eightyknots Posted September 5, 2012 Posted September 5, 2012 Quote What is "Tombstone Technology" meant to mean.? If you owned a jabiru you would give up. Honestly, they have some problems but you have got to wonder how much of it is bad workmanship and maintenance, There is a lot of good stuff on Jabaru's website. have all those instructions and bits of advice been carried out with all the engines out there? I reckon I'm pretty neutral on this one, but you will never get anywhere unless you make sure that you deal in facts. A lot of this condemnation is by people who don't operate them or own them. I am not sure that the engines Motz has been dealing with have had the right thing done with them either. Nev Motz might have to change the LAME he uses....
motzartmerv Posted September 5, 2012 Author Posted September 5, 2012 Yea. That would make sence if the two recent engine failures were maintained by the same l2. Or were even in the same state, or operated in the same school. This aeroplane is flown from my satellite school in goondiwindi. I'm pretty sure I've said that 3 times now. I think motz is pretty sure what needs changing, and it ain't the professional engineers he uses.
eightyknots Posted September 5, 2012 Posted September 5, 2012 Quote Yea. That would make sence if the two recent engine failures were maintained by the same l2. Or were even in the same state, or operated in the same school.This aeroplane is flown from my satellite school in goondiwindi. I'm pretty sure I've said that 3 times now. I think motz is pretty sure what needs changing, and it ain't the professional engineers he uses. I think you need a Charge of the Horse Brigade. (for Charge, read Change)
Sapphire Posted September 5, 2012 Posted September 5, 2012 Quote Tombstone Technology: Lots of products are put on the market with little safety testing. For a long time cars didn't have seatbelts but when the death rate embarassed the governments too much, they were manditory. We like to think a life has infinite value, but not true. The amount spent on safety in the airlines is based on a dollar value of your life-some figure I can't remember. If they spent more on a passenger, then it becomes cheaper to let the passenger die [statistically speaking] When you think about it, you can't spend an infinite amount on safety because there isn't an infinite amount available
turboplanner Posted September 5, 2012 Posted September 5, 2012 Quote Lots of products are put on the market with little safety testing. For a long time cars didn't have seatbelts but when the death rate embarassed the governments too much, they were manditory. We like to think a life has infinite value, but not true. The amount spent on safety in the airlines is based on a dollar value of your life-some figure I can't remember. If they spent more on a passenger, then it becomes cheaper to let the passenger die [statistically speaking] When you think about it, you can't spend an infinite amount on safety because there isn't an infinite amount available Come on Sapphire, I was one of the pioneers of seat belts, safety harnesses, roll cages and a few other things, and we sure didn't have any statistics to show they would reduce deaths other than in some US auto racing, particularly NASCAR.
motzartmerv Posted September 5, 2012 Author Posted September 5, 2012 Didn't they used to think seatbelts were dangerous?
Bubbleboy Posted September 5, 2012 Posted September 5, 2012 Quote Didn't they used to think seatbelts were dangerous? I was an Undertaker for many years and collected a number of folk out of cars and machinery that died because they couldnt get out of a vehicle because of them. In saying that I am sure they save more lives than by not wearing one. Anyway off topic. Jury still out about these Jabs!... Scotty
Old Koreelah Posted September 5, 2012 Posted September 5, 2012 I don't want to re-open the perennial debate, but we should remember that many Jab engines are running quite reliably, and a few (but not nearly enough) make it past 1000 hours. We just don't seem to hear these stories. 1
Tomo Posted September 5, 2012 Posted September 5, 2012 Well to the Jab's credit with this problem, this wasn't a design fault, but an assembly issue by the assembler... (be that Jab factory or someone else)
king_daniels Posted September 5, 2012 Posted September 5, 2012 Jab engines 80hp, 1112 hours and still running strong. 4
Thruster87 Posted September 5, 2012 Posted September 5, 2012 Quote MotzWhere the inlet manifold connects to the head they have or at least they are supposed to have gaskets, stripped my 3300 yesterday for a top. Where they come out of the air box there is no gasket. I think you will find that there are no gaskets used on th 3300A only "O" rings and sealants Cheers
Sapphire Posted September 5, 2012 Posted September 5, 2012 There were two Jabs at a club I flew at and they were doing top end overhauls almost as often as they changed underwear. One new plane needed it done after 300-400 hours and another was done 3 times in about 3 years. He eventually sold it for something else which had electrical problems. Planes keep you busy
motzartmerv Posted September 5, 2012 Author Posted September 5, 2012 The guys from the brumby factory showed me a plane that was on it's 3rd engine with 15 hours on it. It's since done 100 and something, but it's the third attempt engine. O think that Ome played no small part in them not using the engine anymore. Only offering rota and lycoming engines in new acft now.
Aldo Posted September 5, 2012 Posted September 5, 2012 Quote I think you will find that there are no gaskets used on th 3300A only "O" rings and sealants Cheers See section "G" of the Jabiru 3300 engine parts manual. As you can see there are 6 gaskets and 18 cap screws (i.e. 3 screws per head) the "O" rings are on the plenum which is mounted on the underside of the engine 1 4109824 2 GASKET 6 PH0535N CAP SCREW 3/4 X 1/4UNC 18
turboplanner Posted September 5, 2012 Posted September 5, 2012 gaskets/no gaskets, daily inspection of items which can't be seen without a strip longer than the flight? Whatever happened to the aviation standards that were higher than car standards? 1
Doug Evans Posted September 5, 2012 Posted September 5, 2012 from what been said it sounds like you are sitting on a granades bit like the old rotax 532 ! I think I be looking at replacing a jab with a 912 s or a 582:amazon: I feel safer .I have a friend who but a jab in a lightwing and he always got the heads of the thing he always trying to get it right ,, but in saying that I know of others early jabs that are going fine and still getting around everywhere with no problems so to me it sound like a late model issue '
jetjr Posted September 5, 2012 Posted September 5, 2012 OK, talking about induction pipe to head not main induction plenum These have 3 bolts and a gasket, also should have been checked at 25 hr service........some are a bit hard to get to without correct long ball head allen key This is an assembly/service mistake, very little to do with Jabiru engine design Id be pulling that head for valve inspection, it would have been running lean for some time. Tell the owner to fit an Engine monitor, would have saved this emergency landing without doubt in my mind.
