Russ
Everything posted by Russ
  1. " screw downs " .......I think was the name, I've got a set, so far so good. ( set of 4, with screwing handle and pouch, $60 approx ) Don't forget the can of cheap surface spray, to douce your ropes and tyres, them angry ants don't mind climbing aboard sometimes. Especially out west.
  2. There are a number of bladder makers, most are GA certified. ( turtle pak, liquid solutions, just to name 2. ) Then there's all the imported ones.....again, most certified.
  3. You guys are waaay behind the times....chap NQ built a ground effect aircraft 30 yrs ago, Cessna powered, trialled it in the Deeral river, last I heard he was chasing more power out of it. Would not be surprised if it's gathering dust up here somewhere. Same chap gave me a video of a massive Russian built machine, it appeared to go really well. ( lurker here frank A might be able to shed some light, we trialled it right at his back door , Oye frank, it was ken C's project ) Just googled Russian ground effect aircraft.......bingo
  4. LAME that did my topend refurbish 6 mths ago, payed particular attention to the refitting of the 4 inlet tubes to the heads. He said relying on the single O rings was not good enough, he as well, placed a small ring of silicon just inside each joint, as the tubes came together, the silicon created that extra seal. ( where the tubes entered that alloy distribution box.) he noted at the dismantle stage that a couple of cyls were running leanish. Hence his usual practice of better sealing. Now done close to 100hrs, and checking plugs the other day, they all looked uniform in colour. The comment was....perfect.
  5. Got my renewal last week QBE.....was a tad less.
  6. Winners are grinners..........me face is aching from grinnin.
  7. I'm cybershakin you there merv. ( easiest $10 I've earnt today ).....can see yanks and SA doing it tho.
  8. [quote=" just kidding, that's never going to happen. Rod won't back down Yip......he'll go down with the sinking ship, that's a gimey. ( probably signing sales contracts with America and South Africa as we speak ) .....watch this space.
  9. A sentence within a mail from Camit......" We build / supply engines to jabiru, to THEIR specifications" .....period. The Camit engine is to Camits specs, jab forced Camit from further proceeding to "certification" ( this now situation has curtailed things, but stay tuned ) ...I hope
  10. Way back when, casa signed off the " C " series, as structurely sound, engine etc delivered test figures to agreed values, etc etc, now they are saying it's no longer reliable, so it must follow.....the package ( type C ) is now not certified. ( hello mr Camit, I'll pickup my new engine Friday )
  11. So....my 160c is no longer certified ??
  12. My 160C.........is casa type certified, that must include the engine I assume. So they've certified my original engine as operating to set specs, reliability etc, so it must follow, I'm exempt from this hoo ha,........( just a thought )
  13. I think......" Glide from populous areas" as mentioned in the casa document, excludes takeoffs and arrivals. Clarification might be needed here.
  14. The gyro folks have similar, it was " self " .....asra, initiated, yrs ago, never heard a case where the newbie bolted after reading the form, they signed, they flew.
  15. Phew.......( expected worse ) to the dooms day brigade......Get that into ya.
  16. The SOONER jab and Camit take a breath, realise each can save the other, and continue pumping out a great product, with reliability issues fixed, the sooner everyone's a winner. ( that's everyone )
  17. One issue I have on Mogas is at shutdown, it sometimes, just as it's about to stop, it reverse runs for a couple of prop revolutions. Why ?? Trialling different shutdown methods to stop this.
  18. My thoughts.....maybe......a reverse vented panel on the top of engine cowl. ( create a largish low pressure there to drag out head temps from above ) ?? An area of small rear facing vents. Just a thought.
  19. Ugland Windgeland Thatchland Sadland Headbutland Wetland Coldland Iwanaleaveland Couple of possibilities ??
  20. "draft proposal for jabiru aircraft" ....that's the topic to this thread... Gee.....we've well and truly deviated to engines and issues that are far removed from topic, the bulk of inputs here belong elsewhere. ( yes, mine too )
  21. Sure does... 16.3 LPH ...28ish revs........me same revs 15 ish. Latest jet kit too. ( did you jet even bigger ) ??
  22. Why the "PM" to find out your mods, share them for all to see / evaluate. Post a disclaimer if that helps. Strange to me, to express your " fix" but only accessed privately. .????
  23. About 150mm......the " angle " is a factor as well. Converted to 98 prem, adding moreys top end lube, as per their specs. Pull throughs etc, are always good. Acquaintance talked me into all this, he's accumulated 1500+ hrs! just keeps purring away
  24. This works a treat, I can maintain full power indefinitely, Max's to mid green, cruise sets at the bottom green. I've got the numbers somewhere. Full power, 250f = 121c Cruise........205f = 96c That's reading from LHR cyl head ( cyl 4 ...I think ) Your figure 150......f.....or Celsius ?
