Happyflyer Posted May 9, 2017 Share Posted May 9, 2017 Now this would improve the take off performance a bit! 4 2 Link to comment Share on other sites More sharing options...
snarf007 Posted May 9, 2017 Share Posted May 9, 2017 The single ECU scares me, but with the fuel injection fleet having accumulated over 60 000hr and not a single failure, it must be safe. SDS offers a similar system, but with the option of having a back-up ECU. I think they are going to sell a lot of these kits in North America. Why get a 914 or 915, when you can have this fuel injected turbocharged 912 on your homebuild for the same price as a 914?! 1 1 Link to comment Share on other sites More sharing options...
Guy s Posted May 9, 2017 Share Posted May 9, 2017 Crikey!!! I might have to get something a little sleeker than the Savannah that can handle all those horse's Link to comment Share on other sites More sharing options...
facthunter Posted May 10, 2017 Share Posted May 10, 2017 Can't see how it can be reliable with the same built up crank and cases. There's extra heat to get out of it as well with supercharging. Generally they oil spray the underside of the pistons even for a small increase. The oil system in a 912 is "funny" how it relies on blow by to return it as well as pipes everywhere. The 80 HP is reliable but the others less so. Having to time limit high power setting is a sign the engine is a heat sink. Nev 1 Link to comment Share on other sites More sharing options...
Nobody Posted May 10, 2017 Share Posted May 10, 2017 Can't see how it can be reliable with the same built up crank and cases. In the video they address the crank shafts. They claim to have a procedure to weld up the pressed together crankshaft. Interesting idea if it works.... Link to comment Share on other sites More sharing options...
Yenn Posted May 10, 2017 Share Posted May 10, 2017 I doubt that they could produce 154hp for more than a very short time. The hp increase is 94% so the heat increase must be terrific. 2 Link to comment Share on other sites More sharing options...
Oksinay Posted May 10, 2017 Share Posted May 10, 2017 ECU made in Melbourne? 1 Link to comment Share on other sites More sharing options...
aj_richo Posted May 10, 2017 Share Posted May 10, 2017 Same guy turbocharged and fuel injected a Jab 2200 1 Link to comment Share on other sites More sharing options...
geoffreywh Posted May 10, 2017 Share Posted May 10, 2017 I spent several years assembling and tig welding Suzuki and Kawasaki crankshafts, same system same reason..... FYI the power output increase was in the order of 150%. Some heat sink...Others got about 1000hp but only for a short time....Never had thru' bolts break though. 1 1 Link to comment Share on other sites More sharing options...
bexrbetter Posted May 10, 2017 Share Posted May 10, 2017 In the video they address the crank shafts. They claim to have a procedure to weld up the pressed together crankshaft. Interesting idea if it works.... Welded pressed cranks are nothing new at all, absolute standard practice and very common in bike racing since year dot. Not sure on the stresses of the crankcases longterm though, hate split cases with a passion, tainted by the amount of VW failures I have seen. There's a good reason top drag VW's use these style cases ... 1 Link to comment Share on other sites More sharing options...
bones Posted May 10, 2017 Share Posted May 10, 2017 I doubt that they could produce 154hp for more than a very short time. The hp increase is 94% so the heat increase must be terrific. I had 145 hP on a 80 hp rotax no heat problem similar idea to this it works well, you can trick the computer on the 914 nd they pump out something like 180 hp 1 Link to comment Share on other sites More sharing options...
