11 hours ago, facthunter said:
None like that. The ones I recall can't stay open. You had to push them up to get fuel to exit.. Viton is for heat situations,. I wouldn't like relying on an O ring that can break and Leak a lot.  Nev
these don't stay open either. you push the fuel tester against the spring pressure to get fuel.
Two different taps ! .
One a quick test of fuel.
The other to drain your " gascolator " , at the days end.
Those threads are the same pipe thread ( tpi ) . just one is tapered , to seal with-out thread tape .
spacesailor
One of the types Illustrated WILL stay open. if it's rotated anti clockwise when pushed in.  A Tapered Metal to metal seat will seal and it helps if it is rotated occasionally.  IF the O ring is not the right material for the fuel it will fail fast and you will have a significant leak that you might not notice.    You should not drain old fuel onto the ground either . Nev
Mine goes into a fuel receptor on my ride on mower🙃:plane:
  • Like 4
I've used Curtis fuel drains for years and replaced the O-ring seal. If the O-ring wasn't there fuel would just run out. A standard fuel tester with its castellated notched top fits the horizontal rod and a push up allows fuel to flow in to the tester tube. While pushed fully up twist the tester to the right and the valve will lock open & you can drain the fuel in the tank in to a container. A good quality brass reliable fuel drain. I have never had to replace one, just the O-ring.
All good BUT
  • To what What Curtis fuel drain are you referring??
AND
  • What part number and/or dimensions are the "O" rings.😈
Edited by skippydiesel
