FlyBoy1960
Members-
5
Everything posted by FlyBoy1960
FlyBoy1960 replied to Kyle Communications's topic in AUS/NZ General Discussion
With only 200-300 years of "semi-accurate" climate records, and maybe 50 years of accurate climate records, for a planet thats billions of years old, who really knows what the typical climate should be/is ? We just don't really know if a few hot years following an ice age is normal. Just a personal opinion/observation not a researched scientific opinion. -
Why do you need fresh water for cooling ? Whats wrog with ocean water ? -
Just put a Sub off the coast and run a power lead to the mainland, one for each major city. Problem solved -
I dont seem to have a problem unless your getting in from the rear vision position, at the other end it as big or bigger than other SUV type vehicles imo. Maybe you need to get in like its an aircraft with small doors.. Head first ? -
This is the only thread with a lot of activity in a long time, let-it-run, i say. For old and moldy the Tesla Model Y is a great choice, like a model 3 but higher off the grond so the seat height is say 200 mm higher and plenty of headroom also. I have about 150 mm above my head and i am 186cm tall (6'2"). You seem to fall into the seat reather than drop into it because its high and easy. -
I know that if I have the vehicle out of chill mode into sport mode, if I have the air conditioning set below 20° and if I have the sentry mode activated to run 24-hours every day it uses quite a bit of battery. There are also other settings which can stop the cabin from getting really hot called vent mode which will put fresh air into the car once it gets to a set temperature, there is also dog mode that keeps the vehicle at 24° so you can leave your dog inside a parked car (something I would never do anyway) but the alarm and sentry mode seems to be a really big power drain. Even when the vehicle is just parked it runs about 5 cameras and records everything to a hard drive. If I parked overnight I could notice 3 or 4% drop in the battery just from running the cameras overnight so I now have it turned off whilst I am at home because the vehicle is locked in a garage. It will still record and the alarm works if the vehicle get bumped or if somebody walks really close to the vehicle but it is not recording 24/7 in 4K with this setting turned off. Overnight i have zero battery drain now. -
You are correct I do have this model, I drive like a little old lady going to church, i have it running in chill mode because it limits the performance, even in this mode it exceeds my speed requirements. 90% of my operation is stop and start below 80 km/h just in a normal residential area with a few linking roads that run at 80 and the rest are at 50. 10% is highway use, but I use all of the technology to drive for me, and again it regulates the speeds, acceleration rates and optimises the use of regeneration for breaking which can sometimes be a little frightening because it leaves it till really late so it gets the best regeneration available. -
Let me add my ten cents worth I own a new Tesla Model Y vehicle, now with about 4,000 km After the rebates in Queensland it cost just under $53,000 on the road with a full charge ! I have 8.8 kW of solar panels on my roof because I have been trying to reduce my power costs for some time. I have installed a car recharging unit called the Zappi, and I have this set up to only recharge my vehicle on 100% solar. If I was not recharging the vehicle I would get a $0.05 credit per kilowatt hour put back into the grid (which is an absolute joke), so I therefore cost the vehicle running charges at $0.05 per kilowatt hour because this is what I would be getting back if it went into the grid instead of into the car. Using the Tesla app, it is showing me the total cost of recharging for about 4,000 km is $27 based on $0.05 per kilowatt hour which I have put in as the charging cost. Summary: I have a vehicle which is significantly cheaper than anything else the same size like a traditional SUV. A hilux or a raptor does not give you much change out of $70,000 and yet I "only" spent $53,000 which is expensive to most of us, but by comparison to most comparable vehicles, a reasonable price for what I have received in my opinion. I have my charging set up so I don't need to have any out-of-pocket expenses for the use of my vehicles electricity and recharging. I have a 450 km range which is good enough for 99% of my driving as I expect it would be for 99% of people with this type of vehicle. If I ever go on a big trip which will require remote recharging I have the expectation that I will have to take a 30 minute break, I may even need a one hour break if I need to wait for a charger. I may have to pay $30 or $40 for said electricity to recharge, but my attitude is, I am so far ahead that it doesn't really matter. If I have any concerns about using this vehicle on a big trip then I am fortunate to have a little Renault which uses on average 5.3 L per 100 km from the surprising performance given from the 1.5 L turbo diesel engine. There is no one vehicle that is going to suit everyone's needs, just as there is no one aircraft that suits everyone's needs. Some people need to be landing at 25 kn in a cub type aircraft, some people don't care they just want to do 200 kn to get from A to B. I am the first to admit an electric vehicle won't suit everybody, especially if you are in a country area say 6 hours out of the city. This type of location would make it difficult to get any benefits but for me, with my longest trip under 2 hours return it is near ideal for all of the reasons I have mentioned above and I'm also to have access to my Renault for the time that using an electric vehicle does not suit. -
Trouble is no-one wants it in their backyard. Why not put the plant on one of those little offshore islands ? Whats the name ? That's right, Tasmania! -
How well does that work on the outer suburban and highway cycle? Show me a highway in ANY city that is not stop and start, i would say they are perfect for this use. -
The plane regererates 8-11% of the power used in the circuit during the landing process, BUT it requires a steep approach -
the only thing I can think of is that extreme cold temperatures are reducing the flight time but I remember reading that if the battery was warm from being recharged then it had no effect on the endurance. If the battery had been recharged 3 days ago and the aircraft had been in subzero temperatures since then then yes they would be a reduction in the endurance. I don't imagine however any flying school leaving these outside for any length of time. Perhaps you mess read the article and it was 25 minutes in the training area or something like that. You can download the POH of the Internet, I did this some time ago and it was an interesting read with some new conceptual ideas on how to fly an aircraft -
The aircrafts purpose is abinitio training, remember there is no run-up, or warmup, you taxi straight to the run-up bay and do all of your talking for the upcoming flights with the engine basically off. It works out cheaper because you are not paying all of the ground time and warm up time. 50 minutes of circuits is basically 90 minutes in the aircraft for a pilot doing his first let's say 10 hours. For this mission and purpose I would say they are ideal. The other benefits are much lower operating costs although when you factor in battery replacement in reality it is only about 30% cheaper than a gasoline powered aircraft. The big benefit is reduced or almost zero noise impact at the airfield so you can start your circuits at sparrows fart and not wake up any of the locals. They are not perfect yet, far from it but they are certainly knocking on the door of the future. -
There is one at our airport and it does 50 minutes of circuits. -
50 minutes PLUS 30 minutes reserve. Where do you get 25 minutes from? Also the weight is wrong ? Anyway rather than look it up, just make it up instead, its easier. -
Yeep. We have progressed so far !
The title is wrong, it should be "Morgan Rebuild" A restoration inspires thoughts of an aircraft with many years of flying, something of great historical value. I must be board to even waste everyone's time by commenting. I must get-a-life.
New engine design to keep an eye on
I think you are being a little bit tough on Kyle, I hadn't seen this engine online before and it was interesting to watch the video but as soon as I found out that the thumbnail for the video had a photograph of Elon Musk standing next to the engine (photoshopped) and the fact that it was 20 years in development and hasen't got anywhere started alarm bells going off for me instantly. The comments were not warranted just because somebody had not seen this before like myself. The comment would have been much better if you said something like "this product has been featured before, here is the link where we have been discussing". Maybe I'm just not tough enough to be here. -
I just LOVE the way they have Elon Musk on their thumbnail, any legitimate company would not be using his likeness in an effort to get clicks. If what is written above is true and they haven't got it right after 20 years then what hope have they got. Unfortunately, the older I get, the more I can say, that I have seen it all before. But, thank you for bringing the video to my attention -
4.11.23 Cloncurry light plane crash
FlyBoy1960 replied to trailer's topic in Aircraft Incidents and Accidents
Gulfstream Aerospace Jetprop Commander (twin-turboprop) https://www.flightaware.com/live/flight/BDOG370/history/20231104/0045Z/YTWB/YBMA Decent of more than 10,000 fpm at one stage. It dropped like a rock ? -
Ring them up and ask ! Simples. -
Bydanjohnson Rumours About A New Pipestrel Trainer
FlyBoy1960 replied to mnewbery's topic in Aircraft General Discussion
they are all the same regardless of the energy provider. Agl has a solar saver program that gives you $0.15 per kilowatt limited to 10 kW per day so basically this is $1.50 but there solar meter charge on this plan is also more expensive than it is on any other plan so you are effectively getting back to your $0.05 per kilowatt. It is all smoke and mirrors intended to confuse people especially people that don't understand electricity. I have this in writing from agl when I asked them why the plan I am on and the meter charge is only and (I'm using guesstimates here because I don't remember exactly) $1.00 per day but on the solar saver's plan it was $1.50 per day for the exact same meter. The answer was that because power was travelling both ways through the meter that it would wear out quicker and need to be replaced earlier and that is why they have to charge extra for the meter if you are getting $0.15 per kilowatt hour than you would be getting with $0.05 per kilowatt hour. I emailed the consultant back asking her more questions about this and she proudly told me how she had just come back from training and this is what they were told if anybody ever asked about the different metre charges. ? These people should not be allowed to reproduce ! -
the problem is now that our lousy government has allowed the power companies to do 2 things. Reduce the rebate from solar panels going back into the grid from $0.30 down to 0 cents or at best $0.05 per kilowatt hour increase the meter charges if you have a solar panel system on your roof. They have increased the meter charges by about $1.50 per day completely negating what your solar panels can put in at $0.05 per kilowatt hour we have been sold this fantastic idea of putting solar panels on your roof and having the ability to pay everything off in 5 or 10 years depending on where you are located. They then change all of the rules in cooperation with the power companies so now I am a power generator/provider for the power companies. I am generating electricity for them for which they are paying me $0.05 per kilowatt which is negated by the increase in the meter charges so I am giving them dozens of kilowatt hours per day for nothing and they are happily selling that power for $0.40 per kilowatt hour. There really should be a Royal Commission into this because it is theft on a grand scale. They should lock in the pricing that they offered when they sold us the solar systems -
Well, my Tesla charges 100% from Solar Power. It is hooked into my solar panels through a charger called the ZAPPI. I have it set in eco-plus plus mode and it charges at about 8 kW when the sun is out. Since I have owned it I have never needed to pay for one cent of electricity! A friend has one exact same unit but 3 phase in his work and it can charge at 22 kW because it is three-phase and has more cells. I am limited to single phase at home. One day I will have to pay for energy if I travel to somewhere further than what I travel 99% of the time but for me now, this is the absolute best for my pocket and supposedly the planet.
