danny_galaga Posted 13 hours ago Posted 13 hours ago I figured the engine section is the best place to ask My plane has matco ph-8 disk brakes. The right one is getting much hotter than the left one. Have to add extra herbs after landing to taxi. And much harder to push back into the hangar. It looked a bit glazed, so I was hoping maybe it's suffering from a positive feedback loop whereby the more it overheats, the more glazed it becomes. The more glazed the hotter it gets. I took the caliper off, and de glazed with wet and dry and water. Also touched up the pads with wet and dry on a flat surface. The system is comically simple, and everything thing seems to moving. Pressing the brake pedal gently showed the piston moving. The caliper sliding thing slides. I'm at a loss! If I don't hear of any easier things to try by tomorrow, I'll swap left caliper for right (they are symmetrical) and see if the problem follows it.
skippydiesel Posted 13 hours ago Posted 13 hours ago Speculation: A brake gets hot due to friction. Friction, in this context, is when two materials/surfaces moving at diffrent speeds make contact. Two identical (?) brake systems should deliver the same temperature IF the same forces are applied. Is this an independent brake system (as in castering tail /nose wheel) or a single acting Master Cylinder system? Glazing is more likly to result in cooler(less effective) brakes as the smooth surface of the glazed disk results in less friction. Difference's in materials (brake pad/disk) are likly to result in diffrent temperatures. Differences' can be caused by contamination. Oil is a common one, but other substances eg metal filings can have a similar effect. Do you wash your brakes? If so could detergent residue be contaminating the surfaces? Misalignment of calliper Incorrectly assembled or manufacturing defect, may cause the slave cylinder piston to not retract, causing the brake pad to rub/bind at all times, generating some heat that just increases with braking effort Air in one brake line/system 😈
skippydiesel Posted 13 hours ago Posted 13 hours ago Just another , random. thought - Are you using the correct brake fluid for your system?😈
BrendAn Posted 13 hours ago Posted 13 hours ago 48 minutes ago, danny_galaga said: I figured the engine section is the best place to ask My plane has matco ph-8 disk brakes. The right one is getting much hotter than the left one. Have to add extra herbs after landing to taxi. And much harder to push back into the hangar. It looked a bit glazed, so I was hoping maybe it's suffering from a positive feedback loop whereby the more it overheats, the more glazed it becomes. The more glazed the hotter it gets. I took the caliper off, and de glazed with wet and dry and water. Also touched up the pads with wet and dry on a flat surface. The system is comically simple, and everything thing seems to moving. Pressing the brake pedal gently showed the piston moving. The caliper sliding thing slides. I'm at a loss! If I don't hear of any easier things to try by tomorrow, I'll swap left caliper for right (they are symmetrical) and see if the problem follows it. I think you will find a tight piston. . Can you push the piston In by hand 1
Blueadventures Posted 12 hours ago Posted 12 hours ago 1 hour ago, danny_galaga said: I figured the engine section is the best place to ask My plane has matco ph-8 disk brakes. The right one is getting much hotter than the left one. Have to add extra herbs after landing to taxi. And much harder to push back into the hangar. It looked a bit glazed, so I was hoping maybe it's suffering from a positive feedback loop whereby the more it overheats, the more glazed it becomes. The more glazed the hotter it gets. I took the caliper off, and de glazed with wet and dry and water. Also touched up the pads with wet and dry on a flat surface. The system is comically simple, and everything thing seems to moving. Pressing the brake pedal gently showed the piston moving. The caliper sliding thing slides. I'm at a loss! If I don't hear of any easier things to try by tomorrow, I'll swap left caliper for right (they are symmetrical) and see if the problem follows it. Is the piston returning (coming off, the pad retracting off the disk surface); if not that cause heat. 1
kgwilson Posted 12 hours ago Posted 12 hours ago I agree with Brendan. I reckon the piston is not returning after braking. Pull the whole wheel cylinder apart & check for rub marks grit etc, clean everything meticulously, reassemble & make sure moving parts i.e. the piston moves freely. 1
BrendAn Posted 11 hours ago Posted 11 hours ago When you own Honda road bikes you learn about sticky brake pistons 1
Thruster88 Posted 10 hours ago Posted 10 hours ago (edited) My friend once had a similar problem in his Socata TB10 Tobago. Problem turned out to be the master cylinder was not able to fully retract so hydraulic pressure could not be released to the reservoir. The hotter it got the harder the brake grabbed. Do you have a park brake valve or anything that might be holding pressure. Wrong fluid and swollen orings? Edited 10 hours ago by Thruster88 1
facthunter Posted 9 hours ago Posted 9 hours ago I'm with Thruster. Check residual pressure in the specific brake line. Crack the Bleed. That master cyl may not be porting. Check there's some free play before the Piston moves. Your pads may be too thick also. Nev 1 1
danny_galaga Posted 9 hours ago Author Posted 9 hours ago (edited) Some good thoughts there. I forgot to mention that since I'm on a grass field the only time I use the brakes is PARK on start and engine run ups, and to 'unkink' the tailwheel after pulling the plane backwards out of the hangar. And then of course a quick jab when taxiing to check the brakes are working. I'm Edited 9 hours ago by danny_galaga 1
danny_galaga Posted 9 hours ago Author Posted 9 hours ago 4 hours ago, skippydiesel said: Just another , random. thought - Are you using the correct brake fluid for your system?😈 Definitely the correct fluid. It's a mineral oil system. Just using what's recommended. My experience with hydraulic brakes in cars is that if you have air in the system, the reverse of what you are implying happens. Ask me how I know 😂
