RFguy
Everything posted by RFguy
  1. I read that as control surfaces were connected. But may not have been functional after hitting something . maybe pitch up due to damage , since the distance between impact and wreckage was a fair way. gust of wind or engine trouble, or both or excessive load and failure to gain altitude. Something like that even momentary engine stumble might be big trouble. You'd expect a tailwheel pilot to be ready for a gust of wind. My wild speculation, at best . arrogant presumption at worst .
  2. WHat does it mean by : " Flight control continuity was established through several breaks to the flight control surfaces." Does this mean flight controls were intact (IE controls connected to the surfaces ) ?
  3. Fuel return is to permit circulation of : heated fuel (changing its vaporization behaviour) , purge / pass bubbles in the line around the system . So, it does provide a very useful job. For a system without a collector, it does pose some issues to which wing you might put it back into. high wing with collector tank for both wings - fuel return is easy. Rotax requires that a fuel return is provided for in its installations . (past 6 years) . Skip, so 5 litres / hour now ? IE something about a bit above idle for that engine . or about 4 tablespoons per minute. , amounts to a velocity in the delivery of (2 x 5 lph) of 2.7mL/second. for 1/4" ID (VOL = 31.6mL/meter ), the fluid is 'changed out' abotu once every 11 seconds. sounds reasonable. I think you could go half that again and still have plenty of return .
  4. NOTE - this engine and the chinese bits were discussed elsewhere in this webiste/ forum.
  5. In my case of having traffic to my right , turning right would have meant the collision occurs a few hundred milliseconds earlier. My best option would have been to pull up since. I was below or at Va. Now, if they had ALSO gone right right that would be OK if I had also gone right. if they had gone right down , would have been best for me to go up left.
  6. anyone wondering go to the CASA myCASA portal, log in, go to medical, and there you start the process. you fill in your GP name and details and you get a partially filled in 11 pages to take to your GP that does the same examination as a Heavy Vehicle License test, tick the boxes, fill in a few things. If it is "unconditional" then you just say yeah I am unconditional and the class 2 basic med certificate is generated on the spot and you are done....
  7. so be it , prefer none than delayed or rely on a system that may have high latencies. radio should catch others... mobile data is very low reliability over anywhere serviced by multiple base stations and or base stations that are busy. I will see RPT (they have ADSB without ozrunways) , and many GA. if the others dont have at least a SE2, not much I can do except listen in the radio. down the track I might add a interferometer receiver which can determine likely location of transponder only aircraft by trilateration and triangulation.
  8. I'm convinced reliability is straightforward . just keep the oil clean / fresh, temps moderate, fuel line strainers and filters clean, avoid large changes of throttle < 3 seconds, and for continued monitoring watch the oil filter foreign body contamination and do leakdowns.... simple.
  9. I intentionally prevent my Ozrunways from showing any mobile-data derived traffic due to the lag. I just use the SE2 for my traffic reception on the wifi connection.
  10. probably just a thermal bubble letting go.
  11. I had a bit of a chat to them a couple of years ago. Still unsure whether they made it under license or if it was a pure clone without all the know how. I just cannot beleive they would make it to 700 hours (so far back then) (which people I have independently spoken to in EUrope) if it was an 'uninformed clone' .
  12. correction : my 1000m up and down if shielded should read 1000' . feet not meters.
  13. traffic that is 'OLD" or "out of date " (say 3 seconds) needs to be put into a different colour traffic bubble . I dont like anything with a cellular or third party network that does not deliver time definite in the way....
  14. and baro from the SE2 would have a high uncertainty because it's position could be the subject of variations from atmo pressure.
  15. agreed on nice to see say, inbound traffic 8nm the other side of the airport when inbound, gives you some think time to decide your intentions.
  16. good points on delays. lot sof poor / suboptimal implementations out there there isnt complete blocking by wings at least for close proximity - signals conduct and bend around wings , there is re radiation from the airframe etc. At least up to about 1000m above or below it is going to be pretty bulletproof. It does open you up to the ADSB semi-blocked transmission getting stomped on by another in busy airspace , but that's a low likelihood with 120uS bursts and position being transmitted at ~ 2Hz. My production ADSB-TCAS implementation will be real time. and it is predictive. I have ordered 30 sets of raw data capable GPS modules for my project to start with.
  17. yeah. I am was concerned, but I was looking for them late base.... down to my lower left. not out the window to my right. I shoul;d have been able to see them late base since that's a white aircraft over green pastures. Looking to the right is looking into the town and beyond into the hills. I dont understand you mention of trafdfic displays showing the situation in the past- certainly the past but no more than a few seconds Which brings me to a defficiency with looking at traffic in OZRWYS - there isnt a time stamp or time delay shown for that fix.
  18. 240 mag @ 12-14 kts on ground, IE blowing aircraft on downwind and crosswind wide.
  19. All aircraft were using 15 other aircraft is likely to have gone very deep on crosswind leg, or drifted 1nm on downwind. As we had 1.5nm to 2nm separation (or approx 1 minute) when I was in T&G and other aircraft was crosswind leg and then in late downwind we had zero !
  20. Both GNSS altitude and barometric are available and are transmitted. In the RV, your SE2 has an excellent all round view of the sky.
  21. My experiences are in the PA28 with SE2 on the 2nd pax row seats window behind me. (It's currently up on the instrument panel deck until the GPS-35 antenna is fitted for the xponder). OK I think the GPS wont see well through the wet wings, but through the body would be ok otherwise. To recap- we need satellites from around the whole sky to get a good fix. So SE2 position matters if it is blocked in directions. KG : Those experiments were to determine the practical sensitivity to using an 'outside' antenna, a length of cable, and an inside antenna that is close enough to re-radiate the signal to the SE2 on the bench, inside of my shielded box electronics workshop. AND, performance with multiple antennas to a combiner and then to a re-radiating "coupling" antenna near the SE2. The results are good. I think that it might be possible to get good fixes with just a single 2nd antenna on the other window with a coupling antenna near the SE2. and much better with a third antenna on the nose / instrument panel. The receiver is measuring time delay between sats in order to determine position . To get a accurate GPS fix the receiver needs to be able to see SVs (space vehicles ) around the sky so that it gets diversity . IE if all the sats are around the horizon, the vertical accuracy of the fix will be poor without a satellite overhead . In practice we are not after mm of precision, so we dont need much.. Remember the trig tables, and the relationship with small angles .
  22. Ublox receiver sitting on log. There is a PATCH antenna on the bottom of that receiver , so it is just sitting on it, SE2 with log periodic this is good and about the best reliable distance . works up to about 65mm my GPS antenna power injector (since the roof top antennas need power on the cable) checking polarization dependence this iis cross pol (poor)
  23. Today I was messing around with multiple GPS antennas on active repeaters. they're really all active because most GPS antennas have amplifiers in them to cope with the lossy long thin cable. had couple of antennas on the roof, fed with a power injector, and a few different rerad antennas. I also updated the SW in my SE2 to 2.41 Started working with some ublox receivers I have with the very fancy U-center program that tells you all the backroom GPS data. then I moved to using the SE2. It's clear why the SE2 will report some very poor position fixes. It's bar is very low. With NIC (Navigation integrity category) =0 and NACp (Navigation uncertainty category) = 6 (on the wifi GUI) the box shows GPS green. If we ignore NIC of 0 means containment radius integrity is unknown. IE NFI ! The NACp of six means better than 566 m in horizontal and worse than 45m in vertical. (95% confidence) So what I see (transmission of poor fixes) makes sense. WHen life is good, I see up to NIC=6 and NACp = 8. Now, this is much better - NACp of 8 implies better than 93m in H, but STILL > 45m in V . (95% confidence) and containment radius better than 926m. The SIL for a SE2 is 1, which means likeihood of being beyond the containment radius is < 1 in 1000. I've seen a NACp of 9, which implies better than 30m H and better then 45m in V Now, what is accepted by receivers and processors and displayed online like flight aware and flight radar might be very different to what is displayed by ATC IE ATC are unlikely to display poor NIC and NACp numbers (or shouldnt) . I wonder what SE2 pass to the EFB. NACp is transmitted in ADSB message type 31 in V2. so the nav performance is transmitted. So, of all this I think it is very practical to be able to provide a supplemental GPS antenna to a skyecho, so that the SE2 can be on some inside back window, and also have an aux GPS antenna on the window on the other wise of the aircraft. I started with a log periodic wideband antenna and then made a little dipole antenna to gauge polarization matching sensitivity, and there is that to it. The antenna in the GPS receiver should be a circularly polarized type, but its a very very simple little thing and seems to be rather random but with a preference of paralell to the board axis. Pictures to come
  24. well, today or tomorrow was going to fly to Port Macquarie for a get together. However, the GAF is more than just a couple of sentences, its a couple of pages of hazards.. Instructor was right. If the GAF is more than a couple of lines stay on the ground. MOD MTW, SEV TURB and low cloud.
