Around the world aviation safety authorities take a long time to confirm even the basic facts. Often this is over a year.
This is the main reason so much discussion and conjecture occur.
Some of this discussion is off or even completely wrong but some of it is not.
As long as we all operate with high level filters on, review the source of each piece of info and apply logic to how it all fits together I believe the benefit (safety lessons much earlier) is worth it.
Or offical safety bodys could release what they know much earlier.
The more facts you have the better your OPINION will be,  and you do need "AVIATION expertise" to interpret the FACTS. in  aviation matters.  Nev
WWW.MSN.COM
Typical Trump response above.
I haven't been through all the detail reported here, but could it be as simple as the wrong QNH set on the helicopter that had it at the wrong altitude?
35 minutes ago, red750 said:
WWW.MSN.COM
Crossed my mind too. Not necessarily incorrectly set, but out of calibration. Cracked static line or something.
I'll wager that NVG's played a large part in the crew errors leading to this disaster - and the investigators are almost certainly intent on trying to determine whether they were being worn or not.
The training was a simulated night "escape" for VIPS under a simulated major U.S. leadership attack, such as the 911 scenario.
WWW.NYTIMES.COM
Investigators have yet to determine whether the crew of an Army helicopter was wearing the devices when the Black Hawk crashed into a civilian airliner last week.
WWW.DAILYMAIL.CO.UK
Questions had been raised about how the collision - which killed all 67 people involved - occurred, given pilots follow strict protocol about the altitudes they can safely reach.
This accident really has to be blamed on whoever decided that helicopters flying at 200' below aircraft at 300' on approach to land was OK. The second factor was whoever decided that visual separation at night between aircraft in that situation was OK.
With those factors in play it was just a matter of time and luck before this accident happened.
  • Agree 4
Just read that too. Why turn off ads-b on a training flight? Something you'd think you'd want in a crowded airspace.
I think the ADS-B is a side issue: flying in that situation you would want your eyes mostly outside. And from what we have so far, it looks as though the helo may have transitioned fromapprox 200 to approx 300 late in the piece.
I have wondered whether flight training would benefit from some deliberate focus on potential high risk collision points, explaining them to the student.
For instance, some years ago I was almost taken out by someone wrongly located and a bit low while doing a standard overhead rejoin. I was taking off. So in that instance the risk was at the crossover point between traffic taking off and traffic crossing the strip. Had that risk been emphasised in training, we would all be aware of the need to cross with adequate height, and in an appropriate place.
Similarly, I have learnt to be wary of crossing the flight path of potential outgoing traffic for many miles out, where they may still be in a hard climb, in our case in line with the strip due to it's orientation.
And a third example: a very good look downwind on the base leg and before turning final. Twice I have seen aircraft coming straight in cross in front of traffic on late base leg, and both times in complete radio silence.
Eventually (hopefully) we may work all these things out for ourselves. But why not point them out during training?
And while it's easy to be smart after the event......if the standard helo briefing had included 'under no circumstances exceed the maximum height, doing so will bring you directly into the path of airport traffic'..........maybe all those folk would still be walking around today.
Do you really think they flew this flight without an adequate briefing?? 100+ knots, 200 feet, at night near a busy airport?
Military flying can be dangerous by necessity and people are killed in accidents occasionally. But it shouldn't be putting civilian traffic at risk. There's no justification for a route at 200' below landing civilian traffic.
Aro, I can have no idea.
What I was trying to suggest, in a broader sense, is that there might be some benefit in stressing certain  parts of certain procedures.......and focusing on why.
For instance, the standard overhead rejoin, as taught here, is well documented with minimum heights and positions over the airfield. But so far as I know, the reasoning behind that is not explained.
Sure, most pilots will hopefully eventually figure out the why around all that........but why not tell them in the first place?
The sheer idiocy is in the allowing of intersecting air traffic at low level, with only 100 feet clearance, where height measurement can only be done reliably by very precise instruments.
FFS, the NTSB is still struggling with altitude accuracy of the Blackhawk from its FDR, which wasn't even time-stamped. They're talking about trying to define to more accuracy, a 50 foot altitude variation at 300 feet! Even the ATC screens only report 100' variations.
And why did the Blackhawk pilot request "visual separation" when ATC were in a far better position to advise track and altitude? The U.S. military has to wear a lot of blame for this crash, with procedures that act as if they're the only ones in the sky.
WWW.AVWEB.COM
Blackhawk’s FDR data was missing time stamps.
  • 1 month later...
The NTSB Preliminary Report is out, and it basically only outlines the aircraft movements, flight paths, collision damage and other pertinent facts related to the crash. There are excellent CVR and FDR records from both the helicopter and the CRJ-700. There is NTSB concern over the accuracy of altitude data from the Multi-Purpose Flight Recorder ("MPFR") in the helicopter, and they are currently unsure how this affected other helicopter altitude measuring systems, until further investigation is carried out. The MPFR is a combined CVR and FDR.
In addition, the audio record from the helicopter indicates portions of radio transmissions were not recorded (or heard) - in one case, because the helicopter microphone was keyed when ATC transmission was taking place, and in another section, the word "circling" in the ATC advisory transmission was not picked up by the helicopter recorder, but it is recorded on the CRJ-700 CVR, and on ATC audio recordings.
At the time of the reports release, the NTSB issued an urgent recommendations report, advising immediate steps to be taken, to ensure a major reduction in the level of civilian aircraft and helicopter near-misses, that had been regularly reported in the region, in recent years.
The recommendations report outlines how the helicopter route ("Route 4") along the Potomac River has lax boundaries, and even slight deviation from that poorly-defined route, poses an unacceptably high risk of an MAC with departing or arriving civilian aircraft, that are using the airport runways - especially as flight path altitudes of arriving or departing civilian aircraft over the River, can also have some altitude variations, according to how closely the aircraft is following the glide path or takeoff path.
The NTSB advise that the FAA urgently needs to close the helicopter route ("Route 4") along the Potomac River whilst civilian aircraft are departing or arriving at the airport runways.
However, they also recommend that an alternative helicopter route must be found, to ensure that important Govt, medical, law enforcement, air defense, or presidential transport, can continue at will, and at short notice.
At present there is a NOTAM (active to 31st March, 2025), that prohibits helicopter traffic along the Potomac in the vicinity of DCA flight paths - but that NOTAM also advises that if urgent medical, law enforcement, air defense or Presidential helicopter movement needs to take place along the Potomac River, civilian aircraft will not be allowed to operate along the airport flight paths, until the helicopter has transited the critical zone.
https://www.ntsb.gov/investigations/Documents/DCA25MA108 Prelim.pdf
https://www.ntsb.gov/investigations/AccidentReports/Reports/AIR2501.pdf
FAA chart showing the helicopter routes in the Washington DC area
Aircraft traffic over a 48hr period.
DCA and Helicopter Traffic
13 March 2025
The FAA issued a revised helicopter route chart for the Washington DC area, specifically removing the helicopter routes 4 and 6 in the area of DCA and revising route 7 to the west of the airport. You can compare the old chart above with the revised chart below. For the full notice, including text descriptions of the route changes from the FAA.
New helicopter routes in Washington DC area.
chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://www.faa.gov/air_traffic/flight_info/aeronav/safety_alerts/media/VIS_25-02_CN_DCA_Helicopter_Route_Chart_Revisions.pdf
  • 1 month later...
The pilot of the Black Hawk helicopter that collided with the American Airlines passenger airplane did not comply with directions to change course seconds before the fatal incident, a bombshell new report has revealed.
On the night of January 29, Army Black Hawk pilot Capt. Rebecca Lobach was conducting an annual flight evaluation with her co-pilot Chief Warrant Officer 2 Andrew Loyd Eaves, who was serving as her flight instructor.
Three months on, new details published by The New York Times revealed that the pilot made more than one mistake leading to one of the worst catastrophes in aviation history.
Not only was Lobach flying her Black Hawk too high, but in the final moments before the impact, she failed to take advice and instruction from her co-pilot to switch course.
Lobach's piloting skills were being tested during the evaluation on the fateful night, before the crew were informed that an aircraft was nearby, according to the report.
Just 15 seconds before colliding with the commercial airplane, air traffic control told Lobach and Eaves to turn left, but she did not do so.
Seconds before impact, co-pilot Eaves then turned to Lobach in the cockpit and told her that air traffic control wanted her to turn left. She still did not do so.
Investigators may never know why Lobach did not change course that day.
Both Lobach and Eaves had first acknowledged the message that an aircraft was nearby, and spotted the plane themselves before requesting to fly by 'visual separation.'
This is a practice that allows aircraft to avoid collisions based on their own observations instead of following the air traffic controller's instructions.
'The request to fly under those rules is granted routinely in airspace overseen by controllers. Most of the time, visual separation is executed without note.
'But when mishandled, it can also create a deadly risk — one that aviation experts have warned about for years,' aviation experts told the outlet.
The report stated: 'The Black Hawk was 15 seconds away from crossing paths with the jet. Warrant Officer Eaves then turned his attention to Captain Lobach. He told her he believed that air traffic control wanted them to turn left, toward the east river bank.'
If she had turned left, it 'would have opened up more space between the helicopter and Flight 5342,' it added.
Instead, 67 people - everyone aboard the plane and helicopter - perished.
Lobach, from Durham, North Carolina, was an aviation officer in the Army and had racked up around 500 hours of flying time.
She also served as a White House military social aide during the Biden administration.
A critical rule in the industry is that if two aircraft are on a collision course pilots have to be advised if they are likely to merge, according to Federal Aviation Administration (FAA) regulations.
Experts found that did not happen that night and that 'immediate intervention was needed' to prevent the horrible tragedy that left 67 dead.
'Direct, immediate intervention was needed that night. Instead of seeing and avoiding Flight 5342, Captain Lobach continued flying straight at it,' the report read.
Though it remains unclear why Lobach defied orders, Aviation experts predict she may have been 'blindsided' that the American Airlines flight was 'circling' Runway 33 that night.
Investigators now believe the Black Hawk crew did not hear the word 'circling' because they might have been pressing the microphone key to talk at the same time the crucial term came through, according to the report.
'If the key is depressed, the pilot can speak but not hear incoming communications,' it detailed.
There is also no indication that Lobach suffered a medical emergency at the time of the crash, and didn't have pre existing health issues, her loved ones and people close to the investigation told the outlet.
  • 3 months later...
The level of complacency, bureaucracy, and outright darn stupidity in U.S. aviation controls and regulations, that is coming out of this NTSB investigation is nothing short of astounding.
Jennifer Homendy is on the ball again here, as always - she just needs to go a lot further, and to rip a new one, for a lot of people in the U.S. aviation scene. It is utterly mind-boggling that the U.S. Military actively choose to TURN OFF their ADS-B's, in ALL their military helicopters - on the basis of "military security". WTF???? Who puts the military morons into these positions, to make decisions such as this???
This is defying the basic principle of ADS-B's, and turning the aviation clock back 100 years, and placing every RPT airliner at major risk, when the military are operating in the same airspace as RPT aircraft.
What is even more concerning is the inaccuracy of the Blackhawks barometric altimeters, which have been found to have inaccuracies of between 80 and 130 feet. At low level, where the military expectation is to operate at clearances as low as 75 feet, this is just a dozen disasters waiting to happen. It truly is a sad reflection on the U.S., that things have gotten this bad in U.S. aviation.
EDITION.CNN.COM
The first of the National Transportation Safety Board’s three days of investigative hearings is underway to help determine what caused the deadly midair collision on January 29 between an Army helicopter on...
Edited by onetrack
I agree, there have been a number of near misses reported lately. Trumps dumb decision to get rid of a lot of ATC personnel is likely to contribute to this as well.
I think it's right to say the US glorifies and lionises it's military. To an astonishing degree in some of the US military centres, where the leadership are treated like nobility.
I wonder if at times that translates to the military coming first in whatever they do.......with civilian activities expected to fit around that. A mindset.............?
The Blackhawk accident causes are not related to FAA infrastructure, technology or staffing issues. The crash was a direct result of arrogant military aviation leaders who consider they own all U.S. airspace, and they only need to pay lip service to civilian rules and regulations. Why aren't the military aviation leaders getting totally reamed out by Homendy?
They went straight into a RPT flight path, on a training mission, practicing "edge of abilities" piloting skills - as they so often do. They were apparently using night vision goggles.
I didn't see any mention of the night vision goggles in the hearing. We have already lost a Taipan and all the crew here, and NVG's are largely being blamed for that loss, leading to spatial disorientation.
Add in the U.S. militarys constant practise of flight clearances down to as low as 75 feet (no doubt, "to build flying skills"), and the outcome was inevitable. Moronic doesn't even begin to describe this.
Imagine if it was a large RPT full of politicians or military leaders, that the Blackhawk hit? You'd have a total, mega-billion dollar revision of airspace control in the U.S. immediately, as a result.
