NT5224 Posted June 16 Posted June 16 Hi team. on a 50km local flight yesterday I was watching my fuel flow and realised it was rather high. As an impoverished aviator I adjusted mix to decrease my fuel usage. Then I realised that, as I sometimes do, I had left my fuel pump on after takeoff and climb. There are no hard and fast rules about turning fuel pumps off in flight so I sometimes just let it keep running on local flights. So, forgetting I had already leaned the mix, I switched off the pump. And my fuel flow plummeted… I don’t think the reduced flow reached the engine because RPM didn’t fall, but the flow guage read close to what it reads on idle. I immediately switched the pump back on, and we went back to normal. Is there a lesson to learn here? Should I always switch off fuel pump before adjusting mix to run lean in the cruise? Nobody has ever told me that before. I don’t want to fall out of the sky. 🤣 Alan
facthunter Posted June 16 Posted June 16 What engine and carburettor do you have and do you normally lean on fuel flow or WHAT? Nev
NT5224 Posted June 16 Author Posted June 16 (edited) What engine and carburettor do you have and do you normally lean on fuel flow or WHAT? Nev Good morning Nev. I fly behind a Lycoming 0320, if that matters. Im looking for guidance from experienced pilots on a very simple issue which I hoped would be informative to others. i have been flying over 20 years myself, and in that time I can’t recall anybody ever telling me to turn off the fuel pump before leaning the engine. Not in my pilot training or in any subsequent flight review. Maybe it’s just so obvious they don’t bother mentioning it! Now I think about it, it is bloody obvious, but I found out through making the error myself in flight. No harm was done, so I’m just sharing the lesson learned and observation I made. I thought that advice is probably better coming from aviators with more experience than I. Somebody like you Nev. So what would you advise? No capitals please! 😱 Alan Edited June 16 by NT5224
Thruster88 Posted June 16 Posted June 16 I have o-320 in the musketeer and o-360 in the RV. The rate of fuel consumption is only changed by mixture and power setting, there is no change with electric boost pump on or off, if the are no problems with the fuel system such as partially blocked filter, engine pump faulty etc. How ever in my RV switching on the boost ALWAYS shows an instant increase in fuel flow. I believe this is due to fuel pulsing in the flow meter. So if you lean to a known fuel flow with the pump on and then turn it off the mixture would be to lean in my RV by about 2 gph. 2 2
NT5224 Posted June 16 Author Posted June 16 41 minutes ago, Thruster88 said: I have o-320 in the musketeer and o-360 in the RV. The rate of fuel consumption is only changed by mixture and power setting, there is no change with electric boost pump on or off, if the are no problems with the fuel system such as partially blocked filter, engine pump faulty etc. How ever in my RV switching on the boost ALWAYS shows an instant increase in fuel flow. I believe this is due to fuel pulsing in the flow meter. So if you lean to a known fuel flow with the pump on and then turn it off the mixture would be to lean in my RV by about 2 gph. G’day Thruster88 thanks for this informed explanation. I don’t doubt what you say, but my fuel flow guage reading definitely increases with boost pump on. But as you say, RPM does not correspondingly increase. As mentioned in my original post, when I saw the fuel flow drop suddenly I immediately switched the pump back on again, so maybe that was just a temporary ‘blip’ in the reading, and it would have stabilised after a while. So you are saying that if I lean the mixture with the fuel pump on, there should be no problem then switching it off? Or would it be advisable to first switch off the pump, then lean the engine? I’ve never thought much about this before, but was staring at the fuel guage as I switched off the pump yesterday and the reduced readout was concerning. Alan
Thruster88 Posted June 16 Posted June 16 Yes any time the boost pump is on in my RV the indicated fuel flow is about 2 gallons per hour higher, this is obviously a false reading since there is never any change in power, engine sound or air speed. Are you A, leaning to a fuel flow from the lycoming performance chart? or B, simply pulling the mixture out until the engine starts to run rough and then go slightly richer? If the answer is B then fuel pump on or off will not matter. If answer is A and your flow meter is like mine then there will be a difference. If you are leaning to a fuel flow then I would switch the boost pump off. Normally the boost pump would be off by the time leaning is done. Leaning in a lycoming should be done any time the power is 75% or less, this has nothing to do with altitude. 1 1
NT5224 Posted June 16 Author Posted June 16 Thanks Thruster88 That’s really valuable information and exactly what I wanted to hear from a fellow pilot! To be honest my apparent drop in fuel flow switching off the pump yesterday was even more than 2 gallons… it recorded a greater reduction in flow than when I had leaned the engine… I lean my engine by pulling the mix until I get a wobble on the RPM needle then going back a bit. I then keep an eye on fuel flow and temps… Not very scientific but I get a smooth running engine, better fuel efficiency and hopefully less muck in the cylinders Alan 1
facthunter Posted June 16 Posted June 16 On a float equipped Carburettor I can't see why extra fuel pressure would change anything, unless the flow is below what is should be without the Tank Pump. As a rule I don't lean below about 5000 ft where you're then only getting about 75% with WOT. When a light plane goes into service you should check and get a Fuel flow of about 150% of the Maximum it will ever need on take off. Maybe you have some impediment to flow? Without a fuel flow indication to lean I just lean till it starts to lose Power then push in till it runs smooth and then a "wee" bit more. to be sure it's not lean. That has always come out to what the Book figures would give you. With Bigger stuff you go by the Book. Manifold Pressure RPM and fuel flow for the HP you aimed for dependant on the weight. Nev 2
dlegg Posted June 16 Posted June 16 Do you have a high wing aircraft or low? If high with tanks in them, you probably don't even need a pump. But you must have an engine driven pump? 1 1
NT5224 Posted June 16 Author Posted June 16 1 hour ago, dlegg said: Do you have a high wing aircraft or low? If high with tanks in them, you probably don't even need a pump. But you must have an engine driven pump? High wing, gravity fed motor. No I don’t need the pump in cruise so often turn it off. It’s an electric pump, not mechanical. Alan 1
Headwind Posted 21 hours ago Posted 21 hours ago Personally I have always turned the fuel pump off at around 500ft on climb out, with some possible small drop in flow. But given aircraft age and the drop not affecting the noise up front I’ve never been too bothered; that said I also don’t look at it for long since I’m at a critical phase of flight and trying to look out. I also take it as a demonstration that the pump is working, and if the engine keeps going then gravity and engine driven pumps are also going ok too. Then when I reach cruise I lean out; I tend to above 3000 if it’s a decent cruise or maybe not bother if I’m stooging about. Not sure if that’s any help, but it’s what I was taught and have tended to follow since. cheers 1 1
skippydiesel Posted 20 hours ago Posted 20 hours ago Sonex Legacy/Rotax 912 ULS - Boost pump on for Take-Off and all low level opps. Turn off Boost when at/above Circuit height - immediate drop in fuel pressure. Pressure return/recovers slowly over about 1- 2 minutes. Never been any change in engine note, so am of opinion that gauge is likly in error.😈 2
Thruster88 Posted 11 hours ago Posted 11 hours ago 8 hours ago, skippydiesel said: Sonex Legacy/Rotax 912 ULS - Boost pump on for Take-Off and all low level opps. Turn off Boost when at/above Circuit height - immediate drop in fuel pressure. Pressure return/recovers slowly over about 1- 2 minutes. Never been any change in engine note, so am of opinion that gauge is likly in error.😈 How would the fuel pressure gauge know that you had just turned the boost pump off and then decide to indicate a lower pressure for 1 to 2 minutes? It must be a very clever or mischievous one, or it might just be showing what is actually happening. 1 2
pmccarthy Posted 8 hours ago Posted 8 hours ago Same thing used to happen in my PA28. I checked and found it was common and not a problem. 1
skippydiesel Posted 8 hours ago Posted 8 hours ago 2 hours ago, Thruster88 said: How would the fuel pressure gauge know that you had just turned the boost pump off and then decide to indicate a lower pressure for 1 to 2 minutes? It must be a very clever or mischievous one, or it might just be showing what is actually happening. Nope - no effect on engine performance ie engine still receiving a sufficient fuel - remember pressure , in this context, is a secondary indicator of supply - the engine runs on volume not pressure.. It can only be an anomaly of my fuel distribution system or some inherent fault in the pressure sensing. IF the pressure is actually dropping , as indicated, the engine is somehow still receiving sufficient volume of fuel to keep functioning normally.😈
Moneybox Posted 6 hours ago Posted 6 hours ago The carburettor needle and seat controls the fuel level and therefore mixture regardless of fuel pump pressure (unless excessive). Your fuel flow measurement will be fuel consumed plus by-pass fuel that is returning to the tank. The electric fuel pump should not have any effect on engine performance or fuel mixture unless the mechanical pump is faulty.
Thruster88 Posted 40 minutes ago Posted 40 minutes ago 18 hours ago, skippydiesel said: Sonex Legacy/Rotax 912 ULS - Boost pump on for Take-Off and all low level opps. Turn off Boost when at/above Circuit height - immediate drop in fuel pressure. Pressure return/recovers slowly over about 1- 2 minutes. Never been any change in engine note, so am of opinion that gauge is likly in error.😈 Regarding your posts that the carburetor engine still receives adequate flow even at low fuel pressure, I TOTALLY AGREE, however to say the fuel pressure gauge is in error sometimes makes no sense. How can it be in error sometimes? Is your fuel pressure on the ground, Boost pump only the same as while flying, engine pump only? In a tecnam /912 I have been flying lately they are the same. Turning off the boost pump in flight results in zero change in fuel pressure on the mechanical fuel pressure gauge. Below is a 912 fuel pump. A blockage in the vent line might explain your pressure rising over a minute or two. The little spring controls fuel pressure and should immediately take over from the boost pump unless perhaps the diaphragm is being held down and not able to stroke.
