rgmwa
Everything posted by rgmwa
  1. Charles Lindbergh was a good friend of Henry Ford and was closely involved in advising Ford's executives and helping the Willow Run plant to work through the many teething problems they had in getting the production line and workers up to speed on building aircraft to the required standards. Not surprisingly, early production examples had lots of quality problems, delays in delivery schedules, etc. There was also a lot of friction between the Ford operation and Consolidated over lack of adequate drawings, parts incompatibilities, resistance to making design changes that Ford wanted to suit mass production, and personality clashes between senior executives from both companies. Still, they got it done in the end. rgmwa
  2. Might be worth checking the area around Tyrendarra too if you're over that way. There's a similar aboriginal settlement there: Tyrendarra Indigenous protected area rgmwa
  3. This may be helpful: Pirep: Rutan LongEze rgmwa
  4. Out of curiosity, decided to see how high the RV-12 would go today. Got to 11,100' (12,400' DA), and was still going up at better than 300 fpm before deciding it was high enough for me, even though the plane could have gone higher. Not bad for 100 hp. The view was pretty good too! rgmwa.
  5. I thought the NZeds called them Chilly Buns, not Chilly Willies. Obviously neither would apply to the couple on the bike. rgmwa
  6. I've recently managed to recover from the new kit bug, so hopefully should be immune for a while. rgmwa
  7. Thinking about going, although not this year, maybe in 2017. For you regular Oshkoshites, what's a ballpark cost for the trip so I have some idea of what to plan for? rgmwa
  8. Sorry my fault. Full version here, 10th item down at the bottom of the page. Van's Aircraft - Service Information and Revisions RV-12 rgmwa
  9. I'm sure I've posted this link somewhere before, but download Section 05 (scroll down, third item. It may take a few minutes to download). It has a lot of good information on proper construction techniques and other useful data that should come in handy. Van's Aircraft - Total Performance RV Kit Planes rgmwa
  10. Use a file on straight edges and a de-burring tool on holes to remove the burrs, followed by a Scotchbrite pad (the maroon colour) to smooth the edges. Or use a Scotchbrite deburring wheel to do both jobs - depends on the size and shape of the part. You should be able to get Scotchbrite pads from a decent paint shop. Burrs act as local stress raisers and can initiate fatigue cracking, so deburring rough edges in aluminium components is important. rgmwa
  11. You could try Western Airmotive at Jandakot for AN bolts. PILOTSHOPWA (Western Airmotive) (Powered by CubeCart) rgmwa
  12. A ladder looks doable too ... rgmwa
  13. As you're in the US, probably best to ask your instructor and talk to other local pilots. There are plenty of choices. A used pair of Dave Clarks would be a good start, or maybe Lightspeed Sierra if you want an ANR set, which is probably preferable. Try a few different ones to see which suits you best. rgmwa
  14. Started building control line models at 13. Saved for my first model and an OS.15 by collecting parcels from the railway station for my parents' business at 10 cents a parcel. rgmwa
  15. SAAA sell them in single sheets. rgmwa
  16. No diagonal bracing? rgmwa
  17. I understand that. Had lots in my own plane, both `pop' and standard rivets in countersunk or dimpled holes. Just had some concerns about using countersunk head rivets made with a hammer. Holding a nutplate in position may not be too risky, but you would never want to use them in a critical application (ie. just about anywhere else). rgmwa
  18. Not wanting to sound overly critical, but if those rivets are only intended to hold a nutplate in position, then you'll probably get away with it (unless they shear off eventually). However, if they're structural rivets then use the correct aircraft grade ones and also take note of the correct cutter or dimple die countersink angle to use. AC-43.13 1B is a good reference for how to put aeroplane bits together properly http://www.faa.gov/regulations_policies/advisory_circulars/index.cfm/go/document.information/documentid/99861 You probably won't find instructions on how to make countersunk rivets in there. Also, scroll down the page here and download Section 5. Different manufacturer, but Section 5 has a lot of practical `how-t0' information in it. https://www.vansaircraft.com/public/service-rv12.htm rgmwa
  19. ... or lack of. Time will tell. Somebody once described a camel as `a horse designed by a committee'. Hope it doesn't apply to the F35. rgmwa
  20. Hi Liz, Welcome to the forum. What's your interest in aviation? We have a very diverse lot of aviators here. If you're ever in Western Australia, right seat is reserved. rgmwa
  21. Thanks Rick. I hadn't thought of them, although based on past experience, I may have to remind them that the coating is only Alclad, not gold. rgmwa
  22. Does anyone know where I could get some 2024-T3 sheet in Perth? rgmwa
  23. What's happening with the engine while you're working on this project? rgmwa
  24. Flew from Serpentine WA (YSEN) to Portland VIC (YPOD) where my parents live, with overnight stops at Esperance, Border Village and Whyalla. About 2,900 km so far with intermediate stops at Katanning, Cocklebiddy (rough strip), Nullarbor Roadhouse (good strip), Ceduna and Naracoorte. The biggest problem was not the flying or the navigating, but the logistics of getting mogas to the plane (except for the Nullarbor, oddly enough). Nevertheless a great experience. Even made page 3 of the local paper with a photo and article (maybe I should say relegated to page 3). Highlights so far have been flying along the cliffs at the Head of the Bight, crossing the Gawler Ranges in SA, and taking several people up for local flights around the Portland/Warrnambool area. These included my dad (aged 97) - first time he's ever flown with me, one of his friends (aged 86) from Geelong who according to his wife, still hasn't stopped talking about it, my young nephew who has just got a job as an inspector with the Fisheries Department in Portland, but had never seen the coastline from the air, and one of my brother's friends who was terrified of flying but determined to have a go and is still over the moon at what he achieved. He came back the next day with an A4 page of questions about flying, and has since watched every RV12 video he could find on uTube. He's become an RV groupie, if there is such a thing. That's really what being able to fly is all about. Now I just have to get back to WA! At 7,500' NE of Esperance... Head of the Bight... Overnight stop at Border Village (luckily the winds weren't too strong)... rgmwa
