on either radio is heard by another radio elsewhere ? It is like there is a remote mute or audio suppression active on a radio pin. or intercom 23,24,25 Can you connect up an earphone between the radio output and ground (IE radio output at the back of the switch) ? Need to verify audio is present at the output of the radios before continuing. an earphone etc will work. glen Edited May 8, 2023 by RFguy 1
440032 Posted May 8, 2023 Posted May 8, 2023 On 08/05/2023 at 1:33 AM, facthunter said: Yes we have been able to fly to the moon but getting aircraft radios to work seems one step too far. Nev Expand There's now a cafe on the moon. Great food, but absolutely no atmosphere. 5
gareth lacey Posted May 9, 2023 Author Posted May 9, 2023 1. yes receive icon appears 2. no squelch on both radios 3. not tried that 23,24,25 joined as factory mute not sure how to get connection for earplug for audio
RFguy Posted May 11, 2023 Posted May 11, 2023 factory mute all sounds suspicious. are they just connected together? They should NOT be connected together IIRC.
johnm Posted May 11, 2023 Posted May 11, 2023 On 08/05/2023 at 11:36 PM, 440032 said: There's now a cafe on the moon. Great food, but absolutely no atmosphere. Expand I've been there - they have some books on anti-gravity (theoretical analysis) - once reading them ................. they are very hard to put down 2 1
