Underwood Posted Wednesday at 06:41 AM Posted Wednesday at 06:41 AM I see it has one of those industrial V twin conversions installed. In my view a much better option than the 1/2 VW. there is a Spacek SD1 fitted with one at my airfield and it seems reliable though it doesnt fly often as we are exposed to a lot of high winds and turbulence and the SD1 being a very small taildragger doesnt fare well. 2 1
BrendAn Posted Thursday at 09:07 AM Author Posted Thursday at 09:07 AM Had a look at the spacek after you mentioned it. Very nice looking plane. 1
skippydiesel Posted Thursday at 10:40 AM Posted Thursday at 10:40 AM There is no way he could communicate effectively with that radio. At those engine speeds he should consider a reduction drive of some sort. Otherwise - very well done - must have been an exhilarating first flight😈
BrendAn Posted Thursday at 11:48 AM Author Posted Thursday at 11:48 AM 1 hour ago, skippydiesel said: There is no way he could communicate effectively with that radio. At those engine speeds he should consider a reduction drive of some sort. Otherwise - very well done - must have been an exhilarating first flight😈 I thought those conversions had a tooth belt reduction drive. 2
Underwood Posted Thursday at 05:58 PM Posted Thursday at 05:58 PM 7 hours ago, skippydiesel said: There is no way he could communicate effectively with that radio. At those engine speeds he should consider a reduction drive of some sort. Otherwise - very well done - must have been an exhilarating first flight😈 It has a reduction drive. 1
Underwood Posted Thursday at 06:00 PM Posted Thursday at 06:00 PM 8 hours ago, BrendAn said: Had a look at the spacek after you mentioned it. Very nice looking plane. I think it looks awfull with the nosewheel, but the Taildragger looks quite nice. The one at my field is owned and flown by a quite small guy, I dont think you'd get an American sized person in one. 1
Litespeed Posted Friday at 10:12 AM Posted Friday at 10:12 AM Nice little tin bird. However it's missing most rivets on the screen support, possibly yet to have a canopy mounting point? Otherwise a bit poor for a factory video if rivets are missing. No such thing as spare rivets, everyone adds strength. 1 1
FlyBoy1960 Posted Friday at 10:35 PM Posted Friday at 10:35 PM the upper surface of the outer wing is vibrating aggressively. You can see it when he turns his head sideways around the 8 minute mark. Something is very wrong with this ! 1
Thruster88 Posted yesterday at 12:10 AM Posted yesterday at 12:10 AM Empty weight has to be under 254lb or 115kg. A honda gx690 is 44kg, strip unnecessary parts and then fit a reduction it would be similar weight. Add prop, undercarriage, instruments and fuel tank leaves not much to build an airframe. That is why it oil cans. 1 1
BrendAn Posted yesterday at 03:09 AM Author Posted yesterday at 03:09 AM 2 hours ago, Thruster88 said: Empty weight has to be under 254lb or 115kg. A honda gx690 is 44kg, strip unnecessary parts and then fit a reduction it would be similar weight. Add prop, undercarriage, instruments and fuel tank leaves not much to build an airframe. That is why it oil cans. I thought the ultra cruiser was not part 103.
Thruster88 Posted yesterday at 03:35 AM Posted yesterday at 03:35 AM 26 minutes ago, BrendAn said: I thought the ultra cruiser was not part 103. The Ultracruiser is a development of the heavier Hummel Bird, designed to comply with the US FAR 103 Ultralight Vehicles rules, including the category's maximum empty weight of 254 lb (115 kg). The aircraft has a standard empty weight of 249 lb (113 kg).[1][3][4] 2
