BrendAn Posted 12 hours ago Author Posted 12 hours ago 11 hours ago, facthunter said: None like that. The ones I recall can't stay open. You had to push them up to get fuel to exit.. Viton is for heat situations,. I wouldn't like relying on an O ring that can break and Leak a lot. Nev these don't stay open either. you push the fuel tester against the spring pressure to get fuel. 1
spacesailor Posted 31 minutes ago Posted 31 minutes ago Two different taps ! . One a quick test of fuel. The other to drain your " gascolator " , at the days end. Those threads are the same pipe thread ( tpi ) . just one is tapered , to seal with-out thread tape . spacesailor 1
