aro
Everything posted by aro
  1. It's not about making you safer, it's about limiting the risk to the people around you. You can make your own decisions and choose your own risks, but limited speed and limited weight limits the kinetic energy available to cause damage. Back in the AUF days, exemptions were negotiated on the basis that the ultra-light weight of the aircraft meant that risk to others was insignificant. On that basis: You can fly without a CASA license You can do your own maintenance You don't need an aviation medical Aircraft don't need to be certified to the normal GA standards as long as the weight and stall speed were below specified limits. In the early AUF days the weight limit was 450kg. Then it was raised to 480kg. Then 544kg. Then 600kg. Now talk about 760kg, and campaigning for higher stall speed as well. When do you get to the point where the ultralight exemptions become unjustifiable? Already exemptions are being wound back, e.g. stricter licensing, stricter maintenance, stricter medical requirements. The CASA RPL is an additional danger for the RAA - at some point the differences with the RPL will become unjustifiable and requirements are likely to be merged. Don't be surprised if e.g. suddenly you need a RPL medical and LAME maintenance in return for higher weight limits. And I doubt that there will be sub-categories based on weight operating under RAA.
  2. You're over thinking it. Speed is how fast you are travelling, not what the instruments say (just ask the police!) A legal reference to speed must be CAS - or probably more accurately TAS at sea level in a standard atmosphere.
  3. There are something like 40 pages of statistical analysis in the report. This information is there. If you want to criticize the statistics, maybe it would be worth opening the report first?
  4. How many fatal crashes would you need to see to consider it significant?
  5. The most dangerous place is final approach when everyone funnels into 1 flight path in line with the runway. The closer you get to the runway the less variation there is in flight paths. The rest of the circuit is designed to allow you to locate other aircraft and plan separation, before you are on final approach. If you don't fly a standard circuit it makes it more dangerous, not less. CASA has decided that radios provide sufficient safety for straight in approaches and joining on base. That might be true, however straight in approaches are hard to slot into regular circuit traffic. In theory the aircraft on the straight in is supposed to give way, in practice the aircraft in the circuit are the only ones with practical ways to adjust the spacing.
  6. You don't get to run the case, you hand it over to the insurance company. They don't want to bet their money on your experience. In our case (I assume typical for a relatively small case) I saw no evidence that the PI lawyers or the insurance company actually left their offices to investigate facts, it was all done by letters and phone calls. The PI lawyer wants the insurance company to look at the list and say "Can we refute ALL of those allegations? We're not sure, better not risk it, lets settle." It all changes of course for a large case like Turboplanner's of course, but they are the minority. In reality you probably don't have much to worry about because the PI lawyers would rather go after the council, because they almost certainly have a bigger insurance policy.
  7. Do you think so? Lets write this up in the style of a personal injury lawyer. Remember they don't have to prove anything unless it goes to court, even then the standard is "balance of probabilities" i.e more likely than not it happened - much lower than the standard in e.g. a criminal trial. The PI lawyer doesn't want to go to court. They want to convince the insurance company that they also do not want to go to court, they would rather settle. So the PI lawyer builds a list as long as they can of points they would require the insurance company to argue against in court. The Defendant sprayed lubricant on the swing. The Plaintiff slipped and suffered injuries due to overspray of lubricant on the chains. As a result of the Defendants actions in applying lubricant to the swing, they owed a duty of care to users of the swing. The injuries to the Plainiff are a result of the negligence of the Defendant. Particulars of Negligence The Defendant: Performed maintenance on the swing without authorization Performed maintenance on the swing without adequate training Performed maintenance on the swing without adequate materials Failed to take adequate care when performing maintenance on the swing Used an unapproved lubricant on the swing Used spray lubricant on the swing resulting in overspray on the chains Failed to prevent overspray settling on the chains Failed to clean overspray off the chains Caused the swing to be in a dangerous condition Caused a danger to the Plaintiff Failed to warn the Plaintiff that the chains were slippery Failed to warn the Plaintiff that the swing was dangerous Allowed the Plaintiff to use the swing when it was in a dangerous condition Failed to notify the council that the swing was dangerous Failed to notify the council that the swing required maintenance etc.
  8. I still have the claim, you prompted me to look it up. There is various stuff like failing to keep a lookout, failing to provide a ladder, unnecessarily exposing him to the risk of injury, permitting him to climb the flagpole, permitting him to put himself in a position of danger etc. Failing to warn him of the danger of climbing the flagpole is expressed with about 5 different wordings. There's nothing there that wouldn't apply to any organization with a flagpole. No-one instructed him to climb it or knew he was going to try. He was a volunteer. He tried Workcover first but they denied coverage. We were 3rd in line - he also tried the volunteer organization that referred him to us, but their insurance company also denied coverage. That's not true for out of court settlements. No-one has to prove anything. They just have to convince the insurance company that they would rather pay than argue in court - and that's not hard for small settlements. Small out of court settlements are actually good for insurance companies. They make their money from people buying policies, and a flow of small out of court settlements encourages claims, which encourages people to buy policies. If no-one sued, no-one would buy policies. It's the big multi-million dollar claims that insurance companies don't like. A steady, predictable flow of relatively small payouts is the fuel that powers insurance companies.
  9. I think you have a very rose-tinted view of the public liability issue. The majority of cases wouldn't see the inside of a courtroom, and people are thinking more about Profit and Loss than Donoghue and Stevenson. We got sued a few years ago by a guy who climbed a flagpole, slipped, landed on an object which HE HAD PLACED at the bottom of the flagpole and broke his leg. The suit alleged that we were liable because we had: Failed to adequately train him not to climb the flagpole Failed to adequately supervise him and prevent him from climbing the flagpole Failed to maintain the flagpole in a condition where people would not fall from it and be injured + half a dozen more alleged failures It's hard to imagine this succeeding in court on the basis of Donoghue v Stevenson, but no-one wants to go to court. They just go backwards and forwards for a few months for appearances, then pay a settlement.
  10. To correct myself: I went and read the source regulation, and there was a formatting problem in the paste in this thread. "the aircraft can land at, or take off from, the place safely having regard to all the circumstances of the proposed landing or take off (including the prevailing weather conditions)." isn't part of 2(a)(iv) it is a separate clause applying to all aerodromes. 2(a)(iv) authorizes anywhere that is suitable to land and take off an aircraft 2(b) says for certified, registered, defence aerodromes and places that are suitable (i.e. everywhere) you need to be able to do it safely. In any case this shouldn't be controversial, and I don't think there have been recent changes (except perhaps to numbering).
  11. Of course it's how it operates in practice. 2(a)(iv) covers every operation at a location that is not a certified, registered or defence aerodrome. These operations are happening all the time, but CASA doesn't want to be involved in assessing every farmer's paddock that they want to use as an airstrip. The regulation says that the pilot must not use a location that is not a certified, registered or defence aerodrome unless it is suitable and safe. What is the argument with that? I recall covering this in theory classes 20+ years ago. The question was where can you take off and land, the answer was CASA has effectively authorized the whole of Australia for use as an aerodrome as long as it is safe to do so. If you have an accident e.g. put a wheel in a rabbit hole it would be strong evidence that the location was not safe so you have contravened the regulation. The safe and suitable clause in this regulation doesn't apply to certified or registered aerodromes, so if you put a wheel in a rabbit hole on a certified or registered aerodrome you have probably not contravened this regulation. The rule doesn't appear to have changed significantly, and I haven't heard anything about CASA prohibiting operations from locations other than certified and registered airfields, OR absolving the pilot of the responsibility to ensure it is safe.
  12. That regulation is in fact very permissive. CASA is basically authorizing you to use ANYWHERE as an aerodrome, as long as it is suitable for landing and taking off aircraft and you can do it safely. it's hard to imagine how it could be less restrictive. Do you want to land in a paddock? Operate your helicopter out of your backyard? This is the rule that allows it - as long as you can do it safely. Of course, there may be other rules that apply - landowners permission, council, national park rules etc. but CASA are authorizing you to land where-ever you like.
  13. More information about how accurately they flew the book figures would be useful. E.g from an online POH the C182 performance calculation is based on an initial climb at 58 KIAS. If you let the speed build past that it will use a lot of extra runway. Allowing the speed to build to 66 KIAS would account for at least 30% extra ground roll compared to 58 KIAS. (66/58 squared, which assumes constant acceleration. Real life is probably worse) Likewise the landing figures specify heavy braking. They said they used moderate braking which could easily account for 30%. Another thing to be aware of with braking - braking early when you are still going fast counts the most. Heavy braking when you have already slowed down doesn't make as much difference - the runway is already behind you. Having said that, the book figures are very short and most of us would be challenged to achieve them. 433 feet is 132 metres. Add 50% and you are still below 200m, which would make you stop and think in a 182 I reckon...
  14. As a rule, the airworthiness standards do not apply to EAB aircraft. No-one is going to certify your EAB aircraft is airworthy or meets any airworthiness standard. That is 100% up to the builder. You can build what you like, and power it with whatever you like. Then it is between you and your AP what restrictions need to be applied in the interests of public safety. For the original question, you definitely need to talk to the SAAA. They have people who are on top of all the details.
  15. For a VH registered EAB aircraft, the details are in CAR 262AP: (4) A person must not operate an experimental aircraft over the built-up area of a city or town unless authorised to do so under subregulation (5). (5) CASA or an authorised person may authorise a particular aircraft to be operated over the built-up area of a city or town subject to the conditions and limitations CASA or the authorised person considers necessary for the safety of other airspace users and persons on the ground or water. As far as I know there are no specific requirements for engines etc. It is all down to the judgement of the Authorised Person whether it is permitted and what conditions and limitations are applied. If you are planning building and want the ability to fly over built up areas, it would be worthwhile to talk to the SAAA and an AP who could issue the authorisation, and see what they would consider disqualifying. Even if you have a certified engine there can be other reasons the authorisation might be denied, e.g. the particular aircraft design, build issues etc. But the earlier you talk to the AP about what they would require, the better.
  16. I don't think that there is any intention is to do an evaluation of quality or to uncover fly-by-night or backyard operators. The intention seems to be solely to ensure that the kit meets the major portion (51%) rule. So it is intended to uncover operators who provide a kit that is too complete i.e. not enough work for the builder to meet the major portion rule for amateur built registration.
  17. I'm fairly sure there isn't a fuel pressure gauge in the injected C172 I have flown. Fuel flow definitely, but not fuel pressure.
  18. So what weight limit do you need to bring the stall speed down to 45kt so it is RAA eligible?
  19. 600 kg should bring it down to 49 by my calculation. 45 would require 510kg.
  20. What's the stall speed? Isn't the maximum stall speed 45 kt for RAA?
  21. The OP is flying in Switzerland, most of the replies relate to Australian procedures. Without being familiar with Swiss procedures it is hard to provide advice. I'm not sure that there is much else that could have been done - it sounds like one of those close encounters that are very rare but hard to avoid. Turning may or may not help - a turning aircraft is easier to see, but banking also creates a much larger profile for a collision.
  22. Serves me right for trying to reply to 2 messages in one post rather than double posting. Only #1 was referring to your message. The rest was in reply to Turboplanner. My argument is with the assertion from Turboplanner that: I doubt that that information is in BAK because it is often not true. (You would know better than I what is in the BAK, I am happy to be corrected.) The full flap balloon over an obstacle is often (wrongly I think) taught as a way to get extra obstacle clearance over the POH/AFM technique. Either way I don't think using full flaps for obstacle clearance is good information to give to a student studying for BAK.
  23. It was me who said that. I wasn't suggesting that you crashed, just that it wasn't a technique that should be taught in BAK. 70 feet is a big balloon. The technique was demonstrated to me when I did my PPL, from memory the typical balloon was 10-20 feet. It was supposedly a way to clear fences, not trees. You can't create energy from nowhere. The energy for a balloon comes from airspeed. Flaps may be useful if your airspeed is low enough that trading it for altitude puts you at risk of stalling. However in that case you only have energy available equivalent to the difference between stall speed with and without flaps, which isn't 70 feet worth in our aircraft. If you started at 100 knots and had 70 feet worth of balloon energy, the elevator should have been sufficient. If the flaps cause extra drag, you will end up with more energy at the top without them. However flaps might change the trim enough that the aircraft pitches up with less elevator input, giving the impression that the flaps produced the climb. Consider the situation in this thread: For maximum performance (recommended for high density altitude), he needed flaps 0 and 59 knots. Instead they had flaps 10 (flaps 10 recommended climb is 56 knots) and 65-70 knots and at the high density altitude they weren't climbing. Do you think dropping full flaps would have helped them over an obstacle? It might have given them 10 feet if they timed it right, but then they would have been sinking rapidly. As I said in that thread, know the configuration that gives best performance and the speed you have to fly to achieve it. You can put that in the BAK.
  24. Every time I line up on the runway I rely on the theory of flight, I haven't been disappointed yet. If you feel you have discovered situations where the theory doesn't hold, people would be interested. Just pulling back at 100 knots and trading altitude for airspeed should give you about 200 feet by the time you're down to e.g. 70 knots. You can try this at altitude if you don't believe the theory. Setup for 100 knots straight and level, pull back into a climb without touching the power - by the time you are down to 70 knots you should have gained 200 feet.
  25. Full flap would be unusual though? There is folklore that I have heard a number of times that the best way to clear an obstacle is to put in full flap as you fly towards it. Sure, the aircraft is initially likely to balloon. But what happens then? Maybe you climb away - depending on the airspeed and the aircraft, maybe even at a greater angle. But depending on the airspeed (e.g. too high) you could even sink again. So you really need to time the flap input. When it works, people are around to tell us. When it doesn't, maybe not... I hope this is technique is NOT actually being taught as part of BAK.
