Blueadventures
  1. Could be carby balance or the carb opening system. Could try redoing a mechanical balance. If you were to do a mechanical balance make a note of the turns to get the gap that is measured with a feeler gauge and also the turns on the idle jet. That way if they are out of speck you can adjust to speck or reset them where they were. If you want I'm happy to loan you my balance master for one month if you pay the postage. But consider the mechanical balance first. Even a pneumatic balance if you have ethe gear.
  2. Skip please reread my post and correct your statement as in my second parragraph I said I had a balance master fitted and very happy with it. I saw the balance master on your old Zephyr and assumed you where still happy to fly with it, and you have confirmed your reason and its perceived benefit. For site users information I was very happy with the reduction of vibration by the balance master and would fit one again in the absence of performing dynamic balances. My experience was during 77 flights during 2018 and 2020. AS I now use a Dynavibe to perform dynamic balances I do not refit the balance master (Balance master can not be on the prop during the dynamic balance procedure.) Skip how many flights have you made with the balance master fitted for comparasion?
  3. Agree however the Dynavibe is counting rpm off the reflective tape on one blade so its reduction rpm.
  4. All good; I was referring to MoneyBox's comment. Your 600 tacho is very good balance wise. Cheers.
  5. Some testers are considering the gear ratio not engine rpm on tacho; therefore 600 rpm of prop may be about 1500 rpm on a Rotax 912.
  6. That will work, 500m, good to have releases in the fences so if you clip them with wheels the wire will let go easily and weak posts that will fold over. Also can have side bits at each end so you can do a rolling start when ever needed (start at right angles onto end of runway so rolling when enter and rolling line up and away, not starting from fully stopped at the end.)
  7. By chopper escorted by cobra gunships.
  8. Also mandatory is a shelter, dunny, tea and coffee honor tin and windsock.🙂🙃 You will have a good setup.
  9. Just read your pipe length, look perfect.
  10. Three times the wing span is a good start as minimum (25 to 27 meters).
  11. I give mine a hand cut / polish / wax with a good quality Meaguires product about twice a year; just keep off any decal areas. Starbrite is more like a water stain remover. I'd try the hand polish on an under surface; it should work and most likely you will always notice a different shade where the decals were. Paul or Mark Hilton will have some ideas especially Mark as they restore and repair a lot.
  12. Mike, your aware that sika needs to be protected from UV? Thats the role of the black colour on glass etc; it's to shade the UV not for looks in the first instance.
  13. Meant to be mate; you always remember great true mates forever. Cheers.
  14. Fantastic as usual. You should be the airman of the year. Cheers. PS I'm at Kurrimine the first 2 weekends and the week between again this year. Weather was all over the show this year so must do the catch up like we planned last year.
  15. Best way to cut that spring steel is a small cut off wheel; Dremel or similar. 100mm with care and 1mm wheel. Used all in the past. Then dress the cut end of wire for craftmanship.
  16. How good is that, Congrats and well done to you.
  17. AOPA posted on their BookFace site today.
  18. Well done, may never have been taken out. May be do an oil change at 15 - 20 hours and recheck plug then. Glad it came out for you. I've never put a copper washer under them or seen such. Cheers.
  19. That is about inspection of it; do a google of 'unable to remove magnetic plug' and rotax owner will have some methods of removal. I came across a stubborn one before Xmas while doing an oil change. Owner is getting a new mag plug hex head from floods and then the old one will be removed and inspected and the new one fitted. I hope for you that yours is free it takes a #40 Torx and make sure its fully in when turning as they strip out easily and that's why Rotax upgraded the plug.
  20. Yes I would, two reasons one to see any fur, filing on it and to know it can be undone. It’s a torx drive not Allen key. If it’s hard to undo try some hammer taps and vice grips to loosen. There no washer or copper washer under it just a metal to metal fit. Cheers
  21. Depends on when you do your filter; I change oil at 50 and filter at 100. At 100 also lube the muffler to header ball joints on mine so if you have ball joint type connections you may consider relubeing them at 100 with the specified lube. Mine is S/S so use Koppa Kote / Copper slip lube. Steel Rotax require one of the nickle anti seizes. have you had the magnetic plug out, it has a torx female and they can be a real pain and then you need to buy the upgrade hex head one a 16mm / 5/8” ring spanner fits.
  22. How's Lone Eagle at Clifton, I'd recommend the drifter alos have Jabiru. Be close and have overnight accommodation so could do and afternoon and then a morning fly in the smooth air to start back again with.
  23. Nice Mike. What was the empty weight of Nic's and a couple of images would be nice of how it looks today. Yours is coming along nicely; they take a while just need to get over the humps when seems slow and never getting there thoughts; I'd just do some small things to keep it moving. Like the paint job and colours; even though I'm a Blue person. Cheers
  24. Lucky Keizer took a Rolls Royce Merlin engine from a Mosquito aircraft, chopped off two cylinders and built a bike around it.
  25. The engine is a modified Merlin 12 out of an aircraft so I believe it has a connection, it was last displayed at the Mechanos Air show in Mackay.
