Roscoe Posted July 15, 2014 Share Posted July 15, 2014 Hi all, can anyone explain this brief shudder at about 150ft on tkof which dissipates quickly? Could it be out of balance tyres ? Appreciate comments thanks Guys Link to comment Share on other sites More sharing options...
Powerin Posted July 15, 2014 Share Posted July 15, 2014 In my little experience, yes. An out of balance tyre does cause a shudder as it slowly winds down after takeoff. 4 Link to comment Share on other sites More sharing options...
Jabiru Phil Posted July 15, 2014 Share Posted July 15, 2014 Hi all, can anyone explain this brief shudder at about 150ft on tkof which dissipates quickly?Could it be out of balance tyres ? Appreciate comments thanks Guys Bound to be out of balance tyres. Apply the brake. If this doesn't fix it could be the front tyre. Test by lifting the front in the hanger and notice if the wheel wants to settle in the same place at the bottom. There is a recent post about this and remedies Phil By the way, regards your gps installation query in another post, I made the bracket on photo from a part from the kit supplied with my unit. The very great advantage of this positioning is that you don't look down when using and does not interfere with visibility. My panel has the gps cutout, but not good for the above reasons. Cheers Phil. 1 Link to comment Share on other sites More sharing options...
Roscoe Posted July 15, 2014 Author Share Posted July 15, 2014 In my little experience, yes. An out of balance tyre does cause a shudder as it slowly winds down after takeoff. Thanks Mate 1 Link to comment Share on other sites More sharing options...
facthunter Posted July 15, 2014 Share Posted July 15, 2014 Just touch your brakes after lift of. The mains will stop. The nosewheel should have less effect. Nev 1 Link to comment Share on other sites More sharing options...
Roscoe Posted July 15, 2014 Author Share Posted July 15, 2014 Just touch your brakes after lift of. The mains will stop. The nosewheel should have less effect. Nev Thanks Nev Link to comment Share on other sites More sharing options...
Roscoe Posted July 15, 2014 Author Share Posted July 15, 2014 Phil Bound to be out of balance tyres. Apply the brake. If this doesn't fix it could be the front tyre.Test by lifting the front in the hanger and notice if the wheel wants to settle in the same place at the bottom. There is a recent post about this and remedies Phil By the way, regards your gps installation query in another post, I made the bracket on photo from a part from the kit supplied with my unit. The very great advantage of this positioning is that you don't look down when using and does not interfere with visibility. My panel has the gps cutout, but not good for the above reasons. Cheers Phil thanks I now have a RAM Mount with suction cup which works great! 1 Link to comment Share on other sites More sharing options...
facthunter Posted July 15, 2014 Share Posted July 15, 2014 You could spin the wheel up with a wire wheel mounted in a drill if the seals are a bit stiff. Nev Link to comment Share on other sites More sharing options...
Roscoe Posted July 15, 2014 Author Share Posted July 15, 2014 T You could spin the wheel up with a wire wheel mounted in a drill if the seals are a bit stiff. Nev Ok thanks Link to comment Share on other sites More sharing options...
jetjr Posted July 15, 2014 Share Posted July 15, 2014 They dont have to be perfect to stop the shudder, but can take alot of weight like 20-40g I did mine on the aircraft and fixed the issue. Link to comment Share on other sites More sharing options...
Bruce Tuncks Posted September 5, 2014 Share Posted September 5, 2014 There is a story about how factory testing in the early days showed shuddering at about 100 knots. They thought it might be flutter and they beefed up the elevator hinges. In fact it was a wheel starting to spin with the slipstream being enough to do this at 100 knots. The advice about using the brake is correct, but do it gently as it is apparently possible to do damage.. I guess that all the rotational kinetic energy in the spinning wheels has to be absorbed somehow, so you don't want a sudden grab. Link to comment Share on other sites More sharing options...
Roscoe Posted September 5, 2014 Author Share Posted September 5, 2014 Thanks Bruce. Yes gentle application of brakes fixes it Link to comment Share on other sites More sharing options...
rankamateur Posted September 5, 2014 Share Posted September 5, 2014 100kts at 150 feet, I am impressed. Link to comment Share on other sites More sharing options...
Bruce Tuncks Posted September 5, 2014 Share Posted September 5, 2014 Well you probably could do 100 knots at 150 ft in a 6 cylinder Jabiru, but the story was about how the wheel or wheels STARTED to spin at 100 knots and how they worried about it being flutter. I guess the bit sticking out below a spat has a turning effect from the slipstream and this effect increases with speed. ... Bruce Link to comment Share on other sites More sharing options...
rankamateur Posted September 5, 2014 Share Posted September 5, 2014 I was only teasing. There would be no turning effect with bare wheels then? I am not putting pants on mine so my balance problems will all happen on the ground I hope. Link to comment Share on other sites More sharing options...
hyundai Posted March 22, 2015 Share Posted March 22, 2015 Try applying brakes after lift off if it stops its wheel balance Link to comment Share on other sites More sharing options...
Guest Fresno Jab Posted April 28, 2015 Share Posted April 28, 2015 Hi all, can anyone explain this brief shudder at about 150ft on tkof which dissipates quickly?Could it be out of balance tyres ? Appreciate comments thanks Guys Not sure, I have the same issue on occasion...can feel wheel spin up on rudder pedals. Maybe main tires scrub from landing gear decompression on take off? Link to comment Share on other sites More sharing options...
Roscoe Posted April 28, 2015 Author Share Posted April 28, 2015 Thanks.Others have suggested its the tyres spinning after liftoff which can be fixed by applying brakes briefly. Not sure, I have the same issue on occasion...can feel wheel spin up on rudder pedals. Maybe main tires scrub from landing gear decompression on take off?[/QUO 1 Link to comment Share on other sites More sharing options...
frank marriott Posted April 28, 2015 Share Posted April 28, 2015 Obviously if touching the brakes get rid of it it is the mains. I have found a slight shimmy from the nose wheel about the time referred to when the nose is left on the ground too long. I find picking the nose wheel off the ground a couple of inches early in the take off roll and letting it fly off when ready elimates this (being mindful that you have no directional control until the rudder starts flying) Link to comment Share on other sites More sharing options...
Ultralights Posted April 28, 2015 Share Posted April 28, 2015 dont forget, some aircraft fitted with wheel spats, can have their wheels constantly rotate in flight, even my Savannah nosewheel never stops turning from take off until after i land and park the aircraft Link to comment Share on other sites More sharing options...
hyundai Posted April 28, 2015 Share Posted April 28, 2015 Hey guys I have a problem one head bolt has stripped in the barrel. Not much room for a helicoil. .???? Link to comment Share on other sites More sharing options...
deadstick Posted April 28, 2015 Share Posted April 28, 2015 That's a throw away mate. Link to comment Share on other sites More sharing options...
facthunter Posted April 28, 2015 Share Posted April 28, 2015 You might be able to go slightly bigger and get away with it. If you go to a metric from AF or whatever it is you can sometime minimise the oversize. Nev 1 Link to comment Share on other sites More sharing options...
aj_richo Posted April 28, 2015 Share Posted April 28, 2015 dont forget, some aircraft fitted with wheel spats, can have their wheels constantly rotate in flight, even my Savannah nosewheel never stops turning from take off until after i land and park the aircraft Yep, my spatted Sonex does it continuously, I can set the brake lever behind the flap lever to apply park brake inflight. (Flap lever won't operate if I forget downwind check, and I rarely perform flapless approach but there is always the potential of course to land park brake on.. ) Link to comment Share on other sites More sharing options...
facthunter Posted April 29, 2015 Share Posted April 29, 2015 Murphy's law. I wouldn't set a brake on in flight, as a principle. We ALL do a pre landing brakes check don't we? but..... When you take off, you know the brakes are off. When you are landing you need to know they are off. Nev 2 Link to comment Share on other sites More sharing options...
