jmac Posted March 11 Posted March 11 Hi All, I am building the right wing and have had many discussions with other builders regarding the long-range tank setup. There are three options I am considering, and I would like to get the views of other builders, Option 1 - As in the manual (16mm connector hose to be installed to join tanks), 10mm connector & hose to be installed to be managed with one tapRight tanks.docx Option 2 - Running two hoses (two taps for each wing using the tank 16mm taps and reduce to 10mm) Individually managed Option 3 - Using the 16mm taps and join and reduce to one 10mm hose (managed with one tap) I have attached photos to assist. Any feedback would be appreciated. cheers James
Moneybox Posted March 11 Posted March 11 The bottom option looks the simplest. If you have two valves left and two valves right it could be quite confusing. A single L to R valve would be much easier to select and you are less likely to lose track of what's full and what's empty. 1
Thruster88 Posted March 11 Posted March 11 (edited) I would prefer the tap for each tank option. This gives the pilot control of the system. Most of the time only the inner tanks will be required, it is easier to fill to a know quantity and dip two tanks rather than 4. On a max range flight it is nice to be able to run the outer tanks dry at altitude so when reaching destination the 10-15 litre remaining is in two tanks rather than spread somewhere over four tanks with potential un porting, fuel starvation. With the 4 tank 4 tap system unintended fuel migration and loss out the vents or caps on ground or in flight can be avoided. An electric (facet fuel pump) transfer system with check valve between outer and inner tank is also an option. This gives excellent control over the system. There is more risk of fuel starvation in multi tank aircraft, pilot beware. Edited March 11 by Thruster88 5
Marty_d Posted March 11 Posted March 11 Have a look at @Kyle Communications build logs, he did the four hose/tap into one manifold method and I believe he's very happy with it. 1 1
fallowdeer Posted March 11 Posted March 11 I pretty much copied Mark Kyle and IBob. . After 140 hours in nine months, I’m really liking the flexibility of having four individually valved tanks. 3
fallowdeer Posted March 11 Posted March 11 Hi James When my aircraft was inspected by the CAA they pored over the fuel system in great detail. As the POH and the build manual contained no information about a four tank system I had free rein on the design. As previously noted lots of pitfalls exist in the operation of a multi tank system so I had created the attached document and included it in the POH. This seemed to alleviate the regulator’s concerns. I frequently start up with all fuel valves off at the manifold looking for the low fuel light to come on after using about 100ml of fuel this testing the system as against the button on the panel which is only a bulb test. From experience in normal cruise I’m able to drain any tank completely with the exception of the R/H inner that the return goes to. 3
facthunter Posted March 12 Posted March 12 Non return valves are a good safety feature. You don't want inadvertent transfer or AIR to ever be in the system. With n/r valves and all pumps on you can empty all fuel without a problem of air getting in till there's no fuel in the (fuel) manifold. The pressure while it is there keeps the check valves closed on the empty tanks. Draw a schematic till you understand. You do not need a collector with this system. It has been widely used. Nev 1 1
IBob Posted March 12 Posted March 12 Facthunter, I like the idea of non-return valves. At the same time, I'd be interested to know how they work so as not to restrict flow: the standard (none sprung) one in domestic plumbing is a sort of little trapdoor that has to be installed right way up, as it is closed by gravity. What is the mechanism for aircraft? 1
facthunter Posted March 12 Posted March 12 I don't know what's available. I have operated them and it's not a new idea.. It makes a foolproof system. Nev 1
IBob Posted March 12 Posted March 12 (edited) While my knowledge of fuel systems is limited, it seems to me that the Savannah setup is very well thought out. And for an aircraft of it's size and type, the receiver tank is an integral part of that. It acts as a buffer, effectively guarding against fuel starvation due to momentary unporting of the tanks. And it gives many minutes of warning of fuel exhaustion. The only provisos there are that the level switch providing that warning can fail: that being the case, there is a real advantage to having valving from all wing tanks, so allowing routine ground testing of that switch. And the panel indicator can fail: there is a test button allowing routine testing of that, and in the interest of reliability the incandescent indicator supplied can be changed for a (flashing) LED indicator. Edited March 12 by IBob 2
facthunter Posted March 13 Posted March 13 A lot of certified aircraft have traps for the Unwary built into their fuel systems. The C 54/DC 4 is one such system You can lose the 4 engines. with air in the system. or vent fuel overboard. Nev 1
IBob Posted March 13 Posted March 13 If going to the 4 valve setup as described by fallowdeer above: The rationale for having all 4 valves on the RH fuse wall is to allow the PIC to easily see and reliably operate those valves at any time. However, this mean running the feeds from the LH tanks to the RH side of the fuselage. If doing this, ensure there are no undulations in those pipes, as any high spots may contain air, which the fuel must makes it's way past. My understanding is that most multi-tank setups may experience uneven feeding from L and R tanks, for a variety of reasons. I had uneven feeding until I removed undulations from those pipes. The result is still uneven, but now far less so. (I should add that at no point did uneven feeding affect engine performance.) 1
facthunter Posted March 13 Posted March 13 If you get EVEN feeding from 2 tanks it's a fluke. Slight differences count for a lot. You can't count on it being even. You can equi time them. Nev 1
Kyle Communications Posted March 13 Posted March 13 I always had uneven feeding when I did that system but it wasnt huge. Never had a airlock ever. Except when a bug got into one of the fuel tank breather tubes those silly 3mm tubed out of the fuel caps. So I got rid of them and make the hook style 6mm alu tubes and fitted them to the tank fuel caps..problem be gone then 1 1
jmac Posted March 31 Author Posted March 31 Hi All, I appreciate your help. I have read many stories of experienced pilots who get fuel management wrong, so I want to simplify fuel management. I like the idea of running four taps for fuel control, but my only concern is that I will not have an indicator on the outer tanks. I have read that some leave all taps on for simplicity. What is the best way to manage your fuel tanks? There are so many willing to help. I was lucky to meet Mark K a few months ago for advice on my build. Thanks again for your help. Cheers James
Neil_S Posted March 31 Posted March 31 On 31/03/2025 at 9:17 PM, jmac said: Hi All, I appreciate your help. I have read many stories of experienced pilots who get fuel management wrong, so I want to simplify fuel management. I like the idea of running four taps for fuel control, but my only concern is that I will not have an indicator on the outer tanks. I have read that some leave all taps on for simplicity. What is the best way to manage your fuel tanks? There are so many willing to help. I was lucky to meet Mark K a few months ago for advice on my build. Thanks again for your help. Cheers James Expand Hi James, The outer tanks on my Savvy S feed into the inner tanks, so when I switch them in I wait a short while to allow for the levels to stabilize then double the value seen in the sight gauges. The inner tanks have no switches and simply feed into the tank behind the seat. Nice and simple and has worked OK for me for the last 9 or so years.... Cheers, Neil
Kyle Communications Posted April 2 Posted April 2 I had indicators for all 4 tanks on my first Sav. I ran alu tubes from each tank to the wing roots to the fuel line indicators so I knew exactly how much fuel was in each tank Pictures of all that are in my XL blog on here. it starts on page 5. https://www.recreationalflying.com/forums/topic/9712-another-new-savannah-xl-on-its-way/page/5/ 1
jmac Posted April 7 Author Posted April 7 On 02/04/2025 at 3:09 AM, Kyle Communications said: I had indicators for all 4 tanks on my first Sav. I ran alu tubes from each tank to the wing roots to the fuel line indicators so I knew exactly how much fuel was in each tank Pictures of all that are in my XL blog on here. it starts on page 5. https://www.recreationalflying.com/forums/topic/9712-another-new-savannah-xl-on-its-way/page/5/ Expand Thanks Mark, Like the idea of a fuel gauge for each tank. cheers
jmac Posted April 7 Author Posted April 7 (edited) On 31/03/2025 at 10:58 PM, Neil_S said: Hi James, The outer tanks on my Savvy S feed into the inner tanks, so when I switch them in I wait a short while to allow for the levels to stabilize then double the value seen in the sight gauges. The inner tanks have no switches and simply feed into the tank behind the seat. Nice and simple and has worked OK for me for the last 9 or so years.... Cheers, Neil Expand Hi Neil, You don't have fuel stops in the cabin for each wing, just between the tanks? cheers Edited April 7 by jmac
jmac Posted April 7 Author Posted April 7 On 11/03/2025 at 10:06 PM, fallowdeer said: I pretty much copied Mark Kyle and IBob. . After 140 hours in nine months, I’m really liking the flexibility of having four individually valved tanks. Expand Really nice setup. If all taps are on, does it self-level? cheers
jmac Posted April 7 Author Posted April 7 Thanks again for the feedback. I do like the idea of 4 taps for individual control. If I was to go with the single tap for each wing for simplicity which option is prefered between Opt 1 & 3 cheers I really enjoy building this aircraft. Managing fuel on a trike is simple (one tap) This fuel setup has taken longer than expected. Am I just overcomplicated this?
Neil_S Posted April 8 Posted April 8 On 07/04/2025 at 10:08 PM, jmac said: Hi Neil, You don't have fuel stops in the cabin for each wing, just between the tanks? cheers Expand Correct. And of course the fuel shut off valve to the engine under my seat.
jmac Posted April 8 Author Posted April 8 On 08/04/2025 at 12:38 AM, Neil_S said: Correct. And of course the fuel shut off valve to the engine under my seat. Expand cheers
fallowdeer Posted April 8 Posted April 8 Gidday James. Our experience has shown with all taps on the tanks often empty at different rates, ending up with surprisingly different amounts in each. The theory is that this is caused by slightly differences in internal pressure from variations in the vents. If I was to build again I’d install cross venting. So I never fly with all open, the last thing I want is a little bit of fuel in four tanks. I’ve done a lot of long trips and I just run the outboards dry as I described above. With each tank holding 36 litres and burning around 16.5 an hour at cruise I find I get about 1 hour 40 minutes out of an outboard tank. The difference is the fuel returned to the starboard inner. 1
Kyle Communications Posted April 9 Posted April 9 I ran only one vent for each of the tanks and in the caps and it worked fine except with the original 3mm tube vent in the caps a insect blocked one and I could not access a full tank of fuel. I modified that system the very next day. Its all on my blog. I made forward facing alu 6mm tubes mounted into the tank caps.. I could drain each tank individually. The 2 inlets at the top of the reseverve tank I made 1 the input from all tanks the other ran a vent line to the top of the inner right side of the wing tank the same tank the engine overflow goes to so always make sure the reserve tank can never get a vapor lock and will always drain Mark
