red750 Posted July 29 Posted July 29 The Australian rocket set to launch into space in Queensland today got off the ground then did a Spacex, settling back down in flames. 1
onetrack Posted July 30 Posted July 30 That would be an expensive disappointment. Musk can afford dozens of launch blow-ups, but I would imagine the Australian company would be hurting with that level of loss. I can well remember all the American space programme launch failures in the 1960's, they were truly devastating. I seem to recall someone did a YooToob video on them all. 1
Jerry_Atrick Posted July 30 Posted July 30 (edited) Disappointing, but hopefully they factored one or two failures into their calculations Edited July 30 by Jerry_Atrick 2
Blueadventures Posted July 30 Posted July 30 (edited) looks like one engine not at 100%, yellowish centre flam and not occupying cone diameter. I'm sure they will get it sorted out. Edited July 30 by Blueadventures 1
Kyle Communications Posted July 30 Posted July 30 They had a engine fail just after takeoff and also looks like another had lost thrust. I think every company who has tried to get their first orbital class rocket off the ground has had this type of failure. The one thing they took as being great was their thrust vertoring worked very well when the thrust was asymetric. Gilmore seemed pretty happy that at least it got off the pad 2
FlyBoy1960 Posted July 30 Posted July 30 ChatGPT Says. They should have used Chat GPT to design the rocket. They wouldnt have had this problem and would now be orbiting the moon. 1
onetrack Posted July 31 Posted July 31 (edited) And if they'd employed AI to design and launch their rocket, they'd have a man on the moon already! 😄 Edited July 31 by onetrack
Jabiru7252 Posted August 3 Posted August 3 When I was working I was involved in many trials and when something went wrong, you hoped the hell it wasn't your fault. Imagine being the person who wrote the code or wired a switch and got it wrong. Their head is probably on a pole in the company car park right now. 1 1
BurnieM Posted August 4 Posted August 4 Most work gets signed off by several levels of management before being actioned. It is hard to sack the person who did the work without sacking a manager as well (not impossible just hypocritical). 1
facthunter Posted August 5 Posted August 5 Work on BIG stuff has Builder approved procedures. IF you follow that to the Letter you are bombproof. Outside of that and you are on your own (as it should be). and it's also documented. Nev
onetrack Posted August 5 Posted August 5 Failure of components as they fail to meet specifications or are used outside their specifications, is also a high possibility. Remember the U.S. Challenger Space Shuttle disaster in 1986? It was due to o-ring failure because of a record low frost at the launch platform, which was never anticipated, and a temperature that the o-ring design was not ever expected to encounter.
facthunter Posted August 5 Posted August 5 She "Goes Like a Rocket" won't mean what it used to. Nev 1 1
