CT9000
Everything posted by CT9000
  1. ......consider going the long way around until the new draw bridge is completed........
  2. ...... accessible as the start of filling in the ditch therefore simplifying the forced landing options for two stroke fliers travelling between Tas and the mainland......
  3. ......rules and regulations. We have very learned consultants within our ranks. Take Turbs for example with his well researched comment on the small city called Darraweit Guim in Vic north. Our chief consultant flies out of YMMB so as any thinking person would know that is in Vic so Vic will be taking over Tas and not some upstart from WA. The only small problem at the moment is that Vic needs a new chairman.......
  4. ......there was much questioning of the claims till the marketing department held a press conference to clear up any questions regarding the claims. A synopsis went as follows. "WHY DID YOU USE A VICTA 125" Because the early Victas were low compression and that was the only one we could get to start on 10:1 " WHY 10:1" Because in the interests of more accurate reporting we need to address real world situations so after sitting for a year the aromatic hydrocarbons would evaporate out leaving a mixture equivalent to 10:1 "WHY HAVE THE VICTA FLAT OUT AND THE ROTAX AT FAST IDLE" Because at 10:1 the Victa makes about 4 hp flat out and the Rotax makes that at fast idle. "WHY RUN THE ROTAX AT 80:1 ON THIS TEST" Because that is all that is needed at fast idle load. And so on the snow job sorry press conference went. See a real un biased independent well researched project........
  5. ......almost half the pollution levels of normal two stroke engines that are over fueled and using the normal 10% oil mix. These findings come from a study comparing a Victa 125 at full throttle using normal two stroke oil mixed at 10:1 and a Rotax 582 at fast idle using our product mixed at 80:1 , so as every one can see this independent un biased exhaustive study proves the environmental benefits of using our products. At only $75 per ltr. this represents very good value because $1 will be donated to our distributers for every carton of fifty ltr sold.....
  6. .......although there appears to be some resistance to the seat belt upgrade this is mandatory when operating upside down due to the fact that this operation may at times require hands on controls and therefore not hanging on may result in blade damage due to bone contact, also blood may not wash off a hot engine very easily .....
  7. ......provides a compelling reason to purchase one of the new generation hackalopters. These wonderful machines when used upside down can cut grass or trees to the normally accepted height of two inches. On top of the five thousand dollar drawing upgrade for engine options there is also the mandatory drawing upgrade for the mirror when used for grass cutting, also the mandatory seat belt drawing upgrade........
  8. ......realization hit that a Victa is a lot more powerful than the Morry engine and will give lots of yaw control. Rotax is fine but the Ford V8 flat head is just a tad heavy for good W & B unless the pilot sits in the back. Brilliant opportunity for the five thousand dollar upgrade drawings for the engine options.....
  9. .......this new Biplaopter can be purchased as a quick build kit that takes only 500 hrs to complete. All it needs is the customer to fabricate the wings, fuse. rotors, controls, mounts, etc. and supply own running gear, interior, instruments, wiring, electrics and hardware. Full detailed instruction manual included in one convenient A5 sheet. .......
  10. Captain looks like we posted together but I decided to chuck in an avref
  11. ......they proudly displayed there newest long range twin engine high speed biplane, complete with one Nissan 1200 engine for the main rotors and a morry side valve for the tail rotor. This amazing piece of modern hi-tech kit also had long range vision { a pair of no.2 glasses from the $2 shop } night lights { single AAA powered torch also from the $2 shop } and the stealth kit {ear plugs also from the $2 shop } confusion arose about is it a hackalopter or a biplane with tail rotor for yaw control ?.....
  12. But not always. I made the mistake of thinking the postal service might just work so I purchased a pair of express post envelopes to post to Caulfield and back to Darraweit Guim. Cost $15.00 to get some papers signed. Sent 9am Monday 22 Nov. arrived at Caulfield Thurs 25 and posted back a few minutes later. As of today 2 Dec still no sight of mail. I could have walked there quicker. waste of money and time, the only thing about express is my frustration. Sorry for the thread drift but roses for Aust post, more like cow droppings.
  13. .....every one feeling good as the Volvo was an old F10 model seriously overloaded struggling up even the slightest hill belching black smoke enough to cover the highway from gutter to gutter reducing vis {avref} to about 30 feet.........
  14. .....but even though a bit knocked about the suffering was still less than being hit by the bits of exploding ford 272 Y block engine. The fact is that even though it was actually a late model Customline star model 292 engine, those old Y blocks don't take kindly to super chargers. The hot oil mixed with bits of cast iron would be a bit hard on even the toughest stonefish......
  15. .......shoulder rocket launcher test program where the bullet proof vest wearers { testers } were getting progressively harder to find......
  16. ......oved out of the way as every one else pondered over just how much damage a light touch and go from an ultralight on a tiled roof can do......
  17. .......fight and a rush it's a Thruster a fair dinkum one too, not many original examples of these still around still flying, lets have a closer look then we'll have a party.......
  18. ......hit your head on so the blood in your hair helps keep the afore mentioned hair out of your eyes .......
  19. ......and was nearly hit by the falling vicpol hakalopter that was out of fuel due to the bullet holes in the fuel tanks (they use big bullets where this thing came from)......
  20. ......get about since they pulled his ticket for the low formation night flights. These flights were a very slight technical infringement of the rules. The argument went along the lines of being before sunset due to the "night sun" light on the Pol air hackelopter meaning it was still day light. The alleged flights took place after curfew when no people were about, as proven by chairman Dan's news promo {sorry news conference} stating that people were complying with the lock down rules so therefor the witness audience were not actually there. In the interests of safety the drunk bike owner at Young & Jacksons who also was not there will not ride his bike home without a light. The Thruster pilot did not have a light because there were no more bikes on the foot path outside the pub so he had to follow the Drifter close. In conclusion the several laps around the block of Swanson Bourke Elizabeth and Flinders streets were for practice to make the whole exercise safer and at at 10 feet it not so far to fall.......
  21. ......the curfew. The afore mentioned formation flight was carried out at night due to safety concerns. both aircraft were night rated and prepared for the job. The lead aircraft {Drifter} was fitted with a bicycle torch stolen from the parked bike at the front of the pub taped to the front of the pod, and the tail {Thruster} fitted with a red reflector stolen from a road sign and stuck to the rear of the fuel tank. .....
  22. Forgive me Turbs but how does that follow on from my brilliant lead in back to avref
  23. .....steer this NES back to aviation again by formation flying Thruster and Drifter up the center of Melbourne at 10 feet under the tram wires........
  24. ......but this was really only a con job to make it harder to trace the guilty. Blowing up the CASA inspectors car was just a tad naughty but the minor fact that not only was the inspector still in the car but also his assistant his adviser his secretary and his planner also. It would appear that CASA was a bit cross with it being exposed that not only loosing five dedicated staff but their four seat econobox was overloaded. That's right NES readers a CASA inspectors car more bums than seats but over MTOW. .......
  25. ........thruster by landing into wind which reduced the ground speed to zero then controlled the decent with power for a perfect vertical landing ......
