recflyer Posted February 18, 2015 Share Posted February 18, 2015 http://generalaviationnews.com/2015/02/17/videos-sonex-reports-several-milestones-for-subsonex-jet/ Link to comment Share on other sites More sharing options...
scre80 Posted February 18, 2015 Share Posted February 18, 2015 I soo want one of these planes!!! 2 Link to comment Share on other sites More sharing options...
recflyer Posted February 18, 2015 Author Share Posted February 18, 2015 I soo want one of these planes!!! Same, I wonder what the running costs of this aircraft are compared to a similar high performance single engine aircraft? Link to comment Share on other sites More sharing options...
scre80 Posted February 18, 2015 Share Posted February 18, 2015 I think if you can afford this kit plane, running costs will not be a problem!!! 1 1 Link to comment Share on other sites More sharing options...
bexrbetter Posted February 18, 2015 Share Posted February 18, 2015 Same, I wonder what the running costs of this aircraft are compared to a similar high performance single engine aircraft? Shirley ...... Link to comment Share on other sites More sharing options...
flyvulcan Posted February 19, 2015 Share Posted February 19, 2015 Same, I wonder what the running costs of this aircraft are compared to a similar high performance single engine aircraft? Specific fuel consumption for this engine is reportedly around 1.2lb/lbf/hr so at takeoff thrust (240lbf), fuel flow is probably around 290 lbs/hr which for JetA1 is 165 litres per hour. A high altitude cruise may reduce that to about half... 1 1 Link to comment Share on other sites More sharing options...
KRviator Posted February 25, 2015 Share Posted February 25, 2015 AT 44,000 Euros for the donk, you'd be better off buying an RV-8 and installing TIO-320 or similar. The SubSonex will do 240mph, the RV-8 will do 200, but on a quarter of the fuel, and for three times as far. Probably do a bit better with the turbo. And it'll be cheaper too. 1 Link to comment Share on other sites More sharing options...
kasper Posted February 25, 2015 Share Posted February 25, 2015 AT 44,000 Euros for the donk, you'd be better off buying an RV-8 and installing TIO-320 or similar. The SubSonex will do 240mph, the RV-8 will do 200, but on a quarter of the fuel, and for three times as far. Probably do a bit better with the turbo. And it'll be cheaper too. .... that's Euro 44k Plus controllers, filters, instruments Plus delivery Plus GST ... but lets face facts ... this is and never was about efficiency if cost/MPH or MPG ... its was about the fact it's a freaking JET and if you are not a very select few in an airforce this is your ONLY real chance at getting your bum in the pilots seat of your own jet. 3 2 Link to comment Share on other sites More sharing options...
bexrbetter Posted February 25, 2015 Share Posted February 25, 2015 AT 44,000 Euros for the donk, you'd be better off buying an RV-8 and installing TIO-320 or similar. The SubSonex will do 240mph, the RV-8 will do 200, but on a quarter of the fuel, and for three times as far. Probably do a bit better with the turbo. And it'll be cheaper too. Yup and we should all be driving Toyota Prius also. Anyway, got to go, Myer have brown corduroy pants on sale today ..... Link to comment Share on other sites More sharing options...
scre80 Posted February 25, 2015 Share Posted February 25, 2015 AT 44,000 Euros for the donk, you'd be better off buying an RV-8 and installing TIO-320 or similar. The SubSonex will do 240mph, the RV-8 will do 200, but on a quarter of the fuel, and for three times as far. Probably do a bit better with the turbo. And it'll be cheaper too. Like Others have said, it is a JET and aerobatics rated!!! Cost and Fuel burn, if I could afford to buy and run it, who cares!!! Best thing, only 1 seat so you also get to be by yourself!!! 1 Link to comment Share on other sites More sharing options...
Guest Howard Hughes Posted March 2, 2015 Share Posted March 2, 2015 AT 44,000 Euros for the donk Considering the kit includes the engine, I think it's fairly good value! Link to comment Share on other sites More sharing options...
facthunter Posted March 2, 2015 Share Posted March 2, 2015 There's nothing difficult about flying a Jet . There's no torque reaction... but at 247 lbs thrust it's not going to roar off the ground and will use fuel at a rate you can hardly believe. Being unpressurised you have no chance of getting it's range up to anything realistic. Breathing pure oxygen is not good for you, and you need to have it for flight over 10,000' You don't necessarily have to use it. IF you smoke you will have more need of it. After you get over the buzz , what then? Think I would prefer an occasional blast in something like an Ag Cat . Nev Link to comment Share on other sites More sharing options...
scre80 Posted March 2, 2015 Share Posted March 2, 2015 There's nothing difficult about flying a Jet . There's no torque reaction... but at 247 lbs thrust it's not going to roar off the ground and will use fuel at a rate you can hardly believe. Being unpressurised you have no chance of getting it's range up to anything realistic. Breathing pure oxygen is not good for you, and you need to have it for flight over 10,000' You don't necessarily have to use it. IF you smoke you will have more need of it.After you get over the buzz , what then? Think I would prefer an occasional blast in something like an Ag Cat . Nev It will always be a personal choice. For me, I would love being able to get up and just fly around for no real reason. Best thing, 1 seat so get to go up by yourself!! But yes, if you were intending to go somewhere on a trip, then yes not the right choice. Link to comment Share on other sites More sharing options...
facthunter Posted March 2, 2015 Share Posted March 2, 2015 A few more figures. MAX speed 174 kts Cruise 15o(ota) Fuel 32 Gals Fuel flow 18 gph giving about One hour 40 mins to empty. You wouldn't want to taxi for long either. I think I saw something like a Bede 2 jet fly at Avalon in the 90's. I think it had even less endurance. IF you are keen to fly a Jet..( It won't be cheap to get a full endorsement on it but you don't have to) perhaps a Citation or Lear jet might be a consideration. Spend a bit of time preparing for it (The theory) and have a pressurisation endorsement too. There's such a thing as a pressurised Turboprop Lancair. Nev Link to comment Share on other sites More sharing options...
planedriver Posted March 3, 2015 Share Posted March 3, 2015 Very slippery too, like the money leaving your pocket to buy one (US$950,000-US$1.25 mil and that was about 4yrs ago) Link to comment Share on other sites More sharing options...
scre80 Posted March 3, 2015 Share Posted March 3, 2015 Back to the point of the subsonex, it is a 1 seater for FUN and does aerobatics!! Cheaper than $1mil Link to comment Share on other sites More sharing options...
Kyle Communications Posted March 3, 2015 Share Posted March 3, 2015 Its just like getting your $25,000 ornament out of the garage once in a while to blow the dust off it....at 60 litres and hour.....don't you just love a jet ski 1 Link to comment Share on other sites More sharing options...
scre80 Posted March 3, 2015 Share Posted March 3, 2015 Its just like getting your $25,000 ornament out of the garage once in a while to blow the dust off it....at 60 litres and hour.....don't you just love a jet ski Great thing too, 1 seat, guaranteed time by yourself!! Link to comment Share on other sites More sharing options...
Thirsty Posted March 3, 2015 Share Posted March 3, 2015 A lot less money would be a Onex with a jab 6 or maybe a 914 (not sure if it'll fit). There would be heaps of performance, single seat still and just as aerobatic. Not a jet, true but lots of performance. Link to comment Share on other sites More sharing options...
scre80 Posted March 3, 2015 Share Posted March 3, 2015 Just something about a jet though!!! 1 1 Link to comment Share on other sites More sharing options...
bexrbetter Posted March 3, 2015 Share Posted March 3, 2015 A lot less money would be a Onex with a jab 6 or maybe a 914 (not sure if it'll fit). There would be heaps of performance, single seat still and just as aerobatic. Not a jet, true but lots of performance. Are you strictly a company accountant or do you do private tax returns? .... IT'S A JET!! 1 Link to comment Share on other sites More sharing options...
facthunter Posted March 3, 2015 Share Posted March 3, 2015 A jet engine turns kerosene into a bad smell. Hasn't got the character of a big radial, and it's so easy to fly (the JET) it's for pussycats. Their ease of handling is a well kept secret. None of you will let it out will you.? Anyhow 174 knots? MAX. Not exactly supersonic is it?. It's not really enough bang for your buck.... Believe me... You would tire of it in a week...Nev 1 Link to comment Share on other sites More sharing options...
bexrbetter Posted March 3, 2015 Share Posted March 3, 2015 Hasn't got the character of a big radial, and it's so easy to fly (the JET) it's for pussycats. Their ease of handling is a well kept secret. "character"; a misnomer for old dangerous pieces of crap. Use your experiences to educate how bad things were "In the good old days" and to use the knowledge to move forward, that's what real men do. 1 Link to comment Share on other sites More sharing options...
facthunter Posted March 3, 2015 Share Posted March 3, 2015 You have your idea's. I have mine.. If you fly for a challenge and real experiences not everything new does it better for you. I'm not suggesting one should fly behind radials to England. . What the hell is this REAL Men BS. Bex? Anyhow I've told you a million times not to exaggerate. Nev Link to comment Share on other sites More sharing options...
Thirsty Posted March 6, 2015 Share Posted March 6, 2015 Are you strictly a company accountant or do you do private tax returns?.... IT'S A JET!! Really? I should read these posts a bit better. I was merely pointing out you can get a hell of a lot of performance from the same stable for a LOT less money. And it would sound good too - turbines are boring! Link to comment Share on other sites More sharing options...
