BrendAn Posted July 17 Author Posted July 17 11 hours ago, facthunter said: None like that. The ones I recall can't stay open. You had to push them up to get fuel to exit.. Viton is for heat situations,. I wouldn't like relying on an O ring that can break and Leak a lot. Nev these don't stay open either. you push the fuel tester against the spring pressure to get fuel. 1
spacesailor Posted July 17 Posted July 17 Two different taps ! . One a quick test of fuel. The other to drain your " gascolator " , at the days end. Those threads are the same pipe thread ( tpi ) . just one is tapered , to seal with-out thread tape . spacesailor 1
facthunter Posted July 17 Posted July 17 One of the types Illustrated WILL stay open. if it's rotated anti clockwise when pushed in. A Tapered Metal to metal seat will seal and it helps if it is rotated occasionally. IF the O ring is not the right material for the fuel it will fail fast and you will have a significant leak that you might not notice. You should not drain old fuel onto the ground either . Nev 1
Blueadventures Posted July 18 Posted July 18 6 hours ago, facthunter said: One of the types Illustrated WILL stay open. if it's rotated anti clockwise when pushed in. A Tapered Metal to metal seat will seal and it helps if it is rotated occasionally. IF the O ring is not the right material for the fuel it will fail fast and you will have a significant leak that you might not notice. You should not drain old fuel onto the ground either . Nev Mine goes into a fuel receptor on my ride on mower🙃 4
kgwilson Posted July 18 Posted July 18 I've used Curtis fuel drains for years and replaced the O-ring seal. If the O-ring wasn't there fuel would just run out. A standard fuel tester with its castellated notched top fits the horizontal rod and a push up allows fuel to flow in to the tester tube. While pushed fully up twist the tester to the right and the valve will lock open & you can drain the fuel in the tank in to a container. A good quality brass reliable fuel drain. I have never had to replace one, just the O-ring. 1 1
skippydiesel Posted July 20 Posted July 20 (edited) On 18/07/2025 at 9:43 PM, kgwilson said: I've used Curtis fuel drains for years and replaced the O-ring seal. If the O-ring wasn't there fuel would just run out. A standard fuel tester with its castellated notched top fits the horizontal rod and a push up allows fuel to flow in to the tester tube. While pushed fully up twist the tester to the right and the valve will lock open & you can drain the fuel in the tank in to a container. A good quality brass reliable fuel drain. I have never had to replace one, just the O-ring. All good BUT To what What Curtis fuel drain are you referring?? AND What part number and/or dimensions are the "O" rings.😈 Edited July 20 by skippydiesel
