Blueadventures
  1. The white rod gives great support to the wing to relieve stress on the rear tube pivot bolt and framing. Worth making and other forum member got my support set.
  2. Trailering should be kept to a minimum and when folded better to have additional supports attached to the leading edge wing tube to the fuse near the main leg attachment. I had such a set for mine. Keeps the wing more rigid.
  3. PM your email and I'll send copy of the schedule they may not like it posted public. or better still ask them for a copy as your interested in a next one. Cheers.
  4. I could understand the office missing a point or two; but the instructor has heaps of contact time with the student so no excuse IMO. And any coverup is unacceptable and seems will be dealt with.
  5. She does good Fish and Chips; got to like some of her ideas though.
  6. Don't forget you guys are lucky enough to have Aircraft Spruce there as well. However Brisbane / Queensland has the Premiership Cup. 🦁🏆; with Fitzroy so I'm incorrect here;
  7. That adds to the persons experience with flight in addition to the recent training he did. para glider flight time would have instilled an appreciation of weather; hope the Coroner heard such.
  8. Thanks , that would help explain his fast learnings to solo; hope the Coroner heard this sort of info; they can only decide on what they hear in the court and what they read up about.
  9. Rob at Coastal Aviation on Sunshine Coast is worth a call he has many parts available and can make.
  10. Would be good to know how many touch and goes he did under instruction and the weather as that would have displayed his ability to the instructor pre first solo. Also; his flying experience in other types and xc experience in them. I haven't read that detail anywhere.
  11. We had similar up this way where a GA aircraft hit the hills in poor weather, pilot didn't complete his training to solo level but chose to fly, Both he and his wife were killed unfortunately. In this one an instructor signed him off and the pilot involved decided to fly the route. My very limited information on this is along the lines that he achieved solo and was granted x/c at some time and the instructor is not with us to explain his reasoning. Seems x/c at least was not supported with his RAA flight times. When I gained my certificate same person at RAA advised my gliding XC was not able to be transferred or recognised so had to jump all the hoops. Thier are a small number of poor performance decisions identified by RAAus, one example is bfr done with instructor being separated by 400 or so kms at the time, over phone deal and there would be a few more I'd guess. My belief is don't blame RAAus 100% and there is learnings from this.
  12. Agree, going on top and being only VFR trained and VFR equipped is playing 'Russian Roulette' with more than one in the chamber, IMHO.
  13. From Floods, I had inquired about courses in the past so they may have a list of those who have inquired in the past or a general email to customers. Floods email.pdf
  14. You may be closer than me to Floods, I'm attending the Jab course and only 7 hours down the road by car; Floods is 27 (+20 hours).
  15. Received an email survey to seek interest in maintenance courses for Rotax by Floods in early April which is similar to the RAAus / Jabiru course set for 3 & 4 April. Great to see as Rotax were unavailable through the Covid times and were looking at online; but I'm all for hands on and Jabiru have had more frequent training courses available. Maybe they were both asked to ensure this sort of training is available.
  16. These are the silicone hose and alloy pipes on my 912ULS coolant setup. (Note the image of port side of engine is an old one and shows the black rubber hose, its changed to blue silicone years back and I'll get an up to date image.) The alloy coolant pipes are great and from Flylight Airsports in UK ; they are great and reduce the long lengths of hose that some people use. (The exhaust wrap is a mix of white and gold colour tape.)
  17. Found using a forklift with wing on a mattress was perfect for removal and refitting wings. The springiness of the mattress allows for small movements to allow removal and refit into attachments. Then when inboard is connected use a jack to support to fit struts. Doing the 2,000 hourly wing bolts and some other things. New motor to go in next on this A32. First wing removed with 3 people, owner thought up using forklift and it's a winner. I’ll be using same when I do my Nynja wing upgrade in a few weeks.
  18. This guy had tube for sale on 2nd January.
  19. This is the Rotax reference for info as well. Rotax 912 ULS performance data.pdf
  20. Best to contact the manufacturer or agent for upgrade info. For example early Foxbat 22's where high 400 kgs and with upgrades went to low 500's but unable to upgrade to 600kgs. The lower / earlier ones had metric fasteners and the 600 kg variants now have AN hardware and beefed up in other areas. Alos the 600kg Nynja have AN hardware in upgrade kits and thicker brackets, upgraded strut build and brace wire size. Seems LSA requires AN hardware now. Yours may be a similar situation, I don't know about them.
  21. Looks like there was an option for a larger factory tank and the document was a general print version. Maybe worth contacting an agent or factory in Europe and they may have details of your aircraft build.
  22. This aircraft build similar to the Saphire was available a year ago, have you looked at it before?
  23. Make a nut from 3mm flat and tap thread. Will work.
  24. Also does the log and other paper work contain its original or a recent w&b; if not try RAA maybe to get a copy if they can provide it. Some paperwork is only available to the first owner sometimes.
  25. Needs to be installed and signed off and includes rego marks etc.
