rep003 Posted July 13, 2019 Share Posted July 13, 2019 To replace or not to replace , that is the question . I have an Airborne Edge Outback 582 & although the hours are low , and it's been stored in a hangar , It has sat for years. It doesn't seem to me that the shock cord is as tight as those who share the hangar ... so Just replace & be done with it, or retighten & reattach ? Crimps or cable ties ? Any suggestions , tips or tricks greatly appreciated . Cheers Troy Rep. Link to post Share on other sites
onetrack Posted July 13, 2019 Share Posted July 13, 2019 Rubber degrades with age and the effect of sunlight, and the small percentage of ozone in the air. Even if kept in dark conditions, rubber components still slowly degrade, by hardening and losing strength. 5 years is a regularly recommended changeover period for critical rubberised components, you might be able to run them for 10 years, if they're kept in dark, covered conditions. I'd say replace them. 1 4 Link to post Share on other sites
pmccarthy Posted July 13, 2019 Share Posted July 13, 2019 Like a condom in a wallet? 3 Link to post Share on other sites
440032 Posted July 18, 2019 Share Posted July 18, 2019 We can't take you anywhere Peter, can we........................ Link to post Share on other sites
spacesailor Posted July 19, 2019 Share Posted July 19, 2019 BUT Dam good advice !. LoL spacesailor Link to post Share on other sites
Keenaviator Posted August 6, 2019 Share Posted August 6, 2019 I've replace one on my Edge X 582. From Airborne, advised that zip ties are ok. This is what I did then covered the join in heat shrink. 1 Link to post Share on other sites
rep003 Posted August 7, 2019 Author Share Posted August 7, 2019 I've replace one on my Edge X 582. From Airborne, advised that zip ties are ok. This is what I did then covered the join in heat shrink. I spoke to the friendly team at Airborne & they said either cable ties or crimps were fine . Since I was ordering some parts anyway I got the crimps :-) It took a while to work out how to lace the bungy , but I have it sorted now . The previous repair had used two hose clamps ! Seemed to work well though ... but I will stick with approved methods Cheers 1 Link to post Share on other sites
Keenaviator Posted August 8, 2019 Share Posted August 8, 2019 How did you go with squeezing the crimps, keeping tension on the bungee etc? Link to post Share on other sites
rep003 Posted August 8, 2019 Author Share Posted August 8, 2019 How did you go with squeezing the crimps, keeping tension on the bungee etc? Short version ... cable ties :p I secured the pivot arm with one , & the end of the bungee with another , then pulled it tight & cable tied it off . I had already crimped one half so was ok to finish when secured . Another pair of hands would help greatly doing the remaining three bungees! Cheers Troy Rep. Link to post Share on other sites
