rgmwa
Everything posted by rgmwa
  1. Just to balance the books, I've always thought this scene was pretty good. Jimmy Stewart was an experienced WW2 bomber pilot and colonel in the US air force, so he would have known how to start an engine.
  2. Needs more signwriting practice then, or maybe a better dictionary.
  3. I believe they're not going for the mainstream routes, and you can get a Dragon Rapide down just about anywhere.
  4. Could mean Borrowed Off New Zealand Airways for all I know. Most of these cheap fare startups have had a short life in Australia, but maybe they’ll find a niche market and survive. Time will tell.
  5. Bonza Airlines? Not a name to inspire much confidence. Cheap fares, cheap planes, cheap maintenance?
  6. Only time I ever needed an ASIC was after landing at Tindal in the NT. The exit gates were remotely controlled and security wouldn't open them without an ASIC.
  7. The record at SABC was either 34 or 39 years for a Piel Super Diamant. First flew in 2016.
  8. Out of interest, I just looked up the first flight records for the Sport Aircraft Builders' Club (SABC) based at Serpentine in WA. The first recorded homebuilt to fly was in 1967 (Jodel). The number of first flights for each decade since then are: 1970-1979 - 22 1980-1989 - 20 1990-1999 - 51 2000-2009 - 40 2010-2019 - 30 In 2020 there were 5 and from memory there have been another 3 or 4 this year. Obviously membership has also grown since the early days, and there are currently about 350 members. Quite a few of these are just social or associate members, so there are probably around 250-280 full members. As with most other flying clubs the average age of members doesn't seem to be getting any younger so the long term trend may be downhill. However, from those figures at least, while the 90's obviously saw the greatest activity, the current numbers are still quite respectable. Demand for hangar space is also high, so that's a good sign.
  9. Same type of plane that had an EFATO at Serpentine not long ago, but unfortunately with a worse outcome.
  10. Rutan Defiant is not a common aircraft. What's it like to fly?
  11. My instructor told me he had a student freeze on the controls once and he ended up having to punch him to make him let go.
  12. If you do have an autopilot, best to engage it early before you become completely disoriented and put the plane into a situation where the AP can't recover it. It could be a lifesaver though, provided you have the presence of mind to use it and trust it to do its job. May not be so easy when everything outside suddenly goes white.
  13. I prefer not to ask anymore, Nev.
  14. Yenn, you're correct for all the RV's except the 12. Vans manufacture and sell the RV-12 as a completed fly-away LSA (SLSA), and they also sell the kit which the builder can register either as an ELSA or an experimental (EAB). If it's built as an ELSA, which most of the ones in the USA seem to be, it has to be an exact copy of the original with no deviations, and Vans then remains the registered builder - even though they didn't (crazy system). Therefore, because it can be either an SLSA (factory built) or ELSA (homebuilt copy of the factory original), Vans has to provide the POH and acceptance test procedures, so they write and publish those documents. However, if you choose to build the kit as an experimental (EAB), then you can write your own POH as per the other RV's, but why would you when it comes with the kit anyway. Incidentally to add to the craziness in the US, once the plane receives its `pink slip' for airworthiness as an ELSA, the real builder is allowed to modify it in any way they like, provided they don't violate the LSA performance or design parameters. In other words, it effectively becomes an experimental but with Vans still as the registered builder and with no control over any modifications. They must worry about that! Over here, CASA doesn't care whether you register it as an ELSA or ABE. If you build it as an ELSA, you're the builder, not Vans. Consequently most if not all 12's over here are built as ABE. In the US, the perception is that an ELSA will hold its value better, so that's the main reason most seem to go that way. It also only needs a 5 hour Phase 1 instead of 25 or 40 hrs, so that's another reason.
  15. That’s the right attitude. Good luck!
  16. Vans currently say the absolute ceiling for the 912 iS and 912 ULS versions of the RV-12 is 19,200' and 14,600' respectively. Their service ceilings are 17,300' and 13,000'. I assume these are at standard temp and pressure. I took mine up to 12,400 once before deciding that was far enough for me, although the plane was still climbing.
  17. Just to confuse the issue, the RV-12 POH states Vne of 136 KIAS up to 16,000', but 136 KTAS (at higher altitudes - implied but not very clear in the POH). This assumes both you and the plane can get that high. Don't ask me how Vans decided on those apparently contradictory limits, but I'm sticking with TAS at all altitudes.
  18. I can understand the attraction of having a high performance aircraft if you like fine and fast machinery, but I suggest your focus at this stage should be on learning to fly well. You can run into information overload even in a docile 100 kt aircraft when you're coming in for your first few landings. High performance also means much more complexity with constant speed props, retractable gear, sophisticated displays showing a lot of information that you have to take in quickly. Getting a PPL is a significant achievement at any age, and being young at heart doesn't quite compensate for getting older, even if you are in good shape overall. There is a lot to learn when doing the course that is not just about handling the aircraft. You will also need further training and licence endorsements to operate the more complex aircraft. I got my PPL a couple of weeks before turning 60, so I was also a late starter. Age in itself is not a barrier. My suggestion is to book the Cessna and an instructor and have fun driving the Porsche to the airport for a while. Time enough to trade up later by which time you'll also have a learned a lot more about the kind of aircraft you want to fly. If you find you like aerobatics for example, you might change your mind about the Cirrus.
  19. Easier to see where you've been than where you're going. Not a great design feature for a fighter.
  20. Here's one ...
  21. Link to a related article that Vans did some years ago that may be of interest. https://vansaircraft.com/wp-content/uploads/2019/01/hp_limts.pdf
  22. Bit of a long shot but you could try contacting these guys (Steve or Tom). http://www.aircraftspecialty.com/ They are aircraft hose specialists so if they can't help they can probably tell you where to look. They are pretty helpful in my experience. MacFarlane may also be worth a look. https://www.mcfarlaneaviation.com
  23. Good on you for building your own plane. I hope you keep on with it despite your negative experiences around aero clubs. Money is a definitely a problem for most people and particularly when you're young. Even for most of us older guys it's a big commitment. That's the main reason I was just on 60 before I got my licence and started building my RV, also with no experience. I could not have justified the cost and time commitment much before then. My experience at the aero club where I trained was also different. There were plenty of old guys there besides me but also lots of young students and keen instructors that made it a busy and enjoyable place to be. No doubt there were people like those you describe, but I never came across any. It sounds as though you've had a long run of bad experiences which is pretty unfortunate, but I hope you keep at it and get that plane in the air.
  24. Too true! It's depressing to get on a commercial flight these days. The first thing most of the passengers do is pull down the window shades so they can see their electronic gadgets better. You spend the whole flight stuck in a dimly lit tube until you get off at the other end. Granted you can't see a lot from 35,000 feet, but at least in years gone by people treated a plane trip as an event and took some interest in what was happening. Not any more.
